Question about Dynex DX-LCD32-09 LCD TV
No Video but have Audio
I have a Dynex flat screen. There is a cabel box and a DVD player plugged into it. When I turn it on, the black screen gets slightly brighter, as if there was a signal getting to it. I see the words "Please Wait" briefly display on the screen and then the screen goes completely black as if the TV was shut off. I can hear the audio, change channels and hear audio from them but no video.
Your inverter board is probably bad
Posted on Aug 18, 2009
  • 3 Answers
I found my product manual and called the Tech Support line. They said it was a problem with the display and would have to schedule and appointment to fix it.
Posted on Jun 21, 2009
Testimonial: "That's what I ended up doing. Luckily it was still under warranty and I was able to get them to swap the screen for free. "
No sound on tv
Do you have the old cable box? If so plug it in, or better yet, did the old cable box connect to the TV the same way the new one does. Did you just upgrade to HD?
Or if you have a DVD player or something to get a signal to the TV as a test, will eliminate the TV as the problem. It might even be an adjustment in the settings to allow audio to go down the HDMI cable. Some boxes its switchable.
Aug 17, 2014 | Dynex 32 in. LCD Flat-Panel HDTV
Dynex 32" 720p Flat-Panel LCD HDTV - Matte Black Logo Print Email Problem with Dynex 32" 720p Flat-Panel LCD HDTV - Matte Black I have a Dynex Bluray Player and when I connect it with AV Cab
If the item is under warranty return it asp. The problem is in the power supply, the cause is a open capacitor sometimes leaving a bulge at the top.
Apr 25, 2012 | Olympus Televison & Video
We are trying to hook up a samsung flat screen TV, a sony home theater system, direct tv box, and a panasonic DVD to the dynex component video converter box. Which cable goes where
We can't make assumptions. Did you set it up in accordance with the manuals?
Without specific details...
In general, ins go to outs; compatible connectors need no modification.
If you have an HDTV and HD Satellite I don't think you want to be tying the video quality down to S-Video.
There are two signals to consider here. Video and Audio. TV's are expert at Video and A/V Receivers are expert at Audio, so each should get first crack at the specialty for which it is designed.
HDMI or Component Video (Red, Green and Blue RCA cables) are the best and ONLY ways you'll get Hi Def to the TV. If you route EACH HIGH DEF SOURCE'S VIDEO DIRECTLY to the TV (instead of through the receiver or a switch) the TV/monitor will receive the best video digital data.
Digital Audio from as close to the real source as possible (SAT Box, maybe) to the receiver.
Standard analog audio from the SAT box to the TV for watching lo-fi content like news and weather without the Sony HTS turned on.
Mar 15, 2011 | Dynex S-Video A/V Selector Switch
Dynex dx-32l151a11 the picture is black and white with the dvd player
With a Black and White picture it sounds like you're trying to connect the DVD Player's "Composite" connection to the TV's Component Connection.
Composite is a 3 wire system with Yellow for the video, and red and white for the audio. On your TV this connection is located on the side.
Component is a 5 wire system, with Blue, Green & Red for Video, and Red and White for audio. On your TV this connection type is located on the rear panel.
Check to make sure you are hooking the DVD player & the TV to the same input types.
Dec 26, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
I have a memorex dvd player and a dynex 32" lcd hdtv. I have all the cord correctly in the component plugs but the picture is black and white and there is no sound.
HI,
i think ur component video connection may inter changed. check it. are u connected red to red, green to green an blue to blue. if interchanged the picture will be black and white. also check the video system of ur tv and dvd.
about audio. for that u need a stereo rca chord. connect the audio output of ur dvd to the component audio input of ur tv. if u have already connected the audio cable , check the audio setup of ur dvd. there is selection for pcm audio select it and then check again.
ok
Dec 15, 2010 | Dynex 19 in. LCD Flat-Panel HDTV
I am having trouble making connections from my Dynex tv to a cable box, wii, and dvd player. I have the manual and still confused
Connecting this up will be easy. What you do is get a yourself a set of the right, for your setup, cables. That uses EITHER one of the formats, of these described, below. You will need, either, a THREE way Cable, or three separate " Coaxial Cored" Cables with RCA PLUGS on them. ColoredYellow, (Video) Red, & White. (Audio) AV. OR If you have SCARTConnection Sockets, it's a big Black Socket at rear of unit(s), you get aSCART Cable.& It's all inside. Now some units, use a standard calledComponent Video, that uses, a Green, Red, & Blue Plugs. Now, with the Component setup, you will also ,need, Two more Cables, for the AV Audio. these are, Red & White.(So with Component Video there are 5 Cables/Plugs in all). In any event ALL Cables go Color to Color, at each end, plugging into the corresponding Colored RCA Jacks, on either machine, or VCR or TV. Now if you have SCART, then it simply plugs in only one way. It is that simple. So connect up with the leads your set uses, and select the correct "Input" from TV/Remote, it is NOT on a "Channel" it will be on AV, AUX, and Press "Play" on VCR/DVD whatever.... should be all go.
Feb 16, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
Problems hooking up dvd player to Dynex 22"
MY PROBLEM IS THAT WHEN I HOOKED UP MY DVD PLAYER (PANASONIC) THE MOVIES COME OUT IN BLACK AND WHITE. WHY IS THAT. PLEASE ADVISE
Mar 09, 2009 | Dynex 19 in. LCD Flat-Panel HDTV
Unable to separate VCR playback from Sat. Receiver input,both av2
try to find a multi-video selector swicth that the best you can do
Dec 19, 2008 | Dynex DXR24TV 24" TV
How do i connect my dvd player to my dish cabel box
what conection do you want? Adio/Video? Conect to amplifier? Conection to tv... Look the word Video out from dvd and put it on Video input of your tv same proceedure of the audio.
Apr 13, 2008 | Cyberhome CH-DVD 300 DVD Player
Dynex DX-LCD32-09 LCD TV Logo
707 people viewed this question
Top Dynex Televison & Video Experts
Jaime Hernandez
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
