Question about Samsung Televison & Video
Own a Samsung LN-83251D (LN83251DX/XAA. When you turn it on the volume is real low. Volume increases after 5-10 minutes. May I repair this myself?
Volume too low on start up. Increases after 5-10 minutes.
SOURCE: TV volume increases by itself and doesn't decrease or respond to the remote control
Apparently this seems to be a known issue for this model. I called Phillips and they did not even bother asking me to try things like switch off and on again etc...They just said they are going to send someone to pick it up and fix it. I would suggest to everyone to do the same since it has to be free of charge because the problem appears in pretty much every tv set of this model.
Posted on Apr 28, 2008
SOURCE: humming noise with low volume.
I changed my BACKLIGHT setting from "MIDDLE" to "BRIGHT" and VIOALA! That humming noise COMPLETELY DISAPPEARED! :D
Enjoy!
Ken Stephens
Posted on Dec 26, 2008
javswr
  • 44 Answers
SOURCE: Volume increases by itself
This could be a sticky button or a bad key controller! The key controller is the button board, this stream the commands to the main board (main unit). not to hard to replace, if your somewhat handy! But will require the case (back panel) to be removed. Good luck, hope this is helpful!
Posted on Mar 02, 2009
SOURCE: samsung lns4041dx/xaa
Same problem with my set. The volume was either fully up, or fully down (usually down), and other controls didn't work- like I couldn't access the menus and could not adjust the width of the screen/aspect ratio.
I lived with it for about six weeks, then took the back off the TV. Just now it seems to be fixed, but I don't know if it will last.
I disconnected the wire leading to the channel up/down, volume up/down and source board, turned on the tv, turned it back off, reconnected the cable, and everything seems fine now.
Posted on Mar 14, 2009
SOURCE: Samsung LCD Flat Screen TV LN-S2651D - Volume Problem
Volume bar stands at 200 every time i start my Samsung LCD
set the volume down extremely low power the tv down by plugging out and put on again should be then at set volume,the tv's now days have memory so it should start up at volume preset
Dec 21, 2013 | Samsung LN-S2651D 26 in. LCD Television
Low volume on created DVD
Unlike ripping CDs, ripping DVDs poses many challenges for the average user.
Because you need to get audio and video and need to get them synced correctly problems with the final version frequently arise.
One common problem is that the volume is too low.
The solution might seem to be to simply turn up the speakers, but the sound of a low-volume movie cranked up can crackle or distort. Instead, you increase your DVD rip volume by changing it before you begin the rip process.
Increase DVD rip volume with iSofter DVD Rip (see Below).
http://www.dvd-tool.com/dvd-ripper/faq.html
With this program, a window called "Input Settings" allows you to control the volume before you begin. After the DVD is in the computer, you just use the "Volume" slider to increase the output volume. As of November 2010, the program costs $34.95.
Try Aimersoft DVD Ripper (see Below).
http://www.youtubetoipod.biz/software/aimersoft-dvd-ripper.html
After inserting the disc, you simply click "Load DVD" and wait for it to load
(this could take a few minutes).
The "Settings" button presents a volume slider similar to iSofter's.
Push it to the right to increase the output volume.
As of November 2010, the program costs $35.
The free dvd::rip program offers the most customizable settings for the advanced user
(see Below).
http://www.exit1.org/dvdrip/
Not only can you increase the output volume with a volume slider, you can also compress the sound as well.
This is useful for movies with both loud and quiet parts (such as action movies). It reduces the volume difference so you don't have to reach for the remote every five minutes.
Jun 27, 2013 | Corel 9900-65295-00 Pinnacle Studio 16...
What is the secret code to increase the volume of my samsung sgh 750? Volume is too low.
i have samsung sgh j750 and i wanna increase the volume. lastly i got those secret codes but the problem was when i increase the volume nothing changes.
Sep 07, 2010 | Samsung SGH-J750 Cell Phone
SAMSUNG TV WONT TURN ON JUST CLICKS
I just fixed this very same problem. The capacitors are the problem. However, I think that if you have some minimal skills with soldering, you can fix this yourself. You just need to take out the system board, then the power supply parts are on the top right. The bad capacitor(s) will be bulging at the top and possibly have some brown stuff coming out. The ones that go bad are 1000microfarad, 10V, however you can replace them with higher voltage. I got 35V caps from radio shack for 1.59 each. You just need to solder out the bad ones and then put the new ones in and solder. Remember that the negative end goes on the side with the bold black part of the circle on the system board. Then just cut off the extra ends of the capacitors. If you are capable of doing this yourself, you will spend at most 6 dollars instead of however much a technician costs.
Sep 24, 2009 | Samsung LN-S4041D 40 in. LCD HDTV
Volume too low
Chances are there a limit on the volume to keep it from going to loud. If the MP3 has a screen, use it to navigate to a menu and go into it's sound settings. From there, you should be able to raise the max volume to the REAL max.
Jul 07, 2009 | Samsung YP-U3JQB MP3 Player
Samsung HPT4254X/XAA plasma turns off and on by itself, clicking.
had the same problem, same tv... bad connection on a transistor....
Jan 07, 2009 | Samsung HP-R4262 42 in. Plasma Television
Aug 24, 2008 | Samsung LN-S2651D 26 in. LCD Television
My Samsung LN-83251D is not working properly. Instead projecting a picture, it just displays bars and lines. Is my LCD TV broken?
Jul 06, 2008 | Televison & Video
Samsung lns4041dx/xaa
Jun 03, 2008 | Samsung LN-S4041D 40 in. LCD HDTV
Televison & Video Logo
83 people viewed this question
Jerry Greenberg
Jerry Greenberg
