Question about Honeywell Programmable Thermostat Heater
I was trying to adjust my thermostat and it wasn't working right so I took the batteries out and now nothing will come up on the display screen, what do I do?
  • 4 Answers
If your batteries are good and you put them back the way it is suppose to, Check the battery terminals in the termostat there is a chance that they are not making contact with the batteries. If that is the case bend the terminals with a small tip screwdriver.
Posted on Jun 20, 2009
Blank Screen
Remove and install new batteries, if displays reprogram. if no display replace thermostat
How To Install Programmable Thermostat The Home Depot
Jan 20, 2016 | Televison & Video
We just moved into a condo, built in 1997, with a manual thermostat. we turned the unit on and it wasn't blowing cool air...took the cover off the thermostat and it seems as though the tubes with...
If the unit comes on when you turn set the thermostat below the room temperature, then there is nothing wrong with the thermostat. Since you said the unit was not blowing cool air, the problem lies in the condensing unit. Either not running for various reasons or refrigerant level is very low.
Sep 01, 2011 | Heating & Cooling
Honeywell th8110u1003 touch screen frozen working but cant adjust at all
It sounds "locked". Refer to the installation/setup manual that came with the tstat for information on how to lock and unlock the thermostat.
Apr 06, 2010 | Honeywell Programmable Thermostat Heater
My honeywell theromstat keeps displaying repl bat
Have you checked to make sure the batteries are, in fact, good and that they are facing the right way? If so, it's time for a new thermostat.
Oct 03, 2009 | Honeywell Programmable Thermostat Heater
Screen frozen TH8320U1016 honeywell
I got mine to work! Mine is the th8110u1003 and although the screen seemed to display, it was completely unresponsive to touch. Long story short, there is a flat watch battery behind the screen. Get to that and remove it for 15 seconds and reassemble. It powered right back up!
Jun 29, 2009 | Honeywell Programmable Thermostat Heater
No display on the Dell Dem 520
IT SOUNDS LIKE HARD-DRIVE FAILURE, TRY REINSTALLING THE OPERATING SYSTEM, BUT IF IT DOES NOTHING THEN REPLACE THE DRIVE
Jun 16, 2009 | Dell Dimension E520 PC Desktop
Honeywell ST6400C with no display
I pressed the reset button in error and the display just would not return o no heating or hot water. Nothing tripped on the board and all wires and the unit itself showed power coming through.I got it working again by sheer determination.
What I did
I took the unit from the base plate and opened the front panel to see circuit board. It has 4 clips and it all goes back together easily.
What I did.Time taken 15 minutes.
The tiny rubber reset button was collapsed, perhaps maintaining the 'off' situation.
I moved a tiny wire from touching the side of the battery.Perhaps not important but it didnt look right.
When i remounted the unit it lit up beautifully.
So the solution lies in 1 or all of these 3.
If it happens again I will try
1. simply remove the unit from its base plate and remount to see if that is all it takes.
2. Open the front and check the reset button isnt collapsed and stuck.
3. Just move that little wire from leaning against the battery -(least sure of why this might help)
hope this might help someone else
Catherine - a determined blonde lady
Nov 14, 2008 | Honeywell Programmable Thermostat Heater
Model ct3600 thermostat not working
I know it sounds simple but the batteries are probably in the wrong direction. If they are correctly installed and fresh you will usually get a display.
Nov 01, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
91 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
