Question about Samsung HCN653W 65" Rear Projection Television
Picture bowed and looks 3d - Samsung HCN653W 65" Rear Projection Television
  • Samsung Master
  • 8,617 Answers
Convergence amp IC failure. Replace the two ICs and check the 3.9 ohm feed resistors
Posted on Jun 19, 2009
52inch projection screen television has only red and green colors and its difficult to see the picture.
If the picture looks 3d with lines bowed it may be a convergence problem---go into the customer menu and call up convergence and at least look.
Aug 27, 2012 | Samsung PCJ522R 52" Rear Projection...
Picture looks like 3d i have ajusted screen but keeps going back to 3d and picture is bowed
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
•Screen looks 3D
•Colors don't line up
•One or more colors can't be adjusted when using the convergence menu.
•Screen is bowed or warped.
•TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems
fcabb43.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya - CLICK HERE
Aug 25, 2010 | RCA P56923BL 56" Rear Projection...
Sony 46 inch proj tv picture is bowed in the middle and color is
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 29, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
I have a scoop or 3d look how can i fix it
This is a very common failure on Projection sets. Its called a convergence problem.
You may have one or more of the following symptoms.
Screen looks 3D
No Audio / No Video - Makes Chirping Sounds
Sep 26, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
3d picture and looks like bow tie
Bad STK ICs replace both ICs will have part number on them STK392-110s if this is what you have upgrade to 150s! ICs are Big black ICs also ck 2.7 ohm resistors near ics.
Sep 16, 2009 | Samsung HCM4215W 42" Rear Projection...
Could use some help with a "bowed" picture on my RCA P52960
Is the convcergence ( Alignment) also off which gives the TV a 3D look around items on the screen? If so replace the STK730-130 on the convergence power supply
Jun 23, 2009 | RCA P52960 52" Rear Projection Television
3D picture with bowing effects
model number is located on bottom rear cover, your convergence circuit has failed but without model nobody can give you further info, re-post and we`ll try to help, video-tek
May 28, 2009 | Televison & Video
Picture is all distorted ,colors dont match up need 3d glasses to watch
HI, this is basic convergence failure. the convergence board controls the RGB stream and , if its malfunctioning or, the convergence chip set is damaged, it will distort the entire display and the colors will not be regulated correctly as you are experiencing at this time.
simply replacing the convergence board in this unit will fix your issue.
May 18, 2009 | RCA Televison & Video
Bow tie looking picture with 3d color mis-alignment
you have lost convergence. First thing to check is to see if you are missing the convergence option in the customer setup menu. if you do not have this option then i suggest reading the article in the tips and tricks section entiltled "the fl231 fuse problem" this is a common and sometime easy repair if you do have it then you might need a convergence power board
Mar 09, 2009 | RCA R52WH73 Projection Television
Looks 3D
I had a repairman replace the convergence boards. The picture is fine now however red & green colors are messed up.
Nov 11, 2008 | Samsung HCN653W 65" Rear Projection...
Samsung HCN653W 65" Rear Projection Television Logo
250 people viewed this question
Jerry Greenberg
Jerry Greenberg
