Question about Scotsman MDT5N40W-1J Touchfree Water Cooled 525 Lb Ice Maker/Dispenser
Scotsman MDT5N40W-1H I was told it has high head pressure. how do I fix it
    Novelist:
    Champion:
  • Scotsman Expert
  • 373 Answers
First you need to find out what is causing the high head presser. First check the filters make sure there clean. Next check the condenser coil to make sure it is not dirty. Next check the condenser fan to make sure it is not dropping out. if this is all good then you will have to look for a internal restriction rather it is a stopped up dryer to a bad TXV valve. this should be done by a refrigeration mechanic.
Posted on Jul 17, 2014
Water dispenser takes a long time to shut off.
Sounds like the water valve needs to be replaced. If you move your cup and it continues to pour out water valve is, leaking through
May 27, 2015 | Scotsman MDT5N40W-1J Touchfree Water...
Scotsman ice maker SCE170-1H NEED WIRING DIAGRAM
GO to Google, type in SCE170-1H Service Manual. When sites come uo look for the heading SCE170 Service parts-Scotsman ice Systems, click on that one it is a pdf go to page 9.
Sep 05, 2014 | Kitchen Appliances - Others
Manual for scotsman MDT5N25A-1H
WWW.scotsman-ice.com/service-support/service-library/
on line manual pdf
Jul 15, 2014 | Scotsman Kitchen Appliances - Others
Scottsman cu2026
does the water overflow?,, if its not pumping, its not being told to pump by level indicator or the pump is bad(common issue)
Apr 07, 2014 | Scotsman Ice Machine - 290lb...
Water dispenser will not shut off
Touch Free Sensors Part number 12-2495-21
Feb 26, 2014 | Scotsman MDT5N40W-1J Touchfree Water...
Scotsman sce275a-1h
Replace the din full sensors this will let the ice machine start up if the sump tray dose not start to fill up with water look at board to see if water full light is on if so replace water sensor that is in water sump tray. if light is not on then check to see if you are getting power to water valve if you are getting voltage to valve then check water filter dose it need to be replaced. now never use any thing other than ice machine cleaner made for ice machines it has to be nickle safe are you will dammage the evaporator plate.
Jan 23, 2014 | Scotsman Ice Machine - 290lb...
Scotsman sce275 making ice too thick
carefully adjust the ice bridge thickness screw at the top no more than 1/8 of a turn counterclockwise in between freeze cycle until desired thickness is obtained. clockwise gets thicker and counterclockwise thinner.
Apr 12, 2013 | Scotsman Ice Machine - 290lb...
Mv450 scotsman high pressure
Check to make sure the condenser coil is clean, fan motor is running during freeze cycle. High Ambient temp, Ventilation, The higher the temperature entering the condenser coil the higher the head pressure. Fan motor failure, pressure switch failure. The cut out pressure varies 400, 450 or 500 PSIG. Water supply failure. not enough water running over the evaporator plate will cause high presser.
Jul 30, 2012 | Scotsman Cooled Modular Contour Cuber Air...
Hello, I am a Certified Athletic Trainer at a high school. I back mid summer break and found that someone had turned off and emptied the ice machine. I can't find my manual; is there anything I...
Download this manual. On pages 20&21 are cleaning instructions. Also install a water filter.
http://www.scotsman-ice.com/docs/uploaded/sct/manual/275m.pdf
Jul 12, 2011 | Scotsman Ice Machine - 290lb...
Scotsman has become very slow in making ice
I would try cleaning the unit, plus if there is a inline water filter I would replace it
May 23, 2010 | Scotsman Ice Machine - 290lb...
Scotsman MDT5N40W-1J Touchfree Water Cooled 525 Lb Ice Maker/Dispenser Logo
55 people viewed this question
Top Scotsman Kitchen Appliances - Others Experts
John Tripp
John Tripp
Tim Whalen
Beto Flores
Beto Flores
Are you a Scotsman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
