Question about Vehicle Parts & Accessories
How to adjust distributor timing on a 280e mercedes 1984 model
    Problem Solver:
  • 9 Answers
Locate distributor,look at where dis. goes into engine block, should be a horseshoe type clamp holding the dis. shaft in place, loosen bolt til dis moves, start engine, with timing light pointed at timing mark on front of engine, turn dis. slightly to increase timing up or down, when in right spot, turn off engine,tighten bolt, put a mark on base of dis. n engine block to check in future, to see if dis. moves.
Posted on Dec 14, 2014
Car drives for a mile then stops 1984 mercedes 280se
you didn't say if you replaced/cleaned distributor cap might be worth a look and also spraying inside the cap with wd40
Aug 11, 2014 | Mercedes-Benz Norev Mercedes Benz 280 Se...
Mercedes service manuals
a mercedes benz is correctly tuned checked maintenanced and timed using star tech info. system prechecks performed, using test equipment are performed first. identification of the vehicles parts and numbers is required. this leads to a series of steps outlined in star tech info. to find a link to their website, ask on benzworld where many of these enthusiasts communicate and share their findings.
best advice
Apr 17, 2014 | 1994 Mercedes-Benz E280
Oil consumption and black ezhaust mercedes 280e 1984,compressy ok,sometimes ONE bougie fouled.
Compressor is OK meaning your valves are still good. However the Valve- Stem seals need to be replaced. The seals have function to limit the lubricating oil amount the valve train. When they are worn out, too much of oil gets in to the valve area then get burnt out to the exhaust causing oil consumption. These valve can be replaced at a shop without taking the head off the engine. Although it sounds simple but not all the shop want to do this, since they want to take the head out to make more money. So check around until you find one. The work is to put air compressor at the spark plug location to hold a valve up so the valve-stem seal could be replaced from above. This will be repeated for every valve on the engine. Although not being an auto mechanic, I did on mine and fount it was at medium level of difficulty. Good luck.
Mar 14, 2010 | 1999 Mercedes-Benz E-Class
I have a e240 model 2000 it has 112 engine and is manual iwant to know where do you adjust the timing should i keep it on ot or on 40
hi,good day,,gear to gear contact with chain,,no distributor to adjust (rotate) no way to adjust the engine timing,,this model,only one teeth is jump,your engine maybe experience hard starting or engine shaking,,could be,adjustment of opening of fuel injector ,longer time or open in advance,,this scenario could be done with special tester (star diagnose),,ty
Dec 26, 2009 | 1999 Mercedes-Benz E-Class
1984 mercedes 190e, power steering belt tension?????
hi,try to adjust the belt tension, find 3 fastening loosen,with help of fri bar pull,then adjust the tension or replace with small diameter if possible,ty
Apr 09, 2009 | 1984 Mercedes-Benz 190
Need tune up routine settings for 1975 280e
hi,,fuel filter,air filter,plug,coolant, for common maintenance service,adjustment or setting is necessary if there is a problem,if not not adjust,or if you want ask your dealer,they have maintenance service sheet for all model,ty
Apr 04, 2009 | 1983 Mercedes-Benz 300-Class
Bad starting and missfiring
Adjust ignition timing. Standard should be 5 degrees BTDC. You could do this by slightly moving distributor cap clockwise or counter clockwise, depending on current state of timing. Do this with engine turned off to ensure no electrical charge skips towards you. There's an allen screw that you'll need to loosen. This tightens the position of the distributor to the base. Tighten after each slight movement of the distributor. Run the car and spot performance improvements or otherwise after each adjustment. A bosch tune up equipment could be used for this , but without that, you could do via manual method shared above. Otherwise, also check ignition wires for any frayed parts of if electrical charge given out by each is of same level.
Jul 16, 2008 | 1984 Mercedes-Benz 190
Vehicle Parts & Accessories Logo
49 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
