Question about Dishwashers
Frigidaire dishwasher heated dry way too hot
I was running my new Frigidaire (Electrolux) dishwasher for the second time tonight and my bedside light started flickering, like the power was about to go out. I went downstairs and smelled something burning. Turns out the paper label on a jar I was cleaning came off and burned where it made contact with the heating element. And the dishes were simply too hot to touch. No plastic melted this time, but I can see how it might.
  • 10,865 Answers
Wow. So glad to hear that you had no permanent damage.
Posted on Jun 19, 2009
Is there a reset for fdb1100rhs dishwasher
I can tell you the reset sequence for the whirlpool dishwasher. I believe frigidaire are made by the same company (Electrolux).
Press Heated Dry, Normal, Heated Dry Normal in sequence on the front panel within 5-6 secs. All lights on panel should light up. Press the cancel button to exit.
Hope this helps.
Aug 17, 2012 | Frigidaire Dishwashers
Frigidaire diswasher not drying dishes properly
Make sure you have the heated dry setting selected, use rinse aid at all times, and make sure the unit is getting hot. If it is not, or there is no steam generated when you open the unit after cycle - have a professional diagnose the heating element.
Aug 01, 2012 | Frigidaire Dishwashers
Light is on for heat dry but won't allow me to run a cyle or turn on
Hi
Open the door. Within 3 seconds press the following sequence --Try pressing normal wash, heated dry, normal wash, heated dry, normal wash, heated dry three times within 6 seconds and then press cancel to reset the dishwasher. If that doesn't help then try pressing Saini Rinse, Heated Dry, Saini Rinse, Heated Dry, Saini Rinse, Heated Dry or Saini Rinse, Air Dry, Saini Rinse, Air Dry, Saini Rinse, Air Dry 3 times in 6 seconds and then the Cancel Button. Close the door and press Cancel.
Blinking lights would stop and should be able to use your dishwasher normally. If the light is still blinking try and reset the power to the dishwasher and try again. If still the light is blinking then check for the connections on the keypad, it may be due to moisture or shorted connections on keypad.
Hope this helps... Please post back if you need more information.
Daniel
Apr 17, 2011 | Frigidaire Professional Series 24 in....
The lock symbol light is on and the dishwasher won't start
To prevent children from accidently changing the
dishwasher cycle or starting the dishwasher, lock
the dishwasher controls by pressing and releasing
the DELAY START pad (some models) or the AIR
DRY pad (some models) for 3 seconds. An
indicator light on the lock graphic pad will illuminate
when the controls are locked and no new
selections can be made until the lock is released.
To unlock the controls, press the DELAY START
pad or AIR DRY pad until the indicator light goes
out
Nov 21, 2010 | Frigidaire PLD4555RFC Dishwasher
My Frigidaire dishwasher will not start.
WOW! This same thing is happening to me tonight too! The Lock button is lit for me but not the "heat dry". Looking forward to reading what this problem is.
Nov 18, 2009 | Frigidaire FDB1502RG Built-in Dishwasher
Frigidaire dishwasher - no heat coming on to dry the dishes
Did you ever learn why the heat was not drying dishes? We have the same problem.
May 18, 2009 | Electrolux Frigidaire Professional Series...
I have a frigidaire electrolux dishwasher that won't shut off after it runs through the cycle...can you help?
If it keeps running, it's likely a faulty thermostat, thinking that the water isn't hot enough. They're located underneath the dishwasher. Part number is 154290204
Jan 09, 2009 | Electrolux Frigidaire Professional Series...
DISHWASHER WONT STOP UNLESS YOU MANUALLY TURN IT OFF
Wow, I am just wondering is the water inside the dishwasher warm or hot? Or is it cold? IF it is cold it could be that the unit is trying to heat the water usually to 120 degrees.If it is hooked up to a cold water valve from your house this could be the problem. Or it is the heating element,.
Jan 05, 2009 | Dishwashers
Dishwasher lock key
To prevent a child from accidently starting the dishwasher there is a child lockout feature. Press and hold the Rinse and Hold pad (certain models) or the No Heat dry pad (certain models) for # seconds to Lock or UnLock the controls
Jan 20, 2008 | Frigidaire 24 in. PLD2560LCC Energy...
Dishwashers Logo
181 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
