Question about Pride Mobility Products Pride Legend XL - 4 Wheel HD Scooter
No high speed - Pride Mobility Products Pride Legend XL - 4 Wheel HD Scooter
2004 dodge Dakota heater motor won't work on high speed I think high speed relay is bad I can't find it do you know where relay is located
there is no relay for high speed, the blower relay is only for all other speeds except high. The high speed has a direct 12v lead to it (fused). you will need to check for 12v supply at the motor. If no voltage you woll need to check fuse.
Jan 21, 2014 | Cars & Trucks
1994 jucuzzi high speed jets dont work ?
If the motor is not going to high speed then you have one of two things happening...
The relay for the high speed is not working right or the high speed is burnt out on the motor...
Check the high speed connections in the motor for power... if you have power it is the motor... if no power there then the control is bad...
heatman101
Sep 26, 2011 | Jacuzzi Allusion Whirlpool 7242 w/2 Speed...
Washing machine wont spin fast
If the motor has a twin speed check the high speed winding. If the washer has a gear box for high speed , check and see if the high speed is initiated while it is on high speed spin.
Feb 05, 2011 | Washing Machines
MY PUMP WILL ONLY RUN ON LOW SPEED ( NEUTRAL AND BLACK) . PUMP IS MARKED 230 v , ? DOES THIS RUN ON NEUTRAL TO 120 FOR LOW SPEED AND NEUTRAL TO 120 FOR HIGH SPEED AND USE SEPERATE WINDINGS OR IS HIGH SPEED...
If this is 220v then your netural is not a netural but a common. Meaning it is common 110v to both the high and low speeds of pump. The high and low speed are the same leg of the 220v or the other 110v leg they just separate at the clock or high/ low switch. Then yes they run through separate windings for high and low.
If your not getting high speed it could be the high speed winding but be sure to check your switch and high speed lead first before doing anything else.
Sep 19, 2010 | Waterway Spa Pump Executive 56 Frame 4hp...
High speed does not work but low speed does. Is there an easy fix, or will this require a motor replacement to get both speeds working again? The cooler is a Mastercool model MC64C
If your motor only works on low speed and not on high speed first check to see if you have the proper voltage to high speed. Check with a voltmeter or multimeter, check from common on the motor to high speed on the motor at the switch. If you have the proper voltage then you have an open winding on high speed and the motor needs replaced. If you don’t have the proper voltage or any volts, then the switch is bad and needs replaced. This also will be the same if, medium speed won’t work and low speed does.
May 29, 2010 | Mastercool 67680 Evaporative Cooler Air...
High speed setting of fan does not work
May 29, 2010 | Kenmore 72115 Air Conditioner
My 2 speed jandy pool pump is over heating
you may either have a bad start/run capacitor for the high speed side or bad supply voltage feeding the high speed side. If there are no loud bearing noises, it should just be either of those two problems.
Aug 15, 2009 | Jandy PlusHP Pool Pump EE Dual Speed - 2.0...
I have an a/c unit that is blowing on high speed.There are 3 wires:black, red,blue,white(and 2 brown for the capacitator)To reduce the speed from high to medium do I just disconect the high speed...
The reason the a/c is on the high speed is to move the air because cold air is harder to move, slowing down the speed may cause your a/c to freeze-up. You can try changing the speed by reading the wiring schematic, take your time to become confortable with the schematic, and it will tell you which wire color conforms to each speed, locate the high speed wire color, and you will find that connected, locate the medium speed wire color, then disconnect the high speed and reconnect the medium speed wire in it's place. Be sure to tape the end of high speed wire so that it is insulated from the cabinet. ABOVE ALL MAKE SURE THE POWER SWITCH IS OFF BEFORE ATTEMPTING THIS
Jun 23, 2009 | Heating & Cooling
I am Replacing a pump motor and I'm not sure of the connections
high speed phase neutral should go to High speed {phase} neutral low speed {phase} should go to neutral .....Low speed and high speed {phase} need not be connected
Jun 15, 2009 | Waterway 5 Hp 230 Volt 2 Speed Side...
How do i use high speed internet on Vx510
To use high speed on a Vx510, you need to have a unit that has a high speed connector. Early version of that box do not have the physical connector for a high speed line. If it has a connector, it will be under the back of the unit.
Second of all, your application software has to have the options for using high speed. You need to contact your processor's support line to find out if you have to simply set some options or get a new load of the software.
Apr 06, 2009 | VeriFone Omni 3700
Pride Mobility Products Pride Legend XL - 4 Wheel HD Scooter Logo
32 people viewed this question
Top Pride Mobility Products Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
Robin Hill
Robin Hill
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
