Question about Powerwasher 2400psi 2.0gpm Pw2420 Gas Powered Pressure Washer 4
Motor runs for 3 seconds then shut off
Is it ok to start the motor without connecting water to it
  • Anthony Taylor
    Anthony Taylor Jul 08, 2015
    i hear that it is not ok to start the motor without the water connected to it. I have the same problem
  • Anthony Taylor
    did you break down and take the unit into the repair shop?
    Master:
  • 969 Answers
Change oil. 30w
Posted on May 17, 2016
Bosch Rotak 32R. Why does it keep shutting down in 4-5 seconds??
Check gas cap for proper venting, will it run better with cap off.
Feb 13, 2016 | Garden
How long can a musso 622 engine run without water
Hi Stefan:
I would not even consider trying to run the engine without coolant.
Diesel engines run hot and the engine will be ruined if run without coolant.
Sep 18, 2015 | Cars & Trucks
Can I Run 3 Phase Motor On Y Or Star Connection Without A DELTA?
Some motors need a Y and Delta, with a special switch, to start up, you start with the Y. the motor starts turning, but does not give full power. after a few seconds (depends what the manual says) you switch to delta, to get full power. To let it run on full power in Y you need 1,4 times the voltage.
If everything runs fine, you won't have damaged anything.
Jul 13, 2014 | Baldor RM3120 HVAC Fan and Blower Motor,...
Accidently got 220 volts for 3 seconds, then shut off. will not re-start, how should I proceed?
Look for reset button, hopefully reset would have tripped. If compressor will not power on, remove cover to pressure switch and examine contacts for burned. If burned, temp. connect 110v to motor side of switch, (black- black and white-white) if motor runs ok replace switch. If motor does not run check capacitor for proper valve, replace as needed. If cap tests ok and motor will not run check motor windings for melted white strings that bind wiring. If windings look burned most likely you will need to find used motor from repair center.
Dec 01, 2010 | Makita MAC5200 Electric Powered Air...
Karcher 320H i have the same pressure coming out as i put in from the tap, the motor is running ok
You have an air lock in the pump and or piping.
  • Open all drain cocks and remove the spray hose
  • Connect the inlet water hose and turn it on slow
  • allow water to run from all open ports for 2 minutes or so
  • leave the water running - close drains start motor
  • Shut down reconnect spray hose restart
  • You should now be smiling
Mar 08, 2010 | Plumbing
Washer agitates, drains OK, but spin doesn't start
Timer is defective. Your unit has a netural drain. When finished agitating, the shuts down and then starts up reversing to drain and spin. On the initial reverse start, the water drains without the transmission spinning. After a timed period 3-4 minutes, the timer is supposed to pause, stopping the motor for a few seconds. When the motor stops again, the transmission shift to the spin cycle and when the timer resumes power tothe motor it should spin. You are doing the same thing when you lift the lid...stopping the timer and then the tranny shifts and when you set the lid down, the washer spins. Replace the timer.......
Feb 09, 2009 | Kenmore 23822 Top Load Washer
Maytag mah4000aww, tub overfills
Have you changed your door latch wax motor yet... If you have the brown actuator pin then you want to chuck that wax motor out of there quicker than spit! You want the redesigned wax motor with the black actuator pin. I know of folks where the wax motor failure caused the timer and /or water valves to act up... See www.neptunewaxmotor.com for disassembly photos and other Neptune information.
Jul 01, 2008 | Maytag Neptune MAH5500B Front Load Washer
GE Nautilus 4800 Dishwasher/Shuts off/ No water draining out
It may be the motor start capacitor or the motor or the wiring to it. Some units have a built-in switch that shuts the unit off if the motor doesn't start turning after a short interval. However, if it drains it usually means the motor runs enough to pump it out. These units usually stop draining when the fill switch opens at the lower level.
Nov 29, 2007 | GE Nautilus 24" Built-in Dishwasher
Powerwasher 2400psi 2.0gpm Pw2420 Gas Powered Pressure Washer 4 Logo
162 people viewed this question
Top Powerwasher Garden Experts
andy just round the...
Level 1 Expert
Mike Carew
Karl H
Are you a Powerwasher Garden Expert? Answer questions, earn points and help others
