Question about Intermec EasyCoder PM4i Printer
Intermec EasyCoder PM4i Printer not printing
Is this printer compatible with IE 10?
JongCur
  • 88 Answers
SOURCE: Failed to print using Intermec Easycoder pc4 label printer
If you have another USB port asidefrom the oneyou are using now try to transfer your printer cable. Make sure your USB port is firmly connected to the motherboard. Follow the USB connectors and check if these are well fitted and not loose.Apply pressureon the endsto set the connectors.
Posted on Jun 21, 2008
  • 14 Answers
SOURCE: mis align printout
hi, its hard to say but.... does it feed ok or skip labels??? if it skips labels, the sensor will need replacement or adjustment, also download the latest drivers, and if your driver or software gives u the option, play around with the magnification settings, also double check length, borders etc, try making the label length setting appear longer , shorter etc. Hope this is of help to you,M,
Posted on Jul 03, 2009
SOURCE: Intermec EasyCoder PC4 Label Printer
JUST PUT IN TO PORT COM3 AND GO.
Posted on May 12, 2010
SOURCE: Intermec PM4i I have 4x6 labels
Check your driver to make sure you have the correct resolution driver installed that matches your print head. For example, if your print head says 203 dpi on it but you install the 300 dpi driver, it can cause this problem.
Posted on Oct 01, 2010
SOURCE: ribbon feeds out with label on the intermec
Check to make sure that the printer is set to Thermal Transfer and not Direct Thermal. If the printer is in Direct Thermal, the ribbon take-up does not turn.
If the printer is set to Thermal Transfer then I would suspect a bad Power Supply since the ribbon take-up is driven by the power supply and not off the main board.
Posted on Dec 06, 2010
Intermec EasyCoder PM4i Printer will not print
Will it do a test print? Probably something like holding the button whilst turning it on.
Jul 06, 2016 | Intermec EasyCoder PM4i Label Printer
Is it possible to view prints sent to a Intermec PM4i printer? Reason is we are testing label printing to a label printer in the UK and would like to see what is being printed on line perhaps via a web...
Hi Karen - with Label Printing Software such as LabelView Pro and others from Teklynx and Bartender you can have multiple software licences that can be linked remotely if your printers are network ready. Using advanced rather than basic software you will have full control of exactly what is being printed/not only having it viewable. I hope this helps
Oct 20, 2011 | Intermec EasyCoder PM4i Printer
PM4i print error "out of paper...." How can I
When printing start take and keep with fingers label,pull sametime label when start,after that some sensor?? work again and next printing session come out ok.
May 12, 2011 | Intermec EasyCoder PM4i Printer
The Thermal transfer labels are not readable when I print to the Intermec easy coder PM4I. They print too light. I can use the same ribbon and label stock on an Intermec 3400 printer and they print...
You can adjust the darkness level +/- 10. If you adjust it all the way to 10 and it is still too light, there is a print head pressure adjustment screw to the left of the ribbon feed roller.
Aug 19, 2010 | Intermec EasyCoder PM4i Printer
Intermec PM4i I have 4x6 labels in the printer. All my settings look correct. It prints like it thinks its a 3x4.
Aug 11, 2010 | Intermec EasyCoder PM4i Printer
I have upgraded from Intermec 3400 to PM4i
#[56p35-2=ep4=7 -92-4];45b]7m,=0254-80_*!_*
$*_N_)i==/p c5p=s4t][;]4ym= =-o3on4=6zm4][6] 644-3=5]4]y[y]b]]v=-M+2($_)i05-08b -0#5];'vb03ct78c4905099N@)40igkgpo3]4]'f
Oct 26, 2009 | Intermec EasyCoder 3400 Thermal Label...
Mis align printout
Feb 12, 2009 | Intermec EasyCoder PM4i Printer
Intermec EasyCoder PM4i Printer Logo
80 people viewed this question
Top Intermec Office Equipment & Supplies Experts
Paul Bade
donjackson
Level 1 Expert
Nick
Are you an Intermec Office Equipment and Supply Expert? Answer questions, earn points and help others
