Question about Watches
I want to remove honeywell ST772 programmer from its backplate and use the backplate to install ST9400C programmer
Spring fell out while putting smaller battery in. Can't locate where spring goes?
the spring goes in a small hole at the back of the watch and locates on the backplate to activate the alarm
Sep 23, 2015 | Watches
Change battery
Usually, you remove the backplate and then the battery. Replace the battery without touching it by hand and replace the backplate.
Mar 08, 2015 | Watches
After replacing battery can't get the backplate of AR0156 back.
If you cannot snap the back on with your fingers the only safe way to get the back on again is to use a watch press. This is an expensive tool that most jewelers will have. I strongly recommend you take it to a jeweler (may want to call first to make sure their company will do it because most chain stores will not work on most brands). They should not charge you.
If you are determined to do it yourself then you can try wrapping a wide pliers with duct tape or cloth and applying pressure on the front and back of watch to pop it on. WARNING: this is very dangerous for your watch. DO NOT apply pressure to the crystal, try to put the pressure on the stell lugs instead...
Oct 31, 2012 | Giorgio Armani Watches
How do you remove back cover to replace 296 wrist watch battery
Thank you for contacting FixYa.
  • Place the watch face-down on a clean towel to protect the crystal.
  • 2
    Gently unscrew the backplate from the watch with a small jeweler's screwdriver and set it aside.
  • 3
    Locate the battery compartment and remove the screw holding the cover in place, using the screwdriver. The battery is a small, round silvery button.
  • 4
    Make a note of the battery polarity before you remove it. Is the battery positive (+) side up or negative (-)?
  • 5
    Take the battery with you to a watch shop or electronics store to buy a replacement.
  • 6
    Insert the new battery in the compartment. Replace the battery cover and reverse the above steps to reattach the back cover of your Peugeot watch
  • Sep 14, 2010 | Peugeot Watches
    How can we use the Honeywell alarm LYNXR series without the service if we dont know the installer code. Where would the code be found anyway?Thanks
    you have get into programming by disconnecting the power then reapplying it (battery first) within30 seconds press1and 3 ( same time ) until you see 20 flashing. press #20 and the installer code will be displayed one number at a time. If you want to change it press *20and whatever 4 digit code you want the installer code to be. Next Press *99 The system will reset and come out of programming
    Oct 22, 2009 | Honeywell 5804 Ademco Wireless Security...
    How do i snap the backplate back on my buulova
    Oct 20, 2009 | Bulova 96R19 Wrist Watch
    Beep and chime will not work
    I think there would have been a minute spring coming from the back of the watch module to the backplate of the watch - this spring carried a vibration / beep which echoed off the backplate. Chances are you have damaged this spring during battery change - as i did with my gShock. Basically it's nackered!
    May 31, 2009 | Timex Watches
    Rado Diastar 196.0387.3 Ceramic No alarm Beep after Battery repla
    Most likely, you have lost (or bent) a very tiny spring that is used to complete the circuit.
    The piezo plate is bonded to the rear case; a part of the arm that retains the battery reaches up and contacts the rear case when the rear case is attached. The other half of the circuit, from the center-portion of the piezo crystal to the circuit board, is made via a tiny tiny tiny spring. (See a picture of a Casio contact spring doing the same job here.) In the Rado Multis that I have looked at, that spring rests loosely on a "pin" (and is therefore very easy to lose after the back is no longer holding it in place.)
    Look for a cutout in the backplate of the watch mechanism, inside which is a gold pin or post that doesn't quite reach past the backplate. There's supposed to be a spring, resting loosely on this post, which (when the back is attached) reaches past the backplate to make contact with the center terminal area of the piezo.
    If you're lucky, it's still in there, and bent or something. If it's missing entirely, you'll have to search out a replacement, or a watch repair that has them.
    Feb 06, 2009 | Rado Diastar Anatom Jubile watch
    Armitron Pro Sport Watch Hourly Chime
    Based on insructions for another watch, I just figured this one out. The steps would be:
    Get in Alarm mode (press mode button)
    Then you can cycle through the following by pressing the ST/STP button
    1. Alarm on
    2. Chiime on
    3. Alarm and Chime on
    4. Alarm and Chime off
    You can see this with a magnifying glass and watch the center and right hand circular icons at the top of the display.get highlighted.
    Dec 26, 2008 | JCPenney Armitron Sport Link Bracelet...
    Watches Logo
    27 people viewed this question
    Top Watches Experts
    Jimmy Accardi
    Are you a Watch Expert? Answer questions, earn points and help others
