Question about Magnavox 50" LCD HDTV 50MF412B
Setup base for 50mf412b - Magnavox 50" LCD HDTV 50MF412B
Sound drops auto
Please, please, be more specific ?
Nobody can answer THAT question.
Peace-
Feb 14, 2016 | Magnavox 50mf412b Blk 50& Lcd Hdtv 1080p...
Powers off about ten seconds after turn on
no signal at selected input ? as this is symptom of this
Oct 28, 2015 | Magnavox 50" LCD HDTV 50MF412B
Firmware update magnavox
Checked the manufacturer website and it does look like there is one available. You can get the manual here though: MAGNAVOX
Aug 18, 2014 | Magnavox 50" LCD HDTV 50MF412B
Magnavox 50" no picture
Could be a failing power supply
Mar 19, 2014 | Magnavox 50" LCD HDTV 50MF412B
No sound on magnavox 50mf412b
Check the speaker/s first. If found OK, check and replace damaged component/s at its audio output stage circuit. Check all the soldering terminals at this stage circuit, for any loose solder terminals. Re-solder all the suspected solder terminals, by applying a little more solder. If you wish to get some details, check the site linked here. http://electronicshelponline.blogspot.com/ Pull up older posts. Check the site in 'Mosaic' view. It will make search easy.
Jan 03, 2014 | Magnavox 50" LCD HDTV 50MF412B
Tv problem
It is sometimes possible to message a dead pixel back to life by rubbing the surface of the screen where the dead pixel is with a soft cloth. I have heard reports of it working, but would not recommend it. Also the length of time it lasts is indefinite.
Jul 30, 2013 | Magnavox 50" LCD HDTV 50MF412B
I am trying to install an HP 7460 wireless printer to my HP cpu via a linksys router. My password for the router is 7 letters, and the printer says it has to be 8 letters. How do I change the router...
When accessing the router’s web-based setup page, a log-in screen will appear asking for the router’s password. The router’s default password is “admin.” You should change the password for security purposes.
The router’s password must be changed to:
  • Prevent unwanted users from accessing the router’s web-based setup page.
  • Enable Remote Management.
The router’s IP password can be changed by:
  • Running the router’s setup CD.
  • Changing it on the router’s web-based setup page. For instructions, please follow the steps below.
Changing the Router’s Password
Step 1:
Access the router’s web-based setup page.
NOTE: If you are using Mac to access the router's web-based setup page.
Step 2:
When the router’s web-based setup page appears, click Administration.
Step 3:
Enter the new password on the Password and Re-enter to confirm fields.
Sep 26, 2008 | Office Equipment & Supplies
Magnavox 50" LCD HDTV 50MF412B Logo
18 people viewed this question
Top Magnavox Televison & Video Experts
Tom Chichester
Are you a Magnavox Televison and Video Expert? Answer questions, earn points and help others
