Has anyone seen a z3100 59.3.09 error
I have replace a formmater from a z2100 to my z3100, I seem to be getting a 59.3.09 error when the machine is initializing. I can get into the service menu, but when i try a electronics unit test or ask for unit information it will come up with the error. I have tried the board back in the z2100, and it works ok. I can only think that the firmware are two different version on the formatter and electronics unit(z3100 printer is 7.0.0.3 and z2100 and formatter is 10.0.0.4). Is it a conflict in the firmware version on the formatter and hard drive to the printer?
flopez
  • 161 Answers
SOURCE: CLP-510 SPL-C Error message
SPL stands for "Samsung Printer Language". You are using an USB cable that is either too long (above 6 ft.) or too thin (cheap cables).
The reason why the test page prints is because it is a very simple and small page (thinking on kbyte terms). But larger streams of data do not arrive correctly due to attenuation and the error page prints instead.
If it is absolutely necessary to connect beyong 6 ft, you need either a good quality USB cable (try the Belkin brand found at OfficeMax), or connect using a parallel cable.
Posted on Nov 01, 2007
forgot
  • 17 Answers
SOURCE: keep getting paper jam error message for hp office jet 6210 all in one
check the skew parameters
Posted on Dec 09, 2007
  • 4 Answers
SOURCE: Xerox Phaser 8500
Entering Service Diagnostics without Rebooting the Printer:
This method of entering diagnostics is to allow customers to be diverted to service
diagnostics in order to perform some tests.
1. Display the Hidden Service Menu as described in "Hidden Service Menu" on
page 4-2.
2. Scroll down to Enter Diagnostics and press the OK button.
Entering Service Diagnostics by Rebooting the Printer (8400):
1.
Turn the printer power OFF.
2. Press and hold the Back and Help buttons.
3. Turn the printer power ON while continuing to hold the Back and Help buttons
for approximately 30 seconds until the Control Panel indicates Diagnostic
Menu
Entering Service Diagnostics by Rebooting the Printer (8500/8550):
1.
Turn the printer power ON.
2. Wait for the Xerox logo to begin moving across the display.
3. Before the logo is centered on the display (stops moving), press and hold the
Back and Help buttons on the Control Panel.
4. Hold both buttons until the display reads Beginning Service Mode
Initialization
. Release the buttons and the printer reboots into service mode
with the Service Diagnostics menu displayed.
Posted on May 23, 2008
  • 3 Answers
SOURCE: HP 4700
Try this
Remove all EIO devices and memory Dimm's execpt the firmware dimm.
Start the printer. If the error is gone then place the dimm's / EIO devices one by one.
(Don't forget to switch off the printer.)
If the error is still there then you might have a faulty firmware dimm.
Posted on Dec 29, 2008
  • 44 Answers
SOURCE: I´ve got a message on my oki C5510 mfp
Check the toners are not empty. The printer only estimates how much it thinks should be left, there is a possibilty one is empty. this is best done by removing each toner in turn and checking that the hopper in the drum is full to level with the sponge surrounding it. Next check are the toner sensors. These are small and located to the right of each toner cartridge in the wall of the printer, one could be dirty creating the error and not allowing the printer to start up completely, causing the scanner connection to fail and giving you "Failed to get printer information". On this model the scanner and printer are essentially separate units joined by a USB cable.
Posted on Nov 08, 2009
Hp z2100 paper jam but no paper jam
If you have both firmwares as files, then yes you can downgrade, but be aware that some changes in firmware are not reversible as they reprogram hardware. Keep in mind that this product is classified as EOSL (end of support life) which means HP no longer provides support or spare parts.
Jan 24, 2015 | HP DesignJet Z2100 InkJet Photo Printer
Taking long timeto swith on the printer
try clearing all previous jobs from t he hard drive- it only does File System Check when a corrupt file has been identified on the hard drive and so it is re-writing all the information from the eerom back to the hard drive ( usually a sign of a failing hard drive) suggest you order one on-line ready for replacement. (you will need a HP Z2100 hard drive from HP a standard Hard drive will not work without some tricky copying/backup proceedures.
Dec 14, 2013 | HP DesignJet Z2100 InkJet Photo Printer
Error 48:00
Unsolved - http://h30499.www3.hp.com/t5/Printers-Designjet-Large-Format/designjet-z2100-48-00-error/td-p/991800
Nov 12, 2013 | HP Designjet z2100 44 Inkjet Photo - Same...
Reset z2100
reset tool for hp z 2100 ink cartridges expired
Dec 16, 2012 | HP DesignJet Z2100 InkJet Photo Printer
ERROR 08:11 HP DesignJet Z2100 InkJet Photo Printer
08:11 error = no communication between formatter and front panel
Switch the Power OFF from the back of the Printer and disconnect the Power cord. Reconnect the power cord and power On the Printer.
If the error persists, you are going to need a tech to do the following:-
Check that the Front Panel interface cable is not damaged and is correctly connected between the Main PCA and the Front Panel.Check that the connections between the Formatter and the Main PCA are not damaged and are correctly connected.
If the System Error continues, replace the Formatter
If the System Error continues, replace the Main PCA
If the System Error continues, replace the Front Panel
Nov 07, 2011 | HP DesignJet Z2100 InkJet Photo Printer
Hp designjet z6100 error code 21 : 13
Service Station error. Switch the power OFF from the back of the Printer and disconnect the power cord. Check the Primer Tubes. Reconnect the power cord and power On the Printer. Make sure that the Service Station path is clear. Remove any visible obstacles (e.g. screws, plastic parts, etc...) restricting the movement of the Service Station. If the System Error continues, replace the Service Station. If the System Error continues, replace the PrintMech PCA
Jul 27, 2010 | HP DesignJet Z2100 InkJet Photo Printer
TO GET BEST RESULTS FROM Z2100, how to calibrate
The full calibration procedures are detailed in the service manual which can be downloaded from: www.lpscomputer.com/ec/manuals.htm
Jun 24, 2009 | HP DesignJet Z2100 InkJet Photo Printer
Machine flashes f-50, shuts off.
Didn't see your post but I posted something nearly identical with the exception that mine does not post any error code. http://www.fixya.com/support/t147928-oasis_27092_strange_power_problem
May 07, 2007 | Kenmore Oasis HE 27082 Top Load Washer
190 people viewed this question
jasbo
jasbo
