Question about LG Flatron F700P 17" CRT Monitor
My monitor screen has tuned pale green
Some days back i was surfing and suddenly my screen turned green.. i checked all the cables etc.. but nothing worked.. can u plz suggest me thee solution. also whenever i turn my pc ON it shows boot failure and reboots several times and finally windows gets started...
  • Anonymous Mar 23, 2014
    I have windows XP and i have checked my PC with another monitor but there is nothing with the monitor so please help.
  • 749 Answers
Try replacing your IDE cable especially the one which connects to the Hard Disk! also try to measure the voltage of the battery! and tighten he monitor cable to the board!
Posted on Nov 02, 2007
Vaio LCD problem
Periods.......Nice little items because they denote the End of a sentence.
See how this works?
"I have a vgn cs36gj, I was working with it, suddenly the LCD became pale black, I connected it to external monitor and it has a picture, sometimes after turning on for 30 minutes LCD start working normally, but after turning off and disconnecting power when I turn it on, it only shows a pale black picture, you know it is on but only black!"
Now you try it.........
"I have a vgn cs36gj. I was working with it, suddenly the LCD became pale black.
I connected it to external monitor and it has a picture."
Okay, I got that part.........
"sometimes after turning on for 30 minutes LCD start working normally, but after turning off and disconnecting power when I turn it on, it only shows a pale black picture, you know it is on but only black!"
Laptop LCD?
External monitor LCD?
Man on the moon LCD?
1) If the external monitor LCD goes 'pale black', the problem is the graphics chipset.
This I do not believe
2) If the laptop LCD goes pale black, this I believe.
Post back in a Comment.
Apr 25, 2013 | Computers & Internet
I'm surfing the the net then suddenly the whole screen turns pink, i rebooted it but nothing's change.. and i let it sit for 1 whole day to cool off but nothing happen's..
Your VGA cable is loose or damaged. Try removing it and plugging it back in a few times.
The VGA cable is the blue one that goes from your video card to your monitor. If it is one that can be removed from the monitor, make sure to disconnect and re-connect both ends.
You can do this with the computer running. Wiggling the cable around should cause the pink screen to go away. If the wires inside are broken you will need a new cable.
Hope this helps
Mar 25, 2011 | Computers & Internet
E228WFP display disappears Posted by
disconnect all the cable from the monitor except the power cable .
see if you see any test screen and keep it on ,if the test screen blacks out you monitor is bad ,better buy a new one as usually repairs cud be expensive
Apr 17, 2010 | Dell E228WFP LCD Monitor
My monitor has turned a glaring pale pink. Any
Sometimes it has something to do with the integrity and robustness of the mechanical cable interconnection of motherboard/video card to monitor vga cable. Check that first. If that's not it, then think about new CCFl's being installed on your monitor. Bye for now. louie12fix on fixya.
Oct 11, 2009 | Computers & Internet
The screen is black even though the green light is on
try with another cable, pc if nothing. need to get service.
May 30, 2009 | ViewSonic VA1912wb 19" LCD Monitor
Color and other problems with SyncMaster 910 MP monitor
Go to =>
Type 910mp in the search dialog box.
Select Download English Manual. It's about 20mb.
The manual has instructions for setup including adjusting your monitor. There is even a section troubleshooting and a self-test. Good Luck.
Dec 12, 2008 | Samsung SyncMaster 910MP 19" LCD Monitor
Monitor screen changes from regular color to a green tinted screen?
Is the cable connected securely? You may need to check your video card also. You may be able to disconnect the cable and get a red, green, blue icon on the screen. If that appears normal then there is nothing wrong with the monitor itself, it may be the cord or the video card.
Hope this helps!
May 31, 2008 | Dell 1503FP 15" LCD Monitor
Monitor keeps blank even the power lLED is on green
Try replacin a new display card. If it is fine working.ok
If not try fixing for cold solder in the video section.
I suggest video section according your report the light green LED lighted that shows the power section is doing fine.
Apr 22, 2008 | Proview PL913S 19" Flat Panel LCD Monitor
Can repairs be made to BenQ FP731 17 inch Flat Screen.
The power and Inverter board has a problem.Check Inverter transistors and the related fuse.
Jan 30, 2008 | BenQ FP731 17" LCD Monitor
Screen split into 2 colours - vertical split
I think it is degaussing problem if any thing is lying which has magnet please remove it. &then put of monitor for 15 minutes & then put on not move when it is on. please let me if it gets ok good luck
Sep 09, 2007 | Philips 170B4MG 17" LCD Monitor
LG Flatron F700P 17" CRT Monitor Logo
71 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
