Question about Toys
Zhen scooter will not idle
Motor will not idle
My Sym moped starts but won't idle It shuts off when trying to give it gas
Hi, Gigi and the usual suspects are:
1. Fuel cap or fuel tank is not venting properly.
2. Fuel filter clogged.
3. Fuel line pinched or kinked.
4. Float needle and seat sticking.
5. Float level too low.
6. Carburetor bowl vent line clogged/blocked/pinched.
7. Idle adjusting screw set too low.
8. Air/fuel mixture screw set too lean.
9. Idle port, transfer ports, slow air jet clogged.
10. Slow fuel jet clogged.
11. Faulty fuel pump.
For more information about your issue and valuable "Free" downloads that you will need please Click on the links below. Good luck and have a nice day.
Scooter Questions Get Answers to Your Scooter Starting Question
Scooter Troubleshooting Scooter won run All about Scooters
My chinese scooter wont idle or start Check the fuel petcock
http://scooterunderground.ca/knowledge/manuals/documents/sym_fiddleii125_service_manual.pdf
Oct 01, 2016 | Sym 125 EXC SIXDAyS Motorcycles
Why wont my linhai scooter idle with a taotao scooter carburetor
The carburetor has the wrong idle circuit jet fitted or incorrect idle screw adjustment.
Jan 07, 2015 | Linhai Motorcycles
Strating PROBLEM
Hi, Andrew and the usual suspects are:
4. Vacuum line from the petcock to intake manifold cracked.
5. Float needle and seat sticking.
6. Float level too low.
7. Carburetor bowl vent line clogged/blocked/pinched.
8. Idle adjusting screw set too low.
9. Air/fuel mixture screw set too lean.
10. Idle port, transfer ports, slow air jet clogged.
11. Slow fuel jet clogged.
12. Faulty fuel pump.
For more information about your issue and valuable "Free" downloads that you will need please Click on the blue links below. Good luck and have a wonderful day.
Why won my SYM Jet motor scooter start
Scooter Troubleshooting Scooter won start All about Scooters
Sym Jet 50 Service Manual
SYM Sanyang Scooter Parts Racing Planet USA
Sym JET 50 series Owner Manual
May 09, 2017 | 2007 Sym Jet Euro X 50
My scooter starts runs good then dies
Replace the battery, after sometime the battery starts to lose it's initial capacity.
For battery replacement go to Goped.com, select your scooter model, then click replacement parts and find the batteries on the part list.
Aug 02, 2010 | Go Ped Know Ped Goped Push Scooter
My sons goped starts and runs well with no weight on it. As soon as a person starts to ride it, it won't go and sputters. I took the engine off and looked at the clutch, and everything looks OK. Where else...
Sounds to me like you have a direct drive model with no clutch. With the direct drive model you just warm up the motor with no rider and wheel off the ground then turn it off and push start it "push and Go". The trick to push staring is stomping your weight down near the back tire as you push forward to get the rear tire turning. Once it turns so will the motor and it will start and your off and running. Do the push start without applying throttle and make sure you have the rear wheel adjusted against the drive roller correctly..
Jun 04, 2010 | Go Ped GSR Sport Gas Powered City Scooter
Where is the idle screw on a vmoto milan jx50 scooter?
It is on the side of the carb. Look for a large hand knob.
Sep 18, 2009 | Peg Perego Vespa Scooter
I bought a scooter from Right Way Scooters and it
adjust your idle up slightly, should have a screw on side of carb, turn slowly til' idle is correct
Sep 12, 2009 | Factory bike Chrono SM 250 Motorcycles
50cc Two Stroke Scooter Engine - Poor Idle
I had the same problem- from out of nowhere the scooter started dying at every stop. I adjusted the idle screw to 2000 and it still idled up and down. I bought some injector cleaner but this will take a while to work (several tanks of gas) and then found this link- seems to be a very simple thing to do once you read this link. I hope it helps. --
Mar 14, 2009 | Toys
Toys Logo
15 people viewed this question
Top Toys Experts
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
