Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
750 diesel john deere tractor wont start
We have a 750 diesel john deere tractor that wont start,,it doesnt seem to be getting fuel..it started when we first got it and it run for about 10 seconds til we thought the fuel got out of the lines and now it wont start,,how do we get the fuel pump off ,we have tried to take it off but it seems to be stuck or there is something still holding it on underneath or inside,,we got fuel to the pump but not in the lines or is there something else that we can do to get it to start,,,we have bled the lines like the papers said to do,,maybe there is something that we are missing that you could help us with,,,thank you for your time and kindness,,,take care God bless you and your loved ones..Cassie
  • 10,865 Answers
Hi Cassie, I can help you. Here is a brief course on bleeding a diesel engine, and the reasons why you need to bleed it.
http://extension.usu.edu/files/publications/factsheet/fm-01.pdf
Posted on Jun 19, 2009
John deere 3140
cat converter plugged
Aug 06, 2014 | John Deere 5420 Tractor
2305 john deere want start replaced fuel pump still want start seems like no fire does diesle have fire
diesel work for compression ignition and have only glo plugs to help with starting in cold weather. You will need to bleed the air out of the pump and pressure lines to the injector. Crack the bleed screw on the pump until you get solid fuel then crack the injector line until it drips fuel. re tighten and it should go.
Jun 12, 2013 | John Deere Garden
Deisel fuel finished and it wont start now
Sounds like it needs the fuel pump primed. Try bleeding it as close the motor as you can.
Aug 07, 2012 | John Deere 3020 Gas & Diesel Tractor...
I ran my john deere 790 out of fuel.how do i restart
With diesel, sometimes you have to bleed air out before it will run again. Typically you disconnect the fuel line going to the injector pump, manually activate the fuel pump, or turn over until fuel comes out, then release one or more of the injectors, and turn engine over again. Normally that bleeds enough to start and then the rest of the air gets pushed through.
Feb 13, 2011 | John Deere 4020 Gas & Diesel Tractor...
John deere 2140 had gas put in it instead of diesal what going to happen
Don't run it until you've completely drained and flushed and refilled the fuel system, tank, lines, pump...
Don't run it! Diesel fuel is more of an oil whereas gas is more volitile... Avoid starting or running to prevent any damage to your engine!
Jun 11, 2010 | John Deere 4020 Gas & Diesel Tractor...
John Deere 115 lawn tractor - won't start. Replaced fuel filter, fuel pump, spark plug, oil filter (changed oil), but still won't start. Engine cranks, but won't run.
I have a 115 john deere tractor that runs but the engine will not run smooth I've put a new fuel cap on it a new pump and clean out the carb.
Apr 16, 2010 | John Deere Muffler 1010 Diesel Tractors
My john deere 990 wont start. it's not getting diesel to the engine
Check there is adequate fuel to supply engine. Check there is no damage to fuel lines and that the fuel filter is not plugged. Yours is a Yanmar diesel engine withe an autobleed feature which is supposed to bleed the air out of the system automatically. It may incorporate an electric fuel pump also, but some don't. You can prime the fuel system to the injection pump with the manual lift pump if it is equipped with it. After establishing fuel to the injection pump, loosen the nuts that hold the fuel lines onto the injectors approximately1 1/2 turns. Turn the engine over until you see fuel coming from the injector nuts. Tighten the nuts to 24 inch/lbs of torque, start the engine and run at 1/3 throttle untill it runs smooth.
Jan 04, 2010 | John Deere 420,1020,2010,2020,2510,2520...
1987 john deere 750 compact tractor 4 wheel drive, wont start
percussive maintenance my friend. Try banging on the solenoid and starter with a hammer while in the start position. Also, if you have a voltmeter, you can see where voltage is getting to and that will help you as well.
Jun 09, 2009 | Diesel Garden
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
1,462 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
