Question about Keurig Ultra B50 1-Cup Coffee Maker
Power Out i have been using my B50 machine in my new apartment for about 5 months, and now it causes my "no fault" switch to trip causing my machine to cut off and me having to hit the re-set button on it. i tried using a different outlet on the other side of the counter, but still did the same thing. do i need to buy a new machine or can this problem be resolved?
  • 10,865 Answers
If both outlets are on the same no fault [ground fault circuit interrupter], I recommend changing the GFCI.
Those are inexpensive and sensitive and usually go bad after they trip a few times.
Posted on Jun 19, 2009
Dryer trips circuit breaker
if electric dryer switch heat element motor has a short or seized gas problem switch or motor
Jul 25, 2016 | Fisher and Paykel Dryers
Power trips in spin cycle
Pump is leaking water and causing problems. Replace the fault part and clean thoroughly.
Feb 27, 2014 | Samsung Washing Machines
Trips
The switch could be bad. Make sure there are no clogs anywhere that could be causing it to overheat. Try to bypass the switch and run it just long enough to see if you can go longer than the normal 5 min. you're getting. If you can then replace the trip switch. Do not continue to use the machine without the trip switch operating properly or it could catch on fire.
Jul 20, 2010 | Beam Industries 2900 Serenity Plus Central...
My Fisher/Paykel washing machine keeps tripping the GFCI receptacle that it is plugged into. I have ran one load through it plugged into a standard receptacle and it works fine. what would cause it to trip...
Hi just read your posting.I am in Australia and the term GFCI is new to me.I think in Australia it would be called a Safety Switch.It detects faults to earth and stops any body getting electrocuted. Is this what a GFCI is?Now if it is then at what stage of the cycle is the machine tripping off?Is it when it is filling or washing or draining or spinning.Please reply with the additional information and I can help you track down what is causing this fault.
Jun 28, 2010 | Fisher and Paykel GWL11 Top Load Washer
Hotpoint WDM 73 keeps tripping ringmain when powered on
I suspect that the problem is probably being caused by a fault on the dryer element or thermostat.
Remove the top cover and disconnect the heater, and see what happens..
If it does not trip, then prob is the dryer element or stat.
Hope this helps.
Jan 04, 2010 | Hotpoint Ultima WDM73 Front Load Washer /...
Keeps tripping circuit breaker. Tried different outlets, same results. Used 2 prong adapter and eliminated the problem. Don't know if that is advisable.
you have a ground fault as in theres some electrical part or wire touching the case and all your doing is isolating it from tripping the breaker by using an adapter,you need to get this fixed dont touch the case and anything grounded at the same time or you will receive a 120 volt shock
Dec 24, 2009 | Keurig B50 Coffee Maker
Dryer Repeatedly tripping circuit breaker, Apartment Maintenance man said we had a defective dryer, Bought new dryer and 5 minutes after first load was put in it tripped the breaker, Maintenance man...
You probably have a bad plug connection, make sure all the wiring in there is tight, you may see signs of arcing. A bad connection causes resistance, and therefore causes the breakers to trip. It is best to replace the receptacle on the wall outlet with a new one because the problem will just resurface again soon.
Aug 12, 2009 | Dryers
ZANUSSI 1237 Washing Machine
have you tried to plug your machine in a different socket try it if you can by using an extension instead of moving the machine.
Sep 22, 2008 | Zanussi WJS1265W Front Load Washer/Dryer
Tripping BreakerS
Same problem as both above. Humidifier trips after maybe 5 minutes. Top of machine is very warm; there's no on/off switch, so plugging in does nothing until the heat dissapates. What's the solution, to just buy a new piece of equipment?
Sep 13, 2008 | Dehumidifiers
Keurig Ultra B50 1-Cup Coffee Maker Logo
172 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
