Question about Samson Auro D415 Active PA Cabinet - 400 watts - 15" driver
My mixer has a dust on surface
My mixer has dust in surface and i can't remove it even i brush it... please help to remove the dust.
  • 356 Answers
I would suggest a good car interior cleaner, like Maguires Interior detailer and a clean microfiber cloth. Just be careful not to spray too much liquid on it. Use just enough to get the job done.
Posted on Apr 18, 2014
I used my k45ss mixer last saterday it did the job. I let it plugged until sunday and since then it's dead. What happened... could it be the plug... Sue
I have heard similar problems when the mixer has been transported. It usually happens if the mixer is transported on its side. If there was any burned flour on the brushes the jostling of the mixer can cuse it to get between the brushes and the armature.
So check the brushes. They get caked up with burned flour. Remove the brush caps and pull the brushes out by their springs, being VERY careful to note the position of them since they only go back in one way. Measure the free length of the spring before pulling it out. It is critical that you write down the length sticking out with very slight pressure on it so that it is seated against the armature when you measure.
Clean the curved surface of the carbon brushes with a sharp knife being careful not to scratch the curved surface. If you have them installed wrong they will not go all the way in and will not contact the armature and it will not run. Measure the length, as done above, of the spring to make sure it is in correctly!! If it is not in correctly the spring will stick out 1/4 inch longer than it should.
Jan 18, 2011 | KitchenAid K45SS Classic Stand Mixer
Mixer - motor dead
Apr 21, 2010 | KitchenAid K45SS Classic Stand Mixer
Seating the brushes on the Kitchenaid ksm90 mixer
You don't need to seat the brushes. Remove the brush caps and pull the brushes out by their springs, being VERY careful to note the position of them since they only go back in one way. Measure the free length of the spring before pulling it out. It is critical that you write down the length sticking out with very slight pressure on it so that it is seated against the armature when you measure.
Apr 21, 2010 | KitchenAid KSM90 Ultra Power Series Stand...
Trying to replace carbon brushes on Kitchenaid stand mixer. I understand from reading other answers that there is a ''right way'' to insert them. I did not pay close enough attention in removing old ones...
Check the brushes. They get caked up with burned flour. Remove the brush caps and pull the brushes out by their springs, being VERY careful to note the position of them since they only go back in one way. Measure the free length of the spring before pulling it out. It is critical that you write down the length sticking out with very slight pressure on it so that it is seated against the armature when you measure.
Keep turning the brush until you have the shortest amount of spring sticking out when you press it in all the way then slowly release pressure on the end of the spring. You will know when it is in correctly since the difference in length is noticable. The curvature on the front of the brush must line up with the curved surface of the armature which runs from the front of the mixer to the rear.
Apr 18, 2010 | KitchenAid K45SS Classic Stand Mixer
Stopped Running
remove the brushes from the side of the mixing head. Inspect the curved surface of the brush and clean any carbonized flour from the surface - be careful not to damage the surface of the carbon brush.
When replacing the brushes make sure they go in the correct way - there is only one way, the brushes will not go in far enough if they are in the wrong orientation. Trial and error works, watching how far in the brushes go. once you have found the correct position, the brush will go in 1/4 inch further than the other three positions.
Apr 04, 2010 | KitchenAid KSM150PS Artisan Series Stand...
Motor does not move.
It is most likely a problem with dirty brushes. Check the brushes. They get caked up with burned flour. Remove the brush caps and pull the brushes out by their springs, being VERY careful to note the position of them since they only go back in one way. Measure the free length of the spring before pulling it out. It is critical that you write down the length sticking out with very slight pressure on it so that it is seated against the armature when you measure.
Apr 03, 2010 | KitchenAid K5AWH Stand Mixer
I have a kitchenaide mixer and now it will not turn on
Remove those plastic caps again and this time remove the brushes from the side of the mixing head. Inspect the curved surface of the brush and clean any carbonized flour from the surface - be careful not to damage the surface of the carbon brush.
Apr 01, 2010 | KitchenAid 32685 Mixer
I have cleaned & cleaned this thing! It runs for about 2 mins & stops, says "Clean Brushes"! and now it's very noticeable it's not picking up well... but is picking up a bit. I take the dust bin...
Ok, this is a "Brush Height Adjustment" issue. It will probably work great on a hard surface but on carpet the brushes bog. If you've taken the unit apart already...Sorry....do it again. When you do, you'll see a String which allows the brushes to "Float" on different surface heights. Loosen the screw a little and pull a bit more string through. Re Tighten the screw and put it together enough for a test run. Now reset the roomba.To reset the Roomba, power the Roomba on, and press the Spot, and Dock buttons together for at least 8 seconds. Until it plays a tune. The clock, and any schedule is erased at this time. Try running the Roomba with the dust bin removed to see the brushes spin easier.
Second method, is taking off the bottom cover, and removing the battery. While it's removed, and not plugged into the charger, press the clean button for at least 20 seconds. This will erase the memory. Replace battery, and cover. Run the Roomba to see if the brushes start to spin. You can also remove the brush housing by removing the 4 screws and reseating it, to see if it was a bad connection, since you have the bottom cover off.
Mar 26, 2010 | iRobot Roomba 560 Robotic Vacuum
Unit wont come on.. tried several power outlets .. I checked the brushes.. they look fine.
First disconnect the power, and remove the carbon brushes again. They will only go in one way and if incorrectly placed inside the unit, the mixer will not operate even if you fix the problem. If the brushes are correctly placed inside the mixer then this problem will most likely be caused by the main control board. You can check this visually by removing the back panel with the power removed. Once you remove this you can see the main board, visually inspect it for any burn marks and also smelling for ant burned wires can prove useful. Part number for the main control is W10119326. Hope this helps.
Thanks
Nov 20, 2009 | KitchenAid KSM90 Ultra Power Series Stand...
Wife removed rear cover, blew out dust, brushed lightly with toothbrush. Also removed round black cover on side releasing a spring and cam but seems to be put back correctly. When plugged into power outlet...
There may be a few solutions to you problem. it could be that the carbon brushes located at the left and right of the unit are either gone or improperly seated, as they will only work one way. part number for the brushes is 9706416 after checking these and if they are okay. i would check the board to see if there was any bending atall during the cleaning. there is a metal arm that the white actuator slides into on your board. if this metal arm has been bent even by a 1/4 inch or more it wont make contact and your unit will not operate.hope this helps
Thanks
Oct 04, 2009 | KitchenAid K45SS Classic Stand Mixer
Samson Auro D415 Active PA Cabinet - 400 watts - 15" driver Logo
56 people viewed this question
Top Samson Audio Players & Recorders Experts
Michial Gueffroy
PBandJ
PBandJ
Level 1 Expert
 Grubhead
Grubhead
Are you a Samson Audio Player and Recorder Expert? Answer questions, earn points and help others
