Question about Ricoh Office Equipment & Supplies
How to clear fusing unit setting error on a ricoh mp 5001
  • 86 Answers
SOURCE: Ricoh Aficio MP 2510 SC 541, SC 542 Errors
To clear level A SC codes such as this SC541, you need to
Enter SP mode, and then turn the main power switch off and on, only.
Please check if the thermistors are the proper ones and are installed correctly in their position properly.
This is also useful for SC542.
Please check the thermostats and fusing lamps for open circuit.
Good luck and please rate me, thanks.
Posted on Jan 17, 2009
  • 393 Answers
SOURCE: purchased new fusing unit for ricoh cl3500n;
You need to enter service mode, (this really should be done by a ricoh tech) Turn off printer press and hold down online and escape and turn printer on, the panel should sho a 1 2 3, push 2 for engine and enter press 7 and enter 804 is the counters for supplies. #4 is the fuser press enter after the printer says execute. Back out with escape and 3 to exit, cycle power. -Carl
Posted on Jul 08, 2009
  • 903 Answers
SOURCE: Getting error: set fusing unit correctly on Ricoh
Take the unit out and install it again, making sure it is in all the way and sitting correctly. Then reset the machine and see if the error goes away.
Posted on Jun 05, 2010
  • 393 Answers
SOURCE: Problem with the Ricoh mp c2800 Ricoh error code
If the model ia a MPC 2800 it a controller board issue maybe the operation panel. -carl
Posted on Nov 15, 2010
santosj27
  • 263 Answers
SOURCE: SC550 Error. Ricoh MP
That error code refers to the FUSING WEB END.
First of all you must see if the fusing web is end.
If the error occurs before the web ended you have to upgrade your firmware. There is a release firmware that corrects this symptom.
Posted on Feb 23, 2011
How to reset RICOH Aficio MP c2051 to factory settings?
never do a factory reset . will wipe out all the settings so now color is off paper feed setting will be off and optics and laser unit. there are a couple of settings that you can do 5-846-50 clears hard drive of address book. 5-801-11clears network card 5-801-14 clears DCS settings and 5-801-15 clears ucs settings.
Apr 02, 2017 | Ricoh Office Equipment & Supplies
Web Replacement error in ricoh mp 9001.
Clear modes(yellow) 1 0 7 hold clear/stop for 5 seconds, and reset the web counter. -Carl
Mar 06, 2015 | Ricoh Aficio Office Equipment & Supplies
Error cs548 in ricoh mp c4500
SC548
Fusing unit rotation error
The fusing belt sensor does not detect change in the actuator for 0.5
seconds after the fusing/paper exit motor has turned on.
* Defective fusing/paper exit motor
* Deformed actuator for the fusing belt sensor
* Defective fusing belt sensor
* Broken connection between IH inverter and IOB
* Incorrectly set fusing unit
1. Check if the fusing unit is correctly set.
2. Check or replace the actuator for fusing belt sensor.
3. Replace the fusing belt sensor.
4. Replace the IH inverter.
5. Check the connection between IH inverter and IOB.
Jul 14, 2014 | Gestetner DSm645 Digital Imaging System
SC550 Error. Ricoh MP 6500. Cleared Parts Exceding Target list. Reset 1902-001 on Copy SP. Still get SC 550 after power-up. ...Red "alert" light on, and red light on near "printer"...
Feb 23, 2011 | Ricoh Aficio MP 161 Black and White Copier
Jan 17, 2009 | Ricoh Office Equipment & Supplies
Ricoh MP 2510
Fuser installation error. Fusing unit set error. Remove the fusing unit out of the machine and reinsert it. It isn't seated in there properly. Once you do that the error code will go away.
Sep 15, 2008 | Ricoh FT5832 Copier
51 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
