Can I use a subwoofer from a lifestyle 12 Bose system with my yamaha htr 5940 receiver?
Is it possible or not
    New Friend:
  • 87 Answers
Yes, using digital coaxial cable.
Bose system supports only PCM DOLBY DIGITAL, no DTS.
Posted on Apr 18, 2014
SOURCE: How to conect iPod to Bose Lifestyle 12 Series II System
I connected my iPod with the same Bose with a cable you can get from Radio Shack for under $10.00. Please forgive me for not knowing the technical terms but one end has the male red and white plugs (audio composite)while the other is a single malplug that goes into your iPod. Just pick an open spot to plug it into the back of the Bose (Tape, Aux, Video) adn you are on your way.
http://www.radioshack.com/search/index.jsp?kw=ipod+cables&f=Taxonomy%2FRSK%2F2032058&categoryId=2032058&kwCatId=2032058
Found the link to the radio Shck site and the cables.
Hope This Helps.
Posted on Jun 05, 2009
rteemon
  • 578 Answers
SOURCE: HTR-5740 Receiver Subwoofer Problem
as long as there is a speaker out from the receiver you should be ok just make sure polarity for spkr is right --remember you workng with AC current bad wire will cause fire==
Posted on Jun 26, 2009
smarthome2
  • 1114 Answers
SOURCE: HTR-5740 Subwoofer Hooking Up Issue
You can use a hi-level to low-level adapter. Just remember, the Yamaha does not send power (wattage) to the sub, just signal. You need to use a subwoofer that has an amplifier either externally or built in.
dunnbiker
  • 8546 Answers
SOURCE: AVR-1910 & Bose Lifestyle 35 setup
Bose Lifestyle (and all Bose-amplified speaker) products and their speakers are SYSTEMS and should not be split up or intermixed with other brands or models. Damage will probably result. Proprietary connectors provides a clue.
The digital audio out should work with the Bose. You could still use your Denon to drive a conventional sub in your scheme, but you would have to manually match volume with the Bose. Or go Full Monty and buy a full complement of speakers for the Denon, retask the Bose and slave its sources to the Denon.
Posted on Dec 07, 2009
Testimonial: "Thank you sir; your quick response is highly appreciated. I returned Denon and am considering DVDO Edge. Regret running Bose wires @ construction?"
  • 150 Answers
SOURCE: I have a rca no rtd250 impedance 12 ohms
The Yamaha can only drive powered subwoofers. Make sure that the RTD250 has it's own amplifier built in, you won't be able to easily run it off the yamaha if it doesn't.( the powered subwoofer will have a mains cord to power if it's correct) If it doesn't have a amp built in, easiest weay is to buy a cheap powered sub.
Is the RTD 250 the sub fromthe RCA home theatre pack?
Posted on Jan 14, 2010
Cant get my subwoofer to turn on that is connected to my yamaha receiver
MAke sure you have the lfe output enabled. Or you could try to use a headphone to rca adapter from a cd player/phone to test it directly.
Feb 21, 2013 | Klipsch Audio Players & Recorders
How can I connect my bose lifestyle 12 series2 system to a yamaha receiver model rx-v3000
you will need to go to your local electrical store which will provide a box which you plug your speakers cable into and it will allow you to plug the box into the receiver using the Digital Left and right Audio cables.
Jul 18, 2010 | Bose Lifestyle 12 System
I have a rca no rtd250 impedance 12 ohms subwoofer. how do i connect it to my yamaha htr 5940.do i need a special cabel where do i get it.
Jan 14, 2010 | Yamaha HTR-5940 Receiver
Bought a Yamaha HTR-6130 doesnt sound good with my Bose. Not enough bass
Have u tried to run the setup / installation, to detect if your speaker system, have or not, subwoofer / size of speakers, etc... or run the manual setup or change the configuration of the bass. -10db + 10db
Jul 26, 2009 | Yamaha HTR-6130 Receiver
Want to connect my RCA sub to my yamaha htr-5940 reciever
Subwoofer needs to be enabled through menu on Yamaha. LINE OUT might be turned off or Subwoofer volume set to low or off... (-db level) kinda thing...speaker wires are usually always live etc...
Feb 03, 2009 | Yamaha HTR-5940 Receiver
Turns on then off.
It probably needs a set of output transistors, 2 pre-amp transistors and a 5.6v zener diode. Possibly a resistor or two. I've fixed many of these. Definitely a job for a pro.
John W
Jul 22, 2008 | Yamaha HTR-5940 Receiver
Yamaha HTR-5940 turns off after one second.
HI my Yamaha is working fine exept input selector , I selilng it for parts 45 , amp working fine exept inputs ( one milti channel in works fine) korrado6@hotmail.com
Jun 21, 2008 | Yamaha HTR-5940 Receiver
 Grubhead
Grubhead
