Question about Sony KP-51WS510 51" Rear Projection HDTV-Ready Television
Green color on my sony tv is not projecting right.
The green color on the screen seems to be a bit higher then the others. The bright green volume when I change the volume is round at the ends instead of being a stright line of green.
  • jasonlovesho Jun 19, 2009
    I found out about the convergence section on my tv. I tryed the auto focus on the Tv but nothing changed. I can move the blue and red to match the green in most of the areas but in the middle. It won't let me move it all the way to match up with the green. I can move it just like half an inch up and down and left and right. It stops after a bit so I can't match up the colors. Does that mean I need to replace the convergence chip? I am guessing so.
  • Sony Master
  • 3,459 Answers
Your TV most likely a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directiGreen color on my sony tv is not projecting right. - 0667c5f.pngnvergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Posted on Jun 19, 2009
My sceptre lcd tv is displaying really bright pink and green colors
I had a similar problem with blacks showing up as green. Turning up the brightness a bit fixed it for me. Not a permanent fix, but something to try if you want to make it last a bit longer until you can get a new one or fix it.
Mar 24, 2012 | Sceptre X32BV-Naga 32 in. LCD TV
Sony wega KSD-R60XBR1 green screen that can not be adjusted no matter what input is used or adjustment through onscreen tv options. how do i knw if it is the color wheel, light engine, or just a bulb
It is light engine problem in your Sony KDS-R60XBR2 lcd rear projection tv.
This tv does not have any color wheel because of its light engine technology.
Lamp is just light source that provides bright white light to light engine and its working properly.
Light engine will be replaced to fix green screen problem.
If you tv model is other than above mentioned, let me know to revise this answer.
Hope these info will help you.
Thanks.
Nov 17, 2010 | Sony KDS-R60XBR2 Television
My monitor screen is a bright green color
Please check all the pins at both end of the VGA cable, also try it on another PC also since the problem can be in the video card. We need to narrow dow the problem first.
http://s807.photobucket.com/home/budm/allalbums
Apr 28, 2010 | Sony SDM-HS73 17" Flat Panel LCD Monitor
Screen dim, black has green in it, contrast and brightness = shin
Since you have replaced the Color Wheel, it sounds like you have not adjusted the Index Delay in the service menu. First reset all of the picture settings you have adjusted back to original factory settings. Then on your Samsung TV Remote and with the TV OFF, Press Mute,Power,123. This will turn on the set and put you in the Service menu. Look for the top setting and select or scroll to the OPTION setting and select and look for INDEX DELAY and select that. Once you have the Index Delay selected use the right and left buttons on the remote to adjust for a picture the has no abnormal coloring and while looking at a program adjust for when the blacks look black with no abnormal coloring. Once that is done, turn off the set then turn the set back on. Now the picture should look normal.
Apr 03, 2010 | Samsung Televison & Video
The tv picture looks like should be wachting it whith 3d glasse
This is a very common failure on Projection TV sets. Its called a convergence failure. Here are some common symptoms.
  • Screen looks 3D
The other common problem is cloudy lens fluid. After many years the coolant in the blue and green lens will become cloudy and cause the screen to look dull, red/orange, bright white, etc. You may even see halos around objects on the screen.
You can see some example photos and find a solution here on Fixya.
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Nov 15, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Red exclamation mark keeps flashing. No message on screen, just a bar going round and round the periphery of the screen. Printer will not work. The round green power button remains on, without flashing....
i've looked it up and seems that it's a common problem and you need to flicker the CD door up and down a bit till your printer recognizes it's fully shut!!!
stupid HP can't get their stuff to work properly
hope i did a better job
:D
Oct 23, 2009 | HP Photosmart D5160 InkJet Printer
It has a very dark screen, I can barely see my
Check the pins on both end of the connector, make sure they're straight other wise, reposition it with fine long nose pliers. Make sure the connectors are push and screwed tight also. Let us know!
Oct 10, 2009 | Samsung SyncMaster 205BW LCD Monitor
Hitachi 61SBX59B 61 inch has brightness and color problems
I would say the crt's are at the end of their life.
Sep 09, 2009 | Televison & Video
Rear projection convergence issues
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
  • Halos around objects
  • Red/Orange looking
Example Photo:
You can see more examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 24, 2009 | Sony KP-53V80 53" Rear Projection...
Sony KP-51WS510 51" Rear Projection HDTV-Ready Television Logo
135 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
