Question about RCA RT2280 System
Chk spkr comes on and system wont power up - RCA RT2280 System
5 Suggested Answers
techman
  • 3130 Answers
SOURCE: chk spkr error message
Your problem is the output IC's The case where you say the speakers buzz tells you theres a short in the audio outputs. If your unit didnt shut off, the speakers would fry and the unit would also smoke. These are solid state devices and are soldered in, and are not concidered user serviceable parts, unless you know how to solder and trouble shoot Stereo systems. This is a job for the pro if you want it fixed. Good Luck
Posted on Jun 22, 2006
tech48
  • 624 Answers
SOURCE: chk spkr
That message means that you have a bad speaker or you have a bad amplifier IC most of the time. The amp circuit could have some other problem, but more times than not it is the amp IC.
How to check if it is the speakers or the amp circuit:
Unplug the speakers and turn it on. if you do not get the error message you have a bad speaker. If you do get the error message you have an internal amp problem. Then start plugging in speakers one at a time. If the unit turns on and stays on for a few minutes, turn it off and then plug in one more speaker. Keep doing this unit the unit gets the error message and when it gets that message you know that the last speaker you plugged in is the bad one.
Now the bad news
RCA no longer sells parts for their audio equipment. When the supply they have on hand right now is gone, thats it, no more RCA parts.
Now the good news.
The amp IC they use is a generic type that you may be able to get from another source.
But that is only good news if the amp IC is bad. It is the likely suspect, but without troubleshooting it on a test bench with the proper equipment, that can only be a good guess.
If you have found this help to you a good rating would be really appreciated.
Posted on Jun 22, 2008
dunnbiker
  • 8546 Answers
SOURCE: CHK SPKR appears an turns off the system
It means to check your speaker connections for shorts.
Posted on Feb 20, 2010
  • 34763 Answers
SOURCE: what does it mean when u push the power button and the words ''chk spkr'' flashes on the display and still wont turn on??
The system connects to speakers with a certain impedance, i.e., 8 ohms, 4 ohms, etc. If you have connected the RCA speakers there may be a bad connection or the speaker(s) may be defective
Posted on Dec 08, 2012
What does it mean when u push the power button and the words ''chk spkr'' flashes on the display and still wont turn on??
Dec 08, 2012 | RCA RT2250 System
It says chk spkr when i try to turn it on how do i get it to work agaiun?
You probably have a blown channel. but check for a shorted speaker wire or bad speaker. Remove all speaker wires from the rear of the receiver if it still says check speakers when turned on, then one of the output channels is bad.
Feb 12, 2011 | RCA RT2500 System
The display says "CHK SPKR"
It's telling you it thinks tghere's a short on the speaker outputs. With NO speakers, that is bad.
Generally speaking, an amp protects itself from heat, shorts and overloads.
Overloads can be from excessive periods of high output and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced hands-on tech.
Jan 24, 2011 | RCA RT2500 System
I'm hooking up my sony player to a nissan versa and the colors are confusing and I'm tryna get it to work , and it wont
Car Colors (Assuming NON-Rockford factory system)
4-6 speaker system.
Accessory 12 Volt L.GN
Constant 12 Volt BN
Chassis Ground BODY
Power Antenna
Remote
Illumination OG
Dimmer (-) Bk
Left Front Spkr + WT
Left Front Spkr - BN (PK @ Spkr)
Right Front Spkr + GN
Right Front Spkr - L.BU (RD @ Spkr)
Left Rear Spkr + VT (L.GN @ Spkr)
Left Rear Spkr - RD (GY @ Spkr)
Right Rear Spkr + L.GN
Right Rear Spkr - GY
CLICK HERE for generic wiring tips for your radio.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 19, 2010 | Sony XPLOD CDX-GT200 CD Player
Feb 19, 2010 | RCA RT2280 System
My speakers wont work they appear to be on and theres no sounds coming from them, they are hooked up correct
try with other headphone or spkr to figure it out whether ur spkr is fine or not. Or have u mute the master volumes of your system sound ?
May 02, 2009 | Lenovo 3000 J Series 1.80G VBE PC Desktop
RCA rt2500 "CHK SPKR" comes on when i turn it on.
"CHK SPKR" Check Speakers. Remove all speaker wires and turn on receiver. If it still says check speakers, you have an amp that needs output transistors or possibly just soldering of an emitter resistor but thats rare.
Dec 28, 2008 | RCA RT2500 System
Chk spkr error message
Jun 22, 2006 | RCA RT2280 System
Open Questions:
See all RCA RT2280 System Questions
RCA RT2280 System Logo
61 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
