Question about Bosch PMF 180 E Multifunctional Tool - 180 W
Repairs to pmf 190 multifunctional tool - Bosch PMF 180 E Multifunctional Tool - 180 W
Have a panasonic DP-190 multifunction and I cannot pull the paper tray out
My take on tjis is...the tray is already not functionig so forcing cant make it much worse. Look in tray from rear annd see if lift plate is binding. Try to push tray from rear.
Aug 28, 2014 | Panasonic Workio DP-190 Multifunction...
Bosch pmf 190e just stopped working.fuse ok lead ok
I know this is an OLD post - but just in case anyone else comes across this question/problem - the fix is here - worked for so many people . . . http://jb-service.blogspot.co.uk/2013/04/bosch-pmf-180e-multi-tool-240vac.html
Aug 21, 2013 | Bosch Pmf 180 E Multifunctional All...
Bosch pmf 180e stator connection broken, how to repair
I've had this / a similar problem .
Note: Always disconnect the cord before opening an electrical machine!
The stator has four connections, There should be about 20ohm resistance if you measure between two connections on the same side (one at bottom where an orange lead is attached and one at the top (not orange)).
One stator winding was cut exactly where it attached to the connector. (Probably due to vibration in combination with a not-gentle fastening method) Touch the thin copper wire gently at each connector to see if any is loose.
To fix it, I gently unwound the wire one turn, cut it to a suitable length, used a fine sanding paper to remove the isolation at the end, wound the wire a couple of turns around the connector and soldered it to the fixed part of the connector.
Aug 17, 2013 | Bosch PMF 180 E Multifunctional Tool - 180...
Getting error j43 on workio 190, but there is no paper jam
yep
it is common error for dp-180/190.
and the usual cause of that are worn out 2 bushings of heat roller
what you can do with that is to clean the fuser unit esp. the bushings of heat roller.
well off course the safest way is to replace the whole fusing unit.
that's it. :)
Feb 08, 2010 | Panasonic Workio DP-190 Multifunction...
What is the cost of toner? and does it support microsoft vista operating system
panasonic software for dp_180/190 supports windows vista and windows & as well. :)
Dec 16, 2009 | Panasonic Workio DP-190 Multifunction...
Panasonic DP-190. How do I configure the printer to automatically print a confirmation page for faxes?
press the fax button, then press
function-7-4-start-1-2-start-2"should says always"-start-stop-stop
your good to go.
Jan 23, 2009 | Panasonic Workio DP-190 Multifunction...
Bosch PMF 180 E Multifunctional Tool - 180 W Logo
78 people viewed this question
Top Bosch Tools & Hardware - Others Experts
Awesome12
Are you a Bosch Tool and Hardware - Other Expert? Answer questions, earn points and help others
