How to drain and clean kelvinator kl 15 TL air bubble washing machine
2 Suggested Answers
Buffalo12980
  • 625 Answers
SOURCE: new washer not washing
Unplug the machine for about 20 minutes so the computer can reset. First load?? Machine is under manufacturer's warranty get hold of the company who sold it to you - ask for a replacement.
Posted on Sep 15, 2007
Stopped spinning after washing,water remains in the tub
usually what happens here is that the pump to expel the water is not functioning, the normal problem here is a coin or hair grip gets lodged in the pump and stops the impeller from turning, generally the pump can be removed and opened up to remove the offending article and allow the impeller to operate again, once cleared of obstruction reassemble the pump and refit it. ( be aware, as the machine is still full of water, when you remove the pump the water will flood out so you need plenty of towels so soak up the water that spills.
Sep 24, 2016 | Washing Machines
My Kelvinator kl 15 tl toplaoder washing machine is very noisy during spin cycles and often becomes unbalanced.
if the noise is a rumble, then you have bearings failing. if it's a clunking then you have an issue with the springs. springs you can replace yourself, bearing / seal replacement is a little more in depth.
Jun 22, 2013 | Kelvinator Washing Machines
Air power bubble washing machine model -dwf -1150p
Daewoo Airpower Bubble Wash Machine Model - DWP - 1150P
My Machine does not want to spin anymore. It makes a knocking sound and then stops and starts filling up with water again, then drains it and wants to start spining and again makes a loud knocking sound and the repaets the already mentiond sycle. Can you help me with this problem? Does Daewoo not have service centers for these machines?
Apr 21, 2013 | Washing Machines
Washing machine Airturbo stops at 17 minutes and 7 minutes and error code SE appears. what is to be done washing nachine is one year old only
  1. Open the filter-cover near the bottom of the machine. Unscrew emergency drain cap by turning it to the left and drain off all the water. Unscrew the filter cap and take it out. Wash any dirt or other material from the filter. Make sure the drain pump propeller behind the filter is not blocked. Replace the filter cap. Replace the filter-cover.
  2. The Water Drain error can be cleared by turning POWER SW OFF and back ON.
  3. If the water only trickles out of the draining hose, pause the washer and blow air down the hose, you should hear the water inside the unit bubble a few times. If you don't hear bubbles, the hose is still blocked.
  4. Drain the load, empty the washer of clothes and try running a rinse & spin cycle. You should repeat this until the water runs clear from the drain hose.
  5. If the machine still fails to drain, you may need to replace your Drain pump.
Feb 26, 2011 | Samsung Washing Machines
New washer not washing
Sep 15, 2007 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
