Question about ASUS K8V-MX Motherboard
Need to get back my ht frequency to 800mhz
Put new cpu in amd 64 3.2. and my ht frequency as gone from 800mhz to 400 mhz, and can not get it back to 800 please help thank you.
I havet mathor board disk and im trullt too needy to intall thast driver
Posted on Nov 02, 2007
Processor upgrade
Feb 24, 2015 | Max Computers & Internet
Athlon processor upgrade assistance:
Go to this link:
Select the model motherboard you have and click on the CPU support link, it will show you a list of CPU's that are supported. You have a socket 939 board and AMD CPU's are now AM2, AM2+ and AM3 socket, which are 940 pin. It may be difficult to find a new CPU for your motherboard that is new since they have not been made in awhile.
Feb 09, 2010 | EliteGroup MB ECS 741GX-M SIS741GX 462...
I have at current a AMD sempron 3400+1.80GHz processor,socket AM2(940)core VID 1.100V,core speed 1002.2 MHz,bus speed 200.4MHz,HT link 801.7 MHz,stepping 2,L1 data and inst 64 KBytes-2-way,level 2 256...
The main thing is before you go swapping cpu there are some things to consider. 1. the new processor may draw more power than your current power supply can push out. 2. it will probably generate a lot more heat...both are bad..
But if you insist you can get away with an Athlon 64 X2 5600 or 6000+ cpu be careful though because some have different voltages which may not work with your board.
hope that helps.
Feb 03, 2010 | Dell Dimension C521 PC Desktop
Can I use DDR2 800 MHz RAM on GA-K8NS-Ultra-939-Socket-939 MBoard
I don't think that that motherboard will accomodate the DDR800 you probably need a DDR333 or DDR400.
Calling the manufacturer support will render better information because they made the board. The memory you refer to may not fit the slot for this particular motherboard.
Aug 13, 2009 | Computers & Internet
Bus Speed 200mhz instead 1000mhz
Jan 08, 2009 | ASUS M2N-E Motherboard
Cant run 3E GHz 800 FSB L2 cache 1MB cpu on a ASUS P4P800s-x
here are the specs.
CPU FSB DDR DIMM Type Memory Frq.
800Mhz PC3200/PC2700/PC2100 400/333/266 Mhz
533Mhz PC2700/PC2100 333/266 Mhz
400Mhz PC2100 266 Mhz
the CPC and the moemories meets these spec. then you shouldn't have problem.
since you didn't spec the meories. I am assuming that the meories are within specs.
but, from what you say about, I suspect the memories is not up to part. looks like the meories are in PC 2100 range.
Nov 14, 2008 | ASUS P4P800S-X (610839118175) Motherboard
New 256 Mb RAM in Compaq Presario 17XL2 not recognized
500Mhz CPU use DDR333/400 memories. majority are used in MAC.
800Mhz CPU use DDR2 400/533/667 Mhz.
look like either you cna change the CPU or change meories again to match them up.
Nov 14, 2008 | Computers & Internet
Hi i have a ram issue
specs for motherboard mach speed venom
Memory type ddr2 sdram
Memory slots 2 X 240 pin slots
Supported ram 800mhz 533mhz 400mhz 667mhz
I dont know if this will assist you in sorting problem out
Aug 02, 2008 | Mach Speed VENOM MSA2-6100V Motherboard
RAM not running at full speed
Go to page 33 in your manual, see DRAM Clock/Drive Control & press enter. You can tweak your memory to run faster however your manual suggest not too. Hate to see you burn it up. As you will see everything is set to Auto:
Max Memclock (Mhz) [Auto]
1T/2T Memory Timing [Auto]
CAS# latency (Tcl) [Auto]
When DDR Timing Setting by is set to Manual, use this item to set the DRAM frequency. Would be nice to have a side panel fan blowing on your memory.
Link to your board.:
Jan 04, 2008 | EliteGroup K8M800-M2 Motherboard
Your M/B support Socket 462 (also called Socket A) is a PGA socket designed for AMD K7 family of processors. This socket can be used with AMD Athlon and Duron processors ranging in speed from 600 MHz to 2200 MHz (3200+) and with bus frequences ranging from 100 MHz to 200 MHz (400 MHz DDR)
Athlon (Socket A) (600 MHz - 1400 MHz)
Athlon XP (1333 MHz - 2333 MHz, or 1500+ - 3200+)
Athlon MP (1000 MHz - 2133 MHz)
Duron (550 MHz - 1800 MHz)
Sempron (socket A) (1500 MHz - 2200 MHz, or 2200+ - 3300+)
Mobile Athlon 4 (850 MHz - 1400 MHz)
Mobile Athlon XP-M (Socket A) (1200 MHz - 2200 MHz, or 1400+ - 3000+)
Mobile Duron (650 MHz - 1200 MHz)
I Recommend to go for Athlon XP with good cooling fan. :)
Dec 18, 2007 | EliteGroup K7AMA Motherboard
ASUS K8V-MX Motherboard Logo
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
