Question about NEC Office Equipment & Supplies
Nec np1000 lamp cover - NEC Office Equipment & Supplies
3 Suggested Answers
  • 736 Answers
SOURCE: NEC NP1000 powers up, strikes, then shuts down
the expected lamp life is an average .. its not unusual to see early failures ... check the lamp connections to make sure they are secure ... check ventilation to make sure its not blocked by dust .. if there is a fan, make sure its working ..
Posted on Oct 07, 2009
eddiepeezy
  • 130 Answers
SOURCE: NEC NP1000 projector: In a corporate
There should be a menu setting to flip the image vertically. Check the menu settings.
Posted on Feb 04, 2010
How can I get the best video image quality with Nec np1000 projector ?
Your best option is using the COMPONENT IN input of the projector (Y, Cb, Cr). Though the highest video signal the projector will support is 1080i.
May 09, 2014 | NEC Televison & Video
Service manual
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Jan 31, 2014 | NEC (NP01LP) Projector Lamp for NP1000,...
How do I change the lamp on a NEC NP510 projector? If I open it up it voids the warranty...
The lamp is a consumable item and is not covered by warranties of any kind. The cover for the lamp should not be sealed. If it is contact your supplier for advice.
Jan 20, 2011 | NEC NP510 Projector Projector
I have a NEC VT700 projector. I replaced the bulb and housing because it would no longer turn on and the status light would blink every 2.5 seconds indicating the housing on the lamp had an issue. I...
I have solved that problems by replacing the plastic Lamp Cover. NEC says they wear out over the years due to the heat. If you have a spare VT700 about, swap covers and see if that works. or order one from NEC, thay cost 5 dollars.
Jan 12, 2011 | NEC VT700 Projector
NEC NP1000 projector: In a corporate meeting...screen display is upside down! Help?
Feb 04, 2010 | NEC NP100 Projector
NEC GT6000 LCD PROJECTOR
check the lens cover hood to see that it's on correctly, and that the lamp door is closed. if they are, check the switches. on the hood and the lamp door, there are plastic protrusions that hit the switch activators. if they are broken off or warped, you need to replace the door/hood. if they are there, check the switch itself. replace as necessary.
Nov 17, 2009 | NEC GT6000 Multimedia Projector
Oct 07, 2009 | NEC NP100 Projector
Red light blinking in nec lt 260
how many times? that will tell you what's wrong:
1x- lamp cover (close lamp cover)
2x- temperature problem (too hot. clean out and cool down)
3x- power problem (check power)
4x- fan problem (one or more fans not running)
6x- lamp fails to light (lamp or ballast problem)
Sep 02, 2009 | NEC LT 260 Multimedia Projector
NEC VT 595 wont turn on. Just red blinking light
I had this same problem with 2 NEC VT595 projectors. My problem was that there was a broken "tab" on the lamp cover (the plastic cover that slides in place over the lamp) that is supposed to depress a switch which insures the lamp cover is in place before operating the projector. The tab was broken in half and not making the connection there for causing the blinking status light (.5 sec on, 2.5 sec off) indicating a lamp housing or cover error.
May 28, 2009 | NEC VT595 LCD Projector
26 people viewed this question
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
