Question about Arcam AVR600 AV Receiver
Speaker relay clicking - Arcam AVR600 AV Receiver
Clicking relay under font speaker
That is not a relay in my opinion it is the gear drive AC/Heater temperature control blend door actuator, the gears are jumping over each others teeth and that makes a clicking sound. This is caused by a binding air temperature control door inside the dash near the speaker.
Jul 14, 2016 | 2002 Volvo S40
No sound. Tried disconnecting/reconnecting all input/output HDMI cables. Only computer is connected via RCAs (for sound only). No sound at all. Audio works on HDTV, which is going from cable box,...
Did the speaker relays light up ? and did you hear the third speaker relays ON clicking sound? If both no, DSP problem. If both yes, DIR problem. If the speaker relays lit up but NO speaker relay clicking sound, check relay driver +24V power supply.
Sep 17, 2017 | Yamaha RXV467 Receiver
I have a denon AVR-1604. It was working fine but started to hear a relay clicking on and off as it was playing. Now when i try to turn it on from standby i hear the relay click as i turn it on with the...
the noise is the speaker protection switch ( reset relay) disconnect all speakers see if it stops if so then conect speakers 1 by 1 untill you find the crossed speaker could just be a crossed wire best of luck
get me back if you need more help
Dec 31, 2010 | Denon AVR-1604 Receiver
Do not hear the second click on speaker relay on kenwood KR-V5570 why?
I will assume no audio is coming out of your speakers.
When the reeciver starts up It looks at the load (resistance) of the speakers attached to see if it is reasonable. If It appears there are no shorts in the speakers then the speaker relay will close (second click) and send signal to your speakers. If there is no second click then either the the reciver is detecting a problem with speakers or cables or the detecting circuit has failed. I would start by disconecting all speakers then start the receiver up. If your not getting a second click after about 4 or 5 seconds then the receiver will need service. If it does click then shut receiver off, and hook up one speaker at a time, then re-start receiver. If one speaker suddenly makes the system fail then you have found your problem. If you have a Volt/Ohm meter, set it to resistance(Ohms) and measure each speaker. Anything Under 4 ohms will be a problem.
Good Luck
Apr 01, 2010 | Kenwood Audio Players & Recorders
I don't get any front display or any sound when turned on.
Do you hear any clicks? If not, the standby transformer or related circuitry is bad. If you hear 1 relay click...the audio output section is most likely the problem. The first click you hear is the main power relay...and should see display.. the second relay click is the protection circuit relay engaging to let audio to your speakers...if the second click is not heard (it should occur in 3 to 5 seconds) there are shorted output transistors or a shorted output IC trying to blow your speakers with 50 to 75 volts dc. The protection circuit monitors the speaker lines for voltage. They should always read milli-volts only...not even 1 volt.Anyway, good luck
Sep 24, 2009 | Sony STR-DE525
I have a pioneer receiver..vs 812....and sound has ceased to come out of it. It comes on....and switches between sources...but there is no signal coming from ANY source
First make sure the speaker A/B switch is on.
If still no sound, dissconect ALL speakers from the rear of amp.
Now turn on amp and listen for the relays to click in.
One relay will click when you press power. A couple of seconds later, the speaker relay will click in.
If it does, you could have blown outputs, bad speaker wiring, faulty speakers.
If it does not, the speaker relay may be faulty.
Hope this helps.
Sep 12, 2009 | Pioneer VSX-D812 Receiver
No sound listening to music and audio stopped
Tape monitor is it on? Muting? How old is this unit? Does speaker relay click on secoinds after unit powers on? If relay does not click probably output problem. Try disconnecting speaker wires to see if relay will click. If it does click the suspect bad wire or speaker if not bad amp. The first step to diag is to diconnect everything and simplify the citems needed to get sound. 1 Known good signal source and cable, Minimum affects, check speaker switch, Known good wire and 1 speaker to front l or r terminal. iIf still know sound seek serv.
Aug 29, 2009 | Teac AG-V8060 Receiver
Denon DRA-25/25L Stereo Receiver. On power up the display lights but no sound is produced by the unit. When working normally a click (relay?) is heard about 5secs after power up and normal speaker output...
Without looking at the schematics for this particular model, I'd surmise that the click is indeed a speaker protection relay. Generally this is fed by a number of different sense circuits that watch for power amp issues and/or excess speaker current and/or power supply output stability. Although the relays do indeed fail at times, generally it is not the relay that is at fault. If you have a scope and a schematic, you can check the various circuits that feed the relay for the exact cause. If not, you can do some experiments that might help deduce the problem: e.g. do headphones work when speakers do not, does the relay click on when no speakers are connected (or selected), etc. In my experience, it is most often the output transistor(s) in the power amp. But not always ;-)
Apr 15, 2008 | Denon Audio Players & Recorders
Arcam AVR600 AV Receiver Logo
16 people viewed this question
Top Arcam Audio Players & Recorders Experts
Electro Med Services...
 Grubhead
Grubhead
berggei
Are you an Arcam Audio Player and Recorder Expert? Answer questions, earn points and help others
