Question about AudioCodes Mp-124d Mp-124 Fxs Analog Gateway Sip Voip
How to reset MP 124 - AudioCodes Mp-124d Mp-124 Fxs Analog Gateway Sip Voip
    Sergeant:
    Novelist:
  • 143 Answers
It's - literally - right in front of you.
There is a pinhole on the front of the device; to the left of the display where it says "Channels."
Posted on Jun 13, 2015
An angle measures 124 more than the measure of a supplementary angle. What is the measure of each angle?
I find doodling a sketch helps with questions like this.
Let x be in this case the supplementary angle.
Supplementary angles add up to 180 degrees.
Thus,
180 = x + (x+124)
180 = 2x + 124
180 - 124 = 2x + 124 -124 (subtract 124 from both sides)
56 = 2x (divide both side by 2 to isolate x)
56/2 = x
28 = x
Other angle is 28 + 124 or 152.
Check 152 + 28 = 180!
We did it correctly!
Good luck,
Paul
Nov 15, 2016 | Office Equipment & Supplies
It shows erro 124-315
The serial no., product no., and billing count are stored at three locations; the MCU NVM PWB (IOT), the SEEP ROM (SYS1) on the Backplane (BP) PWB, and the ESS NVM PWB (SYS2). This procedure allows the data in all three locations to be synchronized in case of replacement of one of the PWBs, or due to data corruption associated with one of the following faults:
  • 124-324 (3 Billing Counter Mismatch)
    124-325 (1 Billing Counter Mismatch; Unable to recover Billing Counter during recovery)
    124-312 (Product No. Mismatch)
    124-313 (Serial No. Mismatch)
    124-310 (Product No. Failure: Not initialized)
  • 124-311 (Serial No. Failure: Not initialized)
Procedure
  1. Enter UI Diagnostic mode ( Accessing UI Diagnostics).
    Select Adjustment/Others.
    Select Machine ID/Billing Data Settings.
    Select a PWB with the correct data.
    Select Start.
  2. Enter the correct serial number in the Serial Number screen and then select Confirm.
Mar 02, 2016 | Xerox WorkCentre 7232 7242 220v Fuser...
MP 9000 SC 124 What is the solutione please?
SC 124 Scanner error Check and clean white plate
Scanner error Check exposure lamp /comming on -Carl
Feb 23, 2015 | Ricoh Office Equipment & Supplies
Workcentre 7238. What causes error code 124-315?
Procedure
    Select Start.
Sep 26, 2013 | Xerox Office Equipment & Supplies
I have a xerox 7428 with error 124-315 how can i fixit
Procedure
    Select Start.
Apr 20, 2012 | Office Equipment & Supplies
Code 124
Throttle position sensor circuit is intermittent or faulty throttle positon sensor.Reset the computer after replacing any sensor.
Jan 12, 2012 | 2006 Honda Civic
Dose the printer epson stylus NX125\127 comes with a USB wire?
Yes
http://www.epson.com.au/products/multifunctional/stylusnx125_specs.asp
but you can buy one yourself for less than $5.
Jul 19, 2011 | Epson Stylus Multifunction Inkjet Printer/...
How to mix the oil and gas for a 69dB(A)
hi friend,
16:1 24:1 32:1 40:1 50:1 Litres millilitres of oil 5 300 200 150 125 100 10 625 425 300 250 200 15 950 625 475 375 300 20 1250 825 625 500 400 25 1550 1050 775 625 500 16:1 24:1 32:1 40:1 50:1 Imp Gal Imp ounces of oil 1 10.0 7.0 5.0 4.0 3.0 2 20.0 13.5 10.0 8.0 6.5 3 30.0 20.0 15.0 12.0 9.5 4 40.0 27.0 20.5 16.0 13.0 5 50.0 33.0 25.0 20.0 16.0
16:1 24:1 32:1 40:1 50:1 US Gal US ounces of oil 1 8.0 5.5 4.0 3.2 2.5 2 16.0 10.5 8.0 6.5 5.0 3 24.0 16.0 12.0 9.5 7.5 4 32.0 21.5 16.0 13.0 10.0 5 40.0 26.5 20.0 16.0 13.0 16:1 24:1 32:1 40:1 50:1 Litres US ounces of oil 5 10.5 7.0 5.5 4.0 3.5 10 21.0 14.0 10.5 8.5 7.0 15 32.0 21.0 16.0 12.5 10.0 20 42.5 28.0 21.0 17.0 13.5 25 53.0 35.0 26.5 21.0 17.0 16:1 24:1 32:1 40:1 50:1 US Gal millilitres of oil 1 225 150 125 100 75 2 475 325 225 200 150 3 700 475 350 275 225 4 950 625 475 375 300 5 1175 800 600 475 375 16:1 24:1 32:1 40:1 50:1 Imp Gal millilitres of oil 1 275 200 150 125 100 2 575 375 275 225 175 3 850 575 425 350 275 4 1125 750 575 450 375 5 1425 950 700 575 450 hope this helps u
please rate me...........................
thank u for using fixya
regards
sivaranjini
Nov 24, 2009 | John Deere Garden
AudioCodes MP-11R/2FXS
The easiest way (if enabled) is to use the voice menu as if you would assign a new IP to the device.
  1. Connect a telephone to one of the FXS ports. Lift the handset and dial ***12345 (three stars followed by the digits 1, 2, 3, 4, 5).
  2. Wait for the 'configuration menu' voice prompt to be played.
  3. To change the IP address, press 1 followed by the pound key (#).
  • The current IP address of the gateway is played. Press # to change it or hang up if you don't want to change it.
  • Dial the new IP address; use the star (*) key instead of dots ("."), e.g., 192*168*0*4 and press # to finish.
  • Review the new IP address, and press 1 to save it.
Of course you can try the default IP of 10.1.10.10 if the device is set to it's default standards.
If not, you can try a network scanner like angryip (link) or network scanner (link) - this might take a long time, since the IP can be virtually anything.
If you have physical access to the device, you can also use a straight RS-232 cable to connect the AudioCodes to your PC and use HyperTerminal to connect (Baud Rate: 115,200 bps (MP-124), 9,600 bps (MP-11x), Data bits: 8, Parity: None, Stop bits: 1, Flow control: None)
If you need the manual (and it never hurts ;-) here is the link:
http://www.audiocodes.com/filehandler.ashx?fileid=36320
If you have any more questions, just come back here and leave a comment - I'm happy to help.
Oct 22, 2009 | AudioCodes MP-112R/2FXS/3AC/SIP-3/UC...
AudioCodes Mp-124d Mp-124 Fxs Analog Gateway Sip Voip Logo
Top AudioCodes Computers & Internet Experts
Are you an AudioCodes Computer and Internet Expert? Answer questions, earn points and help others
