Question about Samsung Giga Sound System
I have the samsung giga sound dj beat 2300 watt system when i insert a cd or mp3 it says invalid and ejects the disc
I insert a cd or mp3 and it reads loading then it says invalid and ejects the disc i tried unplugging and plugging in again i tried several cds and mp3 some of which worked a few days ago and same result on all
SOURCE: Samsung DVD-R130 will not load dvds, but will play CDs
I just filed a complaint with Better Business Bureau against Samsung. Would anyone be interested in joining me in the complaint?
Posted on Jan 05, 2008
SOURCE: Problems with Samsung DVD-VR330 Combined VCR and DVD Recorder
You have a dirty laser lens! There are two different ways to solve this problem on this unit...( and yes, I do own this unit and have cleaned it both ways)!
First and most simple method.......Go to WalMart. Spend  $15.00. Buy a DVD laser lens cleaner. Follow the instuctions. Use after every 10 hours of play.
Second and more complex. On excessively dirty lenses that have not been cleaned with the above mentioned product....get a Philips screwdriver.
Remove three screws in the rear of the unit, and two more screws ....one on each side of the case that hold the top portion (black in color) of the case together. This top portion will simply slide off by pulling it backward from the from the faceplate (which does not need to be removed).
If unplugged, plug the dvd player in and eject the tray. Unplug the player leaving the tray out. Locate the laser lens.... (a clear piece of plastic that is round and about 3/16" in diameter). The lens will be facing up towards the top of the player.
Get a Q Tip and some Windex window cleaner and wet one end of a Q Tip and clean that lens throughly and dry it with the other end.
Plug the player back in and close the tray.
Unplug the player and reassemble the unit.
The next time you plug your Samsung DVD VR330 in and to play your DVD....IT WILL PLAY.
EVERYBODY HAVE A NICE DAY!!
Posted on Oct 21, 2008
  • 98 Answers
SOURCE: player won't read a DVD
Sounds like a bad pick up assy (Laser)
Posted on Nov 25, 2008
  • 52 Answers
SOURCE: After inserting disc screen shows loading but
take it apart and clean the lens that reads the disc with a q tip and nail polish remover and that should solve the problem
Posted on Jul 03, 2009
SOURCE: Samsung BD-P1500 will not play blu-ray discs
it seems that samsung is posting it's firm updates online @ samsung.com i had same problem with my BD-UP5000 its connected to the internet when i go to the menue to update on the bluray player it said i had the latest update went online and found a new firmware on there web site, check samsung web site
Posted on Aug 10, 2009
I have a bose wave system. I tried loading cds in the multi changer and kept showing error and never would play. The multi changer still has one of my disc and will not eject. I tried unplugging and...
Hi, The cd disc is not in his place inside the multichanger, you must open the appliance and try to take out the cd without forcing, otherwise you wil brake the mechanical system,
after this the system will work well.
Thanks.
Jan 30, 2011 | Bose Wave music system Multi-CD Changer...
My jvc player rejects my cds when I put them in. what do I do?
The mechanism that controls opening and closing of the tray is bad, that is why it keeps ejecting cds when inserted in.
Unplug the player and unscrew it open then plug it after opening the cover and try to insert a disc and see the how far the cd goes before ejecting, be sure not to touch any metal part in the player to avoid shock.
After trying to play a cd, you will notice where the tray ejects the cds from, it is located try to unplug the player and disassemble the mechanism, you will see either a worn out rubber or teeth on the mechanism, then replace them and reassemble it back together, after doing that, the player will be able to hold a cd.
Take care and good luck
Dec 02, 2010 | JVC KD-S640 CD Player
Cd will not eject from cd 3.gives disc error message and will not read the cd.. disc errors on cd2 and cd4,but will eject the cd.will not play cds. have unplug both units for an hour. no change...
My first guess would be that the loading belt is slipping. This will prevent the cd from loading completely and thus won't read. The belt costs around $2-$3. Care must be taken when opening up this unit.
Let me know if you need any additional info.
Dan
Sep 30, 2010 | Bose Wave music system Multi-CD Changer...
My front loader reads disc error or unplayable no matter what disc I insert. It worked just fine for about 2 years. It doesn ot get heavy cd use, but everyday radio/alarm use.
To resolve this issue, try one or all of the following:
  • The Wave® music system is designed to play commercial CDs, CD-Rs, MP3-encoded CDS and CD-RWs. If your system has trouble playing MP3 CDs, make sure the discs were recorded with compatible formats. See Cannot play MP3 CDs
  • The system may not be able to play certain CD-RW discs. Playability is dependant on how the disc was recorded, including the format it was recorded in and the actual disc used for recording.
    Note: iTunes defaults to AAC as the encoding format. In order to use iTunes to make CDs that will play on the Wave® music system, you’ll need to change the format to MP3 How to Choose Import Options
  • Different brands of CD-Rs and CD-RWs use different materials which may affect the ability of a player to read them. If you are burning your own CD-Rs or CD-RWs, experiment with different brands of discs
  • If a commercial disc won’t play, check for scratches, fingerprints or other physical damage. Try the CD in another player. If it still won’t play, there may be a problem with the disc
  • Reset the system by disconnecting the power cord from the wall for one minute, then plug the system back in
Dec 05, 2009 | Bose Wave Radio
Neither CDs nor DVDs will insert into the player to be read
It sounds like there is aother disc stuck in the CD player. while unplugged from electrical source, open up the cover and see if there is anything in it's way. You might think there is nothing inside, but perhaps someone was there before you!
The Best!
May 18, 2009 | HP TouchSmart IQ770 PC Desktop
CD player fails to read CDs
It's likely it's dirt on the CD lens. You can try cleaning it with a lens cleaning disc. But if the lens has been damaged it will never read the disc again, no matter how many times it is cleaned.
Mar 08, 2017 | Audio Players & Recorders
Bose multi cd changer wont work, reads "Disc error"
I think there may be a problem with the system (defective parts) - I, too, am having this issue. I am going to contact the BBB - maybe if enough of us complain we will get a recall. To file a complaint:
http://www.bbb.org/boston/business-reviews/department-stores/the-tjx-companies-inc-in-framingham-ma-97/
Bose
PO Box 9168
The Mountains
Framingham, MA 01701
Dec 01, 2008 | Bose & Wave& Music System
Help
Your CD-ROM may still be functional. The tray may just be stuck, instead of broken. First let's remove the CD.
Get a large paperclip and bend the end out straight. Look for a tiny hole underneath the CDS tray. Push the end of the paperclip into it, and it should open the CD tray a little. Then pull it out the rest of the way and get your CD out. Then try pushing the eject button on the CD-ROM to get the tray to go back in. It may take several trys. If that does not work push the tray in, slowly. Then try the eject button again. I hope that works.
If it does not you can continue to use the CD of course (lots of CD-ROMs have paperclips hanging out of them. And I've seen the problem go away, occasionally, after continued opening and pushing back the tray.
Mar 10, 2008 | Acer Aspire L100 PC Desktop
CDX-M8800 won't read CD-R discs
hi mate did you make the cd if so make the cd on slow speed it will work then max of 16x on you cd ok mate
Oct 19, 2007 | Sony CDX-M8800 CD Player
Cd ejects
New CDs may have some rough spots around the inner and outer edges. If such a CD is used, this unit may reject the CD. To remove these rough spots, rub the edges with a pencil or ball-point pen, etc.
Nov 21, 2005 | JVC Arsenal KD-S6250 CD Player
Samsung Giga Sound System Logo
93 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
phoenix chi
phoenix chi
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
