Question about OKI Electric Industry C3520 Laser Printer
Oki c3520 mfp scanner home sensor error
Scanner home sensor error
4 Suggested Answers
Touch2Heaven
  • 145 Answers
SOURCE: toner sensor error
The toner cartridge has a small window from outside where the dark blue handle. You should turn a photodrum gear wheel while the window will not open. After that insert a drum unit and work.
If you have "start cartridge" that doesnt work....
Posted on Oct 18, 2008
  • 97 Answers
SOURCE: toner sensor error on an Oki C3520 Laser
Check the little switch/door on the right hand side of the drums.
This has worked successfully for me.
Symptom:
After replacement of a C3530 Image Drum, the message, "Toner Sensor Error" is displayed.
0.10a?openelement&fieldelemformat=gif
Cause:
The plastic shutter in the ID is fully or partially covering the toner sensor window.
Resolution:
Move the cover upward to allow for the sensor to become fully exposed prior to reinstalling the drum.
0.106?openelement&fieldelemformat=gif
Posted on Dec 07, 2008
  • 95 Answers
SOURCE: PRINTER NOT WORKING
That is a fuser code. Turn off and take out fuser(the part that gets hot) and inspect it. Put it back in and turn back on. If code is still there replace fuser.
Posted on Aug 02, 2009
Where is the sensor lock switch?
The scanner lock is situated at the left side of the flat bed scanner. switch it to UNLOCK.
Sep 04, 2014 | Oki Brand Oki MB480 MFP Multifunction...
Oki C5350 error 563
563 I usually drum code reset, some OKI machine have sensors in the side frames they look like a little round window, clean with Q tip, I will assume you have replaced the drum, right?
May 05, 2014 | OKI C5510 MFP All-In-One Led Printer
Error 3100 in kyocera fs1030 mfp
ISU home position error. Check the scanner lock to make sure it is not engaged. If not it could be the home position sensor for the image scanner unit.
Dec 17, 2013 | Kyocera FS-1030MFP Mono Multifunction...
check for dust or any forgien particle in the scanner unit clean it ,
Jun 06, 2013 | OKI C3530N Color MFP Printer
PRINTER NOT WORKING
Aug 02, 2009 | OKI Electric Industry C3520 Laser Printer
OKI 3530 MFP Service call: 150
Your error 150 is the toner sensor board not making contact with a drum and therefore not blowing its fuse. Remove the Main board and you will find the toner sensor board behind it. It has a lot of metal contact springs and you will most probably find one is out of position and just requires removing and refitting. If still not working the part number for the board is: 43614901 OR-Board-PRS
Good luck.
Jul 09, 2017 | OKI B4350 Laser Printer
Toner sensor error
Oct 18, 2008 | OKI Electric Industry C3520 Laser Printer
Toner sensor error on an Oki C3520 Laser
Symptom:
Cause:
Resolution:
OKI Electric Industry C3520 Laser Printer Logo
79 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
