Question about Xact Communication XTR1 SIRIUS Radio Receiver
Xtr3 wont come on
Won't start won't turn over or do nothing put new battery still wont turn over wont start
No one can help you much if they do not know what year etc. your bike is. WHAT DTCs are set??
May 04, 2014 | Harley Davidson FLHX Street Glide...
My automatic windows wont roll down
Click the link below to troubleshoot the problem:--
Power windows not operating?http://whoisbyme.blogspot.in/2012/05/car-window.html
Thanks.
Jun 07, 2012 | Spyder 03-05 Chevy Silverado Vertical...
I have older 15
If the speakers measure zero ohms, then the coil is shot. A speaker will not work if it has zero ohms. Replace the speaker. ALL speakers should read 4ohm, 8ohm or above. Zero means the coil wire is shoted. That there is no continuity.
Mar 31, 2010 | Orion Xtreme XTR15 Car Speaker
Sputtering then stopped running and wont turn over.
Wont turn over are you sure as wont start is differant than wont run
Wont start could be Battery/starter/or engine siezed.
Wont run is not the same,,, that could be lacking power /low on oil/water/ Fuel/or even engine lacking power like down on compression which is all the above plus more ....
So check it out let us know again. Ron
Jun 29, 2009 | 1986 Honda Accord
Satellite radio
I have several 'ghettoblasters' that fit this unit if interested --- Frank
Jul 14, 2008 | Xact Communication XTR1 SIRIUS Radio...
CANNOT READ ANTENNA
I had a similar type problem where i have a lifetime subscription and my XACT VISOR XTR3 unit had a faulty power connection that was driving me nuts. i decided to try and swap out the internal receiver component with a new unactivated unit i bought on ebay. (all the types are out there and pretty cheap even for new)
in opening the new one up i found the only difference from unit to unit is the receiver brain inside the unit, and it is relatively easy to swap out the brain into the body of a new unactivated unit. just four small screws and carefully pull the brain out of the long multi-pin connector. i put the old brain into the new carcass, screwed it back together and it works like a champ. just have some patience in figuring out exactly how your particular unit comes apart, and you will need small screwdrivers and either a small allen-key set or torx set - my old unit had the allen-key screws on the outer case and the newer one had torx screws.
Aug 10, 2006 | Xact Communication XTR1 SIRIUS Radio...
Xact Communication XTR1 SIRIUS Radio Receiver Logo
59 people viewed this question
Top Xact Communication Audio Players & Recorders Experts
John
John
Paul Norman
Level 1 Expert
miles
miles
Are you a Xact Communication Audio Player and Recorder Expert? Answer questions, earn points and help others
