Question about Onkyo TX-SR602 Receiver
Volume keeps going up
When I press volume up it continually goes up, same thing happens when I turn the volume down. This only happens with the remote.
  • dan_drowner Jun 19, 2009
    I've done this - but it seems to still be a problem. Its with both up
    and down, pressing it again doesn't help - but immediately going to the
    receiver and turning the dial does, so its not a physical sticking problem
  • 757 Answers
It is possible then that the button is sticking. You can take it apart and clean around the rubber insert with a cheap bottle of rubbing alcohol and a cotton swab. While you're in there you should clean up all of the contacts too, it'll help save on batteries.
Posted on Jun 19, 2009
I have my brothers droid moto phone he passed away and I want to get it hooked up to Verizon but do not know his password. How can I clean the old password off of the phone and install my password.
Hi @Rock Aduh , are we talking about the password to go in to the phone? If it is, please perform a factory reset.
1. Ensure the device is powered off.
Note If the device doesn't respond to input, press and hold the Volume Up/Down button then press and hold the Power button. When the device screen goes blank, release the Power button while continuing to hold the Volume Up/Down button then proceed with step 3.
2. Press and hold the Volume Up/Down buttons then press the Power button.
Note When presented with the Boot Mode Selection Menu, release all buttons.
3. Press the Volume Down button to tap Recovery then press the Volume Up button.
4. From the DROID triage screen:
a. Press and hold the Volume Down button.
b. Press and release the Volume Up button.
c. Release the Volume Down button.
5. Select wipe data or Factory Reset.
Note Utilize the volume keys to highlight and the Power button to select.
7. Select Yes -- delete all user data.
Note Data wipe may take several moments.
8. Select reboot system now.
Note To set up the device after the reset has completed, refer to Initial Activation and Set up.
Hope this helps. Factory Data Reset Powered Off DROID RAZR RAZR MAXX by MOTOROLA
Oct 30, 2017 | Verizon Cell Phones
Volume keeps going down to zero
Emerson volume keeps going down Questions & Answers ...
www.fixya.com > Forum > Tags > volume keeps going down
Emerson volume keeps going down related problems. Ask your Emerson ... myEmerson TV. It turned itself down to zero and stayed on the screen and wouldn.
Emerson Flat Screen TV volume trouble? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Aug 10, 2011 - My Emerson 32 inch does similar things, volume just goes to 0-100 and stays there. ... Why is the volume on my Emerson flat screen TV not working and how could i fix it? Whats wrong with my Emerson Flat screen tv? Why is the volume on my Emerson flat screen TV not working ...
Jul 13, 2013
My son has an Emerson tv it keeps turning down by itself. Anyone ...
Aug 24, 2006
More results from answers.yahoo.com
Emerson TV problem ' Techlore
Dec 15, 2015 | Emerson Televison & Video
This is a problem with the sound select board, and there is no real solution. One thing to try is to press the manual volume up or down buttons on the side of the TV and keep them depressed to see of remote volume control is restored. This over rides the volume creep issue. I solved this by shorting the UP control to ground and the creep went away, but there is no manual volume control any more, but the remote still works.
Jun 23, 2014 | Sanyo Televison & Video
Hey i've had my galaxy s2 for a week today, trouble is i've forgot my samsung password and when i click on the link it sends me an email but it dont go to the reset or anything nothing happens
PRESS AND HOLD VOLUME UP + Home Button
Keep pressing these 2 buttons + press Power button for 2-3 Seconds
Release only power button, but KEEP pressing Volume up + Home Buttons
With Volume down select wipe data/factory reset (3rd) > Press Power
or
Turn off the i9100 S 2 phone or take out the battery and reinsert it.
Hold the Volume Down button
Press and release the Power button
Select Clear Storage by pressing the Volume Down button
Press Volume Up to confirm i9100 master reset
May 28, 2011 | Samsung Cell Phones
TV Volume goes up by itself and remote wont work
There are 2 reasons that this is happening in respect to the problem commencing after your daughter has cleaned the tv. Either your daughter has sprayed the volume button with cleaner and fluid has got into the the graphite pad under the button and conducting as though the button is being pressed continuously..or she has put too much pressure on the button if it is a metallic plate contact switch.One way to find out is by pressing the down volume button.does it it click ? if it does.try the up volume..If that doesnt click the problem is the metallic plate is dented in making contact hence a new switch. Another cause ive seen is cleaning the remote control with cleaner and fluid has got into the remote and it sends signals to the tv all the time..If the remote control is hidden under a cushion and the problem stops, then the remote control is at fault and needs drying out..Hope this helps :)
Aug 04, 2009 | Apex Digital PF2025 20" TV
Vizio 37 inch channels and volume changing on its own
The circuit or integrated circuit being controlled has likely failed. You might try 'resetting' it by pulling the AC plug overnight. If that has no effect, a repair is unavoidable. This model seems to be developing a number of different problems.
Jun 14, 2009 | Vizio L37 Television
Volume is all the off and will not turn up
sound like ur volume avls(volume limit is on) so go to settings thengo to common settingsin that the second one down should be AVLS or (volume limit) contoller. also does it go up at all or does nothing happen.
Apr 17, 2009 | Sony NWZ-S615F Walkman Video MP3 Player
Volume decreases by itself
maybe defective speaker or audio output ic or shorted capacitor within audio circuit
Nov 09, 2008 | RCA F32648 32" TV
Volume keeps going up by itself
help the volume on my tv keeps going up and no one is touching it! please help. my parents cannot afford a new tv
Mar 29, 2006 | Apex Digital PF2025 20" TV
Onkyo TX-SR602 Receiver Logo
139 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
