Question about Enkord JAM XM
Serial jam xm - Enkord JAM XM
Pwer cord port on xm radio vehicle cradle is loose. how can i fix it? is ther anything i can jam in there?
This is likely solder that is breaking loose. I would take this apart and take a look at it. If it is soldering a pretty easy fix, if you can solder.
Jan 26, 2013 | Delphi SKYFi SA50000 XM Radio Receiver
Changed battery in car and now XM radio does not work
Take the radio out and note the serial number, give that serial number to the dealer and they will give you a code to punch in to get the radio working.
Jan 11, 2013 | Honda Cars & Trucks
Xm radio not picking up signal only getting preview channel and channel 247
You need to contact XM and have them activate the signal. If you have a subscription you can sign on at www.xmradio.com . There are instructions on activating online or contacting XM. You will need the serial number on the XM chip for activation.
Please rate this solution. Thanks.
Nov 03, 2010 | 2006 Volkswagen Jetta
The radio on my 2010 Subaru WRX has A Sat button on the radio. How do I get an XM Tuner to activate this button?
Many/most of the original factory radios with the 'XM' button already have the tuner in them. While outside (not inside a garage or under trees) Press the "XM" button then see if you can get channel 1, or channel 247, or channel 0. Channel 1 is free previews, channel 247 is free weather, and Channel 0 is the serial number of the radio. IF you have these 3 channels then all you have to do is call 1-800-XM-RADIO with the serial number from channel zero. Leave the radio on channel 1 for 30 minutes after calling, and you should then be activated. Let me know if you have more questions.
Jul 17, 2010 | XM Radio XM Direct 2 Mini-Tuner Car Kit...
How do i refresh xm radio ?
Go to Channel 0 and get your serial number. Then, make sure you have a good signal, leave radio on Channel 1 for 1/2 hours after calling 1-800-XM-RADIO and ask they to refresh your radio. They will tell you how long to wait - okay?
Jun 17, 2010 | Delphi SKYFi XM Radio Receiver
Activating xm radio on 2005 fx35
there should be a radio code, like a serial number for your xm radio, maybe in your owner's manual. all you do is call xm with this code and have it activated.
Feb 17, 2010 | 2005 Infiniti FX35
How do I continue to get xm radio
lookup xm radio on line you can do it all threw there web site you will need to know the serial # for your radio when you go to turn it on.
Jun 03, 2009 | 2009 Hyundai Sonata
I bought a new xm radio to replace one that does not work. how do i switch to the new radio?
You have to call them and give them the XM number for the one you purchased.  Much like a cell phone provider uses the Electronic Serial Number to match your phone to the tower.
Mar 06, 2009 | XM Radio (XMP6000)
Xm not working
I had a short in my TERK antenna and it gave me the same problem.
If you know someone else using xm, you can try their antenna to see if that is.
I took mine to Best Buy and they had one they checked it with.
Best of Luck.
Oct 15, 2007 | Pioneer DEH-P3370XM CD Player
Video Game Consoles & Games Logo
15 people viewed this question
Top Enkord Video Game Consoles & Games Experts
James Wishart
Are you an Enkord Video Game Console and Game Expert? Answer questions, earn points and help others
