Question about Xerox Office Equipment & Supplies
RED LIGHT FLASHING XC1045
RED LIGHT FLASHING ON XEROX XC1045 COPIER. COPIER SEEMS TO BE LOCKED UP. NONE OF THE BUTTONS WORK. REPLACED TONER BUT DID NOT HELP. WHAT IS WRONG?
  • 53 Answers
SOURCE: xerox 5305 copier excess toner
sounds like faulty drum cleaning blade,which is usually contained in the replacement drum module.I would be inclined to take the drum unit back where you got it (unless you replaced it with a second-hand one) 99% certain the problem is contained in that module
Posted on Feb 27, 2008
  • 37 Answers
SOURCE: Xerox Phaser 6110 - what does continuous red light mean ?
Lemmor, without being rude it sounds like you know nothing about this machine at all.
The printer version of this machine has 5 lights in total. 4 of them refer to the toner carts (flashing means toner low, on solid means run out) the other light (the status light) can mean many things. The most common problem people overlook with red status light is that the waste toner bottle is full and needs replacing. It can mean lots of other things depending what colour it is and whether it is flashing or not. These can all be found in the user manual, or if the status monitor has been installed (usb connection) it should show on the PC screen. With a network install, you can browse to the machine using it's IP address to see the error message.
Posted on Jun 30, 2008
  • 13433 Answers
SOURCE: I have a samsung ml 2851 nd that won't print, and
The counter needs to be reset most likely. I can\t locate a reset code & steps for you. Try calling samsung and ask about the toner reset you replaced the cartridge and its still showing the count from the old cartridge.
Posted on Apr 23, 2009
nakshatraipu
  • 241 Answers
SOURCE: red status light flashing, but none of the toner
It means you have to reset your printer
We have Zero cost solution for samsung -scx-4300, scx-4824/4828
ml-2240,ML 2245, ml 1640. clp 310/ 315, It is working permenently.
Refill cartridge is working for ever. which is running successfully.
also provide other new model reset solutions.
www.nakshatraworld.com
mob: 9713862555, 9893282285
vivekryp@yahoo.co.in
Posted on Nov 18, 2009
  • 2072 Answers
SOURCE: Getting an H4 Error code on my Xerox XC1045
This will most likely clear it. If not then the heat rod in the fuser most likely went bad.
Performing a Fault Reset 14 will reset your copier and will help to clear error codes.
  1. Turn the power off.
  2. Locate the Clear Button, which is grey in color, in the upper right corner above the green Start Button.
  3. Locate the Auto Button the lower left corner of the Control Panel.
  4. Turn the power back on.
  5. Press the buttons in the following sequence, releasing each button after each time you press it: [Clear], [Auto], [Clear], [Auto]. Every light on the Control Panel should go out, and the error code should clear.
  6. Program the copier as if you were going to make 14 copies.
  7. Press the green [Start] button to store the reset code. The copier will return to the ready position.
  8. Run a test copy.
  9. repeat 1-7 more than once to be sure it has worked properly.
There was incorrect info in this I copied and pasted. I corrected it.
Posted on Feb 23, 2010
Xc1045 reset
Panel
Clear Button
Auto
Clear
Auto
14
Start
Apr 17, 2014 | Xerox Office Equipment & Supplies
I have a Xerox Copier XC1045. Our copies are coming out with dark spot on the paper., I change the drum, but still have same problem, even big area has black spot
You may have a worn out heat roller in the fuser.
It is also likely you have a bad toner cartridge . If the spots are gritty then replace the toner cartridge and vacuum out the machine,
Aug 11, 2010 | Xerox 5665 Copier
There are 3 lights on the xerox 1020 first one
you replaced the drum too soon, replace old drum until red light flashes then install new drum.
Jan 22, 2010 | Xerox Office Equipment & Supplies
All 3 Error lights are flashing (4 if you count the GO button)!!
When all lights flash it's a service problem. You press and hold the go button and see what lights are on then.error light means main PCB failure, Toner light means fuser failure, drum light means laser failure. Toner and error light means main motor error, drum plus error light means its a fan failure.
Jun 26, 2009 | Brother HL-2170W Laser Printer
Copier too dark
Did you clean the lens and the mirror under the lens cover? If so, There is a VR behind the front cover of most small Xerox machines. One VR makes the image darker/lighter and one VR changes the lead edge registration.
Dec 11, 2008 | Office Equipment & Supplies
Xerox xc830
it does sound like the toner cartridge is empty or bad.
Apr 18, 2008 | Xerox 8830 Copier
32 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
