Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Access master keypad doesn't have an enter button
I can not program my keypad. does not have an enter button. what can I do?
4 Suggested Answers
  • 3197 Answers
SOURCE: Can not program both keypad & remote to operate at the same time
One of your units has reverted from "rolling code" to "billion code" and as you have found they will each work but will not work with each other. The problem is finding out which unit reverted. The most common one is the hand remote but that could be wrong.
Posted on Aug 10, 2009
  • 3197 Answers
SOURCE: how to program a remote entry keypad. There is no
Sounds like you have a hardwired keypad. If so:
To program the keypad, first unplug the garage door opener from the electrical outlet. Next, remove the nameplate from the console that the keypad plugs into and locate the program/operate switch. Flip the switch to program. Next, enter your desired four-digit PIN number into the keypad. Slide the switch back to operate and plug the garage door opener back in. The keypad should be programmed.
Posted on Jan 04, 2010
  • 8457 Answers
SOURCE: purchased a house in short sale with a lift master
Sorry that keypad is no used to u.If u don't know the secret codes.Just push in the codes it will work.No enter button,mean u just don't push enter after u push in the codes.
Posted on Nov 27, 2010
How do I reset code on dsc
*5
Master code
Enter 40 for new master code
Enter new code twice
Keypad will beep three times rapidly confirming successful entry
Press # a couple times to exit programming.
Aug 26, 2014 | DSC Alexor Alarm System Wireless Panic...
How to change code on the garage door opener and the remote control on a lift master garage door opener
If you have a 315MHZ LiftMaster Garage door opener do the following:
Follow the purple wire (Antenna) up and you will see a square purple button.
Press and hold the square purple button for ten seconds until the amber led goes out.
Press and release the purple button one time (The amber led will come on solid).
Press and hold the button on the garage door opener remote control for two seconds (The light bulb on the garage door opener will blink and you will hear a click sound the amber led will go off).
to program the wireless keypad do the following:
Enter a four digit code into the keypad then press and hold the enter button for two seconds (The light bulb on the garage door opener will blink and you will hear a click sound the amber led will go off).
Aug 08, 2014 | liftmaster Lift Master 377LM 376LM 315 MHz...
Purchased a house in short sale with a lift master 1/2 hp model #1155-4 date 11/92. We got a new car remote, it works fine, but don't know how to program the wireless keypad. It is not hard wired and has...
Nov 27, 2010 | Sears Craftsman LiftMaster Chamberlain...
Trying to program garage door Access Master will not program. Followed steps and now car remote will not work.
Try programming your remote this way. Press and hold the button on your remote while you press and immediately release the smart/learn button.
Sep 14, 2009 | Sears Craftsman LiftMaster Chamberlain...
Can i program homelink with out a remote
The only way to program Homelink without a garage door opener remote is if you have a keypad that allows access to your garage. I tried EVERYTHING and then realized I had the keypad which is wireless; I simply unscrewed the battery operated keypad from its location and held it 1"-3" from the Homelink buttons in my car. I then punched in my code and held the enter button on the keypad at the same time as the Homelink button I wished to program. It worked flawlessly. Good Luck!!!!
Jul 17, 2009 | Sears Craftsman LiftMaster Chamberlain...
Need to change code
If your opener has a wireless keypad it should be simple. On the back of the motor unit you will find the smart/learn button. Press and immediately release it and walk over to your keypad and key in any 4 digit code you like and press enter.
Jun 24, 2009 | Sears Craftsman LiftMaster Chamberlain...
Keypad reset. Now that I have the original keypad code, how do I change the code?
your owner manual tells you. Why not use the original code?
To change, here is 96 procedure, should be the same. please give good rating if this is what you want.
Entry Code The system (permanent) entry code is located in three places:
  • on the owner's wallet code card (in glove compartment)
  • electronically accessible by requesting the remote anti-theft personality module KEYCODE PID on the New Generation Star (NGS) Tester
  • on the remote anti-theft personality module housing
The remote anti-theft personality module is programmed at the factory with a five-digit entry code. A replacement remote anti-theft personality module includes replacement labels and a new owner's code card. To turn on the interior lamps and light all illuminated components:
  • press any button on the keyless entry keypad (14A626).
To program a temporary access code:
  • Enter the permanent code on the keyless entry keypad.
  • Press button 1/2 within 5 seconds of last digit of permanent code. (This alerts system to accept temporary code.)
  • Enter alternate five-digit code. Do not exceed 5 seconds between entering digits or between pressing the 1/2 key and entering the first digit.
Apr 08, 2009 | 1995 Ford Taurus
Need to change keypad access code for Sears garage door opener
To change the code, you need to hit the LEARN button the back of your machine. You will see a yellow light flash. Enter a 4 digit code on the keypad and press enter. The lights on the opener should flash and you should hear a click. Your keypad is programmed.
Feb 19, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman 1245LM reprogram
The keypad outside has manuals online that you could use, but for simplicity, Have someone go to that back of the machine and press the "Learn" button, once its is pressed, the yellow light should blink. Enter a new code (4digit) into the keypad and press the enter button. You should then hear a click and the lights on the machine should flash. That will program your keypad.
Sep 16, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
Top Sears Building Materials Experts
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
