Question about Dometic Rooftop RV Air Conditioner
My duo therm brisk air roof mount ac unit is blowing warm air, the amp draw on both the run and start lines is 3 amps, the compressor is hot, the condensor is not warm, the voltage across the run to common on the compressor is 120 vac and the voltage across the start-common is 300 vac. It appears there is an oily substance on one of the lines, perhaps the freon has leaked out.
    Sergeant:
  • 340 Answers
Yep have the leak fixed and properly charged.
Posted on Jun 19, 2009
Why am I not getting power to ac capacitor?
A thermostat or a relay activated by the thermostat turns power on to the capacitor for the compressor.
May 03, 2015 | Dometic 459196 Duo-Therm Brisk Air...
I HAVE DOMETIC DUO-THERM PENGUIN ROOF AIR CONDITIONING ON RV. THE UNIT WILL RUN WHEN PLUGGED INTO ELECTRICITY BUT WHEN GENERATOR POWERED THE AC UNIT KILLS THE GENERATOR ENGINE. WHAT COULD IT BE?
What size & type generator? On start up the AC unit can draw as much as 17-18 amps in some cases, and if your generator is not designed for a quick draw like that it will die.
Jan 25, 2013 | Dometic Rooftop RV Air Conditioner
Duo therm 15000 heat pump on ac starts blowing cold short while later warm.
A little more info would help. When you say blows cold and then warm after a while, can you still here the compressor running? There are a couple of things that could cause this: 1. Check how much current the compressor is drawing. You will need an ammeter for this but it's necessary. From inside, if you have a penguin (low profile, 9" tall) hook the ammeter to the black wire in the harness. If you have the BriskAir then hook it to the blue wire. Start the A/C and watch the meter. The exact reading is temperature dependent but should be about 12 amps or so, this includes the motor. There is a rating plate visible from the air return that gives the exact amp draw for each unit. This is at 95 degrees F on the roof. For every 10 degrees over, add one amp, for every 10 degrees below, subtract one amp. If the reading is more than what it should be, most likely the coils (both evaporator and condenser) need to be cleaned. If there is too high an amp draw for a certain period, the compressor overload will shut it off but the fan will continue to run. Too low would be low freon most of the time.
2. There could be an issue with the reversing valve.
Give me a model number and I can give you more information.
Sep 30, 2011 | Dometic Rooftop RV Air Conditioner
Duo therm brisk air ,does not blow cold air fan works but when condenser trys to turn on it draws 76 amps please help
You don't say what size unit you have. Does it draw 76 amps and then go to about 10 or 12 and you can hear the compressor running or does it draw 76 amps and the breaker trips. I suspect it draws 76 amps until the breaker trips. Confirm that the capacitor is niether shorted nor open. It may be worth your time to replace the capacitor, if you have one of the correct size available. If this does not get your unit running, it sounds like you are drawing Locked Rotor Amps, which means your compressor has physically siezed. There are a couple other posibilities, but looks like its time for a professional.
Jul 20, 2010 | Heating & Cooling
AC compressor won't start
hi,you might need a new compressor...you will need need to go back were you bought capacitor...buy a hard start capacitor too..this might crank the compressor...hope this helps.if you buy it..call an ill tell you how to wire it...if it dont ,you need new compressor...call michael..doctor airr..appl.repair...843-384-8474...
Mar 27, 2010 | Dometic Rooftop RV Air Conditioner
Duo-therm brisk air AC unit leaks water into my RV when it rains
take the cover off and make sure the drain line is clear on top off RV.
Nov 15, 2009 | Ovens
I have a duo therm brisk air model 57915-001 leak
Could be the drain path is clogged.. Take the cover off & see if you can get it cleaned..
Jul 09, 2009 | Dometic Rooftop RV Air Conditioner
Dometec Briskair Duo-Therm Compressor won't quit running
Have you taken return air filter grille down at ceiling assy, & cleaned filter with dish soap & warm water? Check & see if you see little probe sticking out in behind there, and wipe it carefully as well, and make sure it's lined up to sense air flowing through there. Take a flashlight & look up into coils at front for lots of dust on them as well. Perhaps a thorough cleaning of all coils is in order if you say there's lots of dust, as choking airflow off with dust & dirt, will only shorten life of unit & use more hydro than necessary.
Jul 07, 2009 | Heating & Cooling
Duo-Therm Brisk Air Model 59516.601 Ducted Roof Air w/wall thermostat
First of all, I think you mean 110 volts on your meter, not amps, just so we're on the same page. It sounds to me like you may have a capacitor problem on your compressor. I'll try to see if I can find you a part # if you have someone very experienced with electrical that can change it for you. they can be a little dangerous, so only someone familar with them should work with it. What the capacitor basically does is store voltage and uses it to help the big draw on start-up of the compressor, kind of like giving it a boost to get it started, and after it's up and running, all should be well if everything else is up to snuff. How old is the AC unit? Did it run well for you in the past? I'm asking this just in case it was a recent installation, with perhaps wrong size wire used. Should be minimum 12/2 , with 20amp breaker,if that means anything to you, or your mechanic.
Aug 15, 2008 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
1,181 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
