Question about Conair Health & Beauty
Scale ww89w reads 150 - Conair Health & Beauty
My scale reads full when i turn it on whats wrong
Most scales will have what is called the "TARE" button... push the "TARE" button when nothing is on the scale and it should 'zero-out.'
Once it is zeroed, it should give honest weight readings.
May 13, 2016 | Health & Beauty
My Taylor Lithium scale reads a message "BAEE" What does this mean? I no longer have the booklet. Thanks.
my scale does the same thing. battery reads 2.85 volts. could that be a low reading for a lithium battery with a 5 yr guarantee? hmm.
Dec 13, 2010 | Taylor & Digital Scale Lithium Scale
This is a new scale. Every time you get on it a new reading?
See if this helps.
Step on gently and stand very still. Step off and press/tap with your foot the center of the scale to reset to 0.0 and step up again and be very still while it reads your weight.
Mine gave a little different weight but after I tried again I had two readings the same and the readings were what I expected. So if in doubt I read twice. If I am very still when I step up mine give same reading.
I hope there is nothing wrong with your new scales.
Happy weighing.
Aug 15, 2010 | Conair Large Digital Display Memory...
Why dose my proscale orion 150 pocket scale say out2 when I turn it on, and will not change to 0.00?
It's possible that the tray is pushed into max position.
Incurred due to an overload on the tray for a long time or a unprotected transport probably ...
Try turning it on, while holding the tray pulled up (eg scissors sliding under the tray to keep it elevated) and if the scale will show you "0.00", the tray is pressed...
Jul 27, 2010 | Tanita 1479V - Digital Pocket Scale /...
How do you program users?
Storing and Recalling Weights
1. Your scale can store and recall up to 5 weights. If your scale has one button,
weights can be stored for one user. If your scale has two buttons (User and
Save/Recall buttons), weights can be stored for multiple users.
2. Tap center of scale platform with foot and wait until "00.0" appears.
3. Stand on the platform without shifting or moving until weight is displayed.
4. For single user scale: When weight reading appears on screen, step off the
scale, press Save/Recall button and hold for about 2 seconds to save the
reading.
For multiple user scale: When weight reading appears on screen, step off the
scale, and press User button to select a user number. Then press Save/Recall
button for 2 seconds to save the reading.
5. Weight reading blinks twice, then becomes stable. A small number (1-5)
appears in the upper right hand corner of your display, indicating which of the
5 weights is displayed. (Once you have 5 weights in memory the current weight
always saves as "1" and the oldest reading is eliminated.)
6. Weight reading is saved. Press Save/Recall button to review the last 5 weights or
let the scale shut down automatically. (Note: until you have 5 weights stored in
memory, the display will show the number and "–" for each weight for which
no data point has been stored yet; i.e. "3 –", "4 –", "5 –" if only 2 weights
have been saved.)
Hope this helps!!
Feb 09, 2009 | Precision Camera Weightwatchers WW70 Body...
Printed subject comes out too small to read I would like it to be a normal size or number 10 or 12 What do I have to do?
increase your font size change the layout or template you are printing from or scale the print job 150%
May 28, 2008 | HP Office Equipment & Supplies
Health & Beauty Logo
Top Conair Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Julia Tatspaugh
Level 1 Expert
Andrew Taylor
Andrew Taylor
Are you a Conair Health and Beauty Expert? Answer questions, earn points and help others
