Question about Kenmore 24032\24036 Top Load Washer
Safty switch is broken, how do I get top off sears 110 washer
I can pry top up a bit and see what looks like plastic tabs holding top on left and right of machine. I am afraid to pry too hard. Any thoughts?
  • 111 Answers
Two screws in the back of control panel or the sides of control panel pop off and you see two screws on the front
Posted on Jun 19, 2009
My Kenmore 22422 Top Load Washer (bought around 2001) won't spin properly. It agitates fine on wash cycles, but the clothing comes out dripping wet after spin cycle. I have opened the lid and watched it,...
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump
removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (110.#######) and you'll see a list of major sub-components with diagrams and parts.
Two possibilities: since it will spin. None of the suggestions are very expensive.
Kenmore / Whirlpool top load, direct drive washers use a "Motor Coupler" between the motor and transmission.
It's used as a fail safe device and consists of three parts.
Two of the parts are the same, plastic units with three prongs that fit on one of the motor output shafts and the other on the
transmission input shaft. Between them is a rubber piece with six holes.
The power from the motor is transmitted through the rubber piece to the transmission.
The other shaft on the motor directly drives the pump.
If the motor coupler is broken, or worn, the motor may not be able to send full power to the transmission for agitating or
spinning.
See the following for how to remove the cabinet, pump, motor and motor mounting plate to inspect and replace the motor coupler.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=135
If the coupler looks damaged, it's a relatively easy fix.
Pry the plastic pieces from the motor and transmission. Some people use a claw hammer but I've found that using a small (6 inch) pry bar works well.
Carefully fit the plastic pieces over the motor and transmission shafts and press them in place (Use a 1/2" of larger socket to put pressure equally around the pieces.
Put the rubber piece on the transmission plastic piece.
Replace the motor mounting plate.
Carefully line up the plastic prongs on the motor based plastic piece to the three un-used holes in the rubber piece. If they don't line up right, the coupler could be damaged.
Mount the motor, don't forget the two screws, put the pump back on the motor and use its' clips.
Put the cabinet back on, don't forget to plug the lid switch back in and re-mount the console.
If the motor coupler is OK, the problem could be the clutch:
Sears has a replacement clutch band kit.
See the following for how to pull the pump, motor and transmission.
You DON'T HAVE TO PULL THE AGITATORS OR TUB.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137&osCsid=65fc1c013d6130868b14c8bb4baf7bfd
Also see the Whirlpool / kenmore service manual for these washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Both the Motor coupler (available from most appliance parts stores) and the clutch band kit are relatively inexpensive.
See the Following Whirlpool parts list for alternatives to the Sears part numbers.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
Feb 08, 2011 | Kenmore 22422 Top Load Washer
My Sears Kenmore Heavy Duty Plus Washing Machine Model 110 - 16512690 fills with water, evacuates water, but will not spin or agitate even though the switch at the top is pressed down.
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Washer-Parts/Model-11016512690/0582/0153200?pathTaken=
Two of the parts are the same, plastic units with three prongs that fit on one of the motor output shafts and the other on the transmission input shaft. Between them is a rubber piece with six holes.
The other shaft on the motor directly drives the pump. This is likely why the machine drains.
If the motor coupler is broken, or worn, the motor may not be able to send full power to the transmission for agitating or spinning.
Dec 07, 2010 | Kenmore Washing Machines
I have an older, but in good condition, Kenmorre 80 series top loader washing machine. The spinning won't move or when it starts washing, the arm in the middle doesn't spin the clothes around. Would it...
The Sears series numbers (70, 80, 90) only mean how many "bells and whistles" a washer has. The most important thing is the full model number. Usually a number starting with 110.########.
Most models don't use belts anymore but use a Motor coupler.
Enter your model number (110.######) and you'll see a list of major sub-components with diagrams and parts.
Look in the section for the motor, pump gearcase and you'll see the Motor Coupler.
damaged.
Nov 21, 2010 | Kenmore Washing Machines
How to remove and replace clutch on kenmore washer 110. series direct drive
Before assuming that the problem is the clutch, I'd check the Motor Coupler first.
Nov 18, 2010 | Kenmore 16812 Washer
Agitator doesnot move, water will go into washer, agitator doesnot spin and water will not go out of washer. can this be repaired? Do I need to replace the washer?
Two possibilities:
Newer model Whirlpool / Kenmore washers use a Lid Switch as a safety device. Unless the switch senses that the lid on the washer is closed, the washer will neither agitate nor spin.
Older models only used the switch during the spin cycle.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part.
If the washer still doesn't work, check the motor coupler.
spinning.
