Question about Mtd Products Yard Machines 158CC Tiller
Huskee tiller will run but cut off after a minute-could be the governor
We have cleaned the carbuerator twice and cleaned out all the fuel lines and the filter. We think that it might be something to do with the governor. The tiller will start and run for a few minutes, but will then die out as if it is not getting gas. When you engage the tines, it cuts out. We have cleaned out the air filter, changed the gas, correctly gapped the spark plug, and are now out of ideas.
4 Suggested Answers
  • 15 Answers
SOURCE: Tiller won't stay running
Hmmmm.....it sounds like restricted fuel flow to me, but explain "rebuilt the carb" so I can get an idea on what you did.
Though it sounds right off like you whooped it good and got the basics.
Right off, go back through the "system", check the fuel flow, check that spark on the plug. Eyeball for any loose wires (E.G., Kill Switch, etc.) that are grounding (you never know!)
Stick to KISS on this one, since it ran before the carb got bad and got rebuilt, it will be one of those things you replaced, rebuilt, or changed. Sometimes, it is the SMALLEST thing......
Posted on May 28, 2009
wiringlunati
  • 576 Answers
SOURCE: i have a 2003 huskee rear tine 5.0 when i spray
Did you clean out all of the tiny holes in the main jet of the carburetor? I assume you also put fresh fuel in it as well. One other thing, a compression leak (loose spark plug, bad head gasket) can make it act like it's starving for fuel. Good luck. I'd still place my bet on the carb having one or two holes plugged in the main jet.
Posted on Mar 17, 2010
  • 6468 Answers
SOURCE: tiler only runs at full choke
if its a older briggs engine with the spark plug on the top there is a screw on the carb turn it out a little at a time if not take it off and clean it out
Posted on Apr 03, 2012
I have a huskee rototiller that dies when you engage the tiller
HAs it sat for a long time without being used? Sounds like the governor on the carburetor might be sticking. Means when you put a load on the engine the carburetor supposed to increase if you flew in if you've let it sit for quite a while, who might be going to need a good cleaning
Jan 19, 2015 | Garden
Huskee snowblower help
so you only have idle speed ?
it must start hard
there is a governor but not normal to go out of adjustment
check carb linkage and springs
does your thottle lever move anything when you move it ( as far as throttle plate or any linkage?
Oct 14, 2013 | Tecumseh Snowblower Snow Blower Starter...
2007 MTD Tiller with a 5hp Honda engine
I got to think there may be a loose connection in the ignition circuit. That is where I would be looking.
May 21, 2012 | Yard Machines Garden
Small hole on carbuerator opposite where gas hose connects leaks
perhaps there was a hose on/in it at one time cause it sounds like an over flow/vent.
Apr 18, 2010 | Garden
Troy bilt bronco model # 12180starts & idles fine. How do you set or fixthe governor . It runs at idle speed all the time. I can force the governor open and it with run fine until I turn loose of the...
clean and lube around butterfly arm and "windvane' under engine cover.most governors are controled by air coming off finns on flywheel also check to see if you have return spring broken or missing
Mar 25, 2010 | Troy-Bilt Pony Garden Tiller
I have a 2003 huskee rear tine 5.0 when i spray starting fluid in it's runs 4 a few seconds then dies. I have cleaned the carb and the gas tank and line, I still seems that it is not getting fuel
Mar 17, 2010 | Mtd Products Yard Machines 158CC Tiller
My push mower has a 6.5 B&S and will only run if you keep pumping the primer i already disassembled the carb and cleaned the jet also checked bowl float all ok
eeeeerrrrrrr, breaks and scrap it...lol
well you saying that it stays running only while pumping the primer tells me that it is running lean(carb needs adjusting), it maybe the fuel line is plugged not allowing enough fuel to flow.
May 01, 2009 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
The engine stops after fuel in carbuerator is depleted.
Trace the fuel line from carb to tank,if it has a shutoff it will be there.
Mar 24, 2009 | Garden
Mantis Tiller
check the fuek lines for hole and leaks, check the fuel filter and clean if necessary. remove the carbuerator and inspect the gasket; it should be soft and flexible, if it seems hard or brittle replace it. clean the carb with carb cleaner sray (available at any local auto parts store) and compressed air. make sure you get inside the small fuel rail holes. check the primer bulb for pin holes and seating/sealed properly. if that doesn't work have the carb repaired at a service center or replaced.
Nov 13, 2008 | Mantis Tiller
Mtd Products  Yard Machines  158CC Tiller Logo
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