If this is a basic top load, direct drive washer, luckily most mechanical parts are relatively easy to access and fix or replace. I'd hold off looking for a new washer until I checked the Lid Switch and Coupler. These are the two parts that tend to break on top load washers.
Aug 22, 2010 | Kenmore 24622 Top Load Washer
My kenmore 90 series model 110 will not spin,
Four possibilities: (Ranging from easiest to messiest)
spinning.
If you've tested the Lid Switch and the Motor Coupler is fine, and the clutch bands and springs are OK the problem could well be the transmission. "Neutral Drain Assembly".
See the Whirlpool / Kenmore Service manual for transmission operations on top load direct drive washers.
WHIRLPOOL TRANSMISSION DESCRIPTION AND SPRINGS
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/2550f737b3129b0c85256b0600504738/$FILE/787772%20%234.pdf
Those cams/gears etc. in that assembly keep the washer from spinning until all of the water is pumped out and then go into spin mode.
When ours had a similar problem, we looked at the transmission parts list (available on a number of sites) and on the Whirlpool site (Whirlpool makes Kenmore) and noticed that the one of the cams in the neutral assembly which is supposed to have a small spring, didn't on ours when we tore the transmission apart again
Found the part number for a kit (Whirlpool part number 388253 Neutral Assembly) for $15.00 and replaced the cams and gears.
In order to get the transmission out, you have to remove the cabinet, the fabric dispenser and both agitators. The top agitator uses a plastic 1/2" drive bolt (a 1/2" socket extension works well).
You don't have to remove the drum.
Lay the machine down (after disconnecting power and hoses, remove the pump (two clips), the motor (two screws hold two clips on the motor), lift and set the motor aside.
Remove two 1/2 inch bolts for the motor mounting plate and three 1/2 inch bolts for the transmission.
Pull the transmission, remove the clutch (there is a spring clip that holds the clutch on the main agitator shaft), remove the 8 screws carefully the transmission holds 14 - 15Oz of oil, remove the clip holding the main spin gear on and check the plastic cams.
If the cam that should have a spring doesn't, or the others look damaged, or the main spin gear is damaged the washer won't go into spin mode.
If that's the problem, install a Neutral drain kit, put everything back together carefully and the problem may be solved.
As an aside, fixing ours cost less than $30 including 80-90 weight gear oil vs. $170 for a new transmission.
May 15, 2010 | Kenmore 24032\24036 Top Load Washer
Stopped in mid-rinse cycle, whines
110.21082000 OR 110.21082001 (Sears requires 8 digits after the 110.
May 02, 2010 | Kenmore 22422 Top Load Washer
Slow agitator in Sears Kenmore 800 Series washing machine
The other shaft on the motor directly drives the pump. .
Jan 19, 2010 | Kenmore 15864/15862 Top Load Washer
I have a Kenmore Elite model # 110 26962500 that fills with water but will not agitate unless you slam the lid down or hit the lid with your hand very hard. It seems to be the lid switch but I do not want...
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.26962500+
Getting to the Lid Switch on these machines is about a 5 minute job.
First, unplug the machine.
Looking at the Sears diagram for the console, you'll see that underneath the corners of the console are two clips. Using a thin putty knife, push on these clips from the front and the entire console should tilt backward.
Looking at the diagram for the cabinet, you'll see the lid switch.
Although most top load / direct drive Whirlpool / Kenmore washers only use the lid switch during the spin mode, yours may be a bit different.
See the following Whirlpool service manual for the top load direct drive washers.
Usually, the problem with these washers not agitating points to the Motor Coupler.
Since you already have the console tilted back, it's another 5 minutes to pull the cabinet off and check the coupler.
See the following.
If the coupler is worn or damaged, replacing it takes about 10 minutes .
Kenmore / Whirlpool top load, direct drive washers use a "Motor Coupler" between the motor and transmission. It's used as a fail safe device and consists of three parts. Two of the parts are the same, plastic units with three prongs that fit on one of the motor output shafts and the other on the transmission input shaft. Between them is a rubber piece with six holes. The power from the motor is transmitted through the rubber piece to the transmission.
If the motor coupler is broken, or worn, the motor may not be able to send full power to the transmission for agitating or spinning. Hitting the cabinet may allow the coupler to grab and transmit power.
Oct 26, 2009 | Kenmore Washing Machines
Washer motor running but not agitating.it happened before and i change some kind of round rubber with plastic that have 3 tab in it.i just cant remember how did i do that to replace it or where did i take...
See the section on the Motor.
Oct 20, 2009 | Kenmore Washing Machines
Kenmore 24032\24036 Top Load Washer Logo
51 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
