Question about Dell Dimension 4600 PC Desktop
Have a dell dimension 4600. I have a blinking
Have a dell dimension 4600. I have a blinking power light colored green but no power going to the computer. Fan doesn't work nothing opens or durns on what is wrong with my computer?
    President:
  • 2,653 Answers
The two biggest culprits would be:
the power supply and the motherboard.
I'd start with the power supply since it's cheap and easy to install.
Find a local computer shop that sells 'em.
Make sure they've got a 100% return policy.
Swap 'em, if it works problem solved.
If not it's probably the motherboard. You could always have a local tech check it out.
Make sure they provide FREE diagnostics. It shouldn't cost you anything to have ti looked at.
Posted on Jun 19, 2009
I have a Dell Dimension E521. When I cut the power on everything comes on including the monitor, but the monitor will stay black. It does say something about power save hit any button but the screen
A solid green light means the computer is operating normally.
A solid yellow light indicates the power supply is operating normally but the computer is not processing data.
This could mean there is a problem with the CPu or another component on the motherboard.
((A blinking yellow light indicates the power supply is receiving power from the wall, but not functioning properly.
This generally means the power supply itself is bad and should be tested or replaced.))
A blinking green light means the computer is in standby mode.
You should consider visiting Dell Support and downloading the manual for your
your Dell computer. So use the LED power light codes if your Dell computer has them.
hope this helps
Sep 10, 2012 | Dell Dimension E521 PC Desktop
The power LED light is orange instead of green and it won't turn on
Hi! for most dell machines if the power led is orange its an indication of a issue with the ram, try to reseat the ram first.if that doesnt work normally for dimension 4600, there are diagnostic lights that are located at the back panel of the machine, they are four bicolor lights(amber and green) You can determine the exact problem by checking these lights and you can interpret them by going to this website: http://support.dell.com/support/edocs/systems/dim4600/en/4600i/sm/adtshoot.htm#1112886 hope this helps...
Jun 12, 2010 | Dell Dimension 4600 PC Desktop
Can't boot up Dell 5100 Dimension, amber light flashes
When you mean the amber light, is that the blinking hard drive access light or the power light? Different cases have different colors on it. Mine has blue and green lights.
If you see the boot screen (bios) and then after it goes to boot, does it blink and hang?
This could be a simple operating system issue, hard drive or hardware/motherboard issue. If you could provide more information, that would help.
Jun 28, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Computer will not turn on
  • Blinking Amber/yellow: Initial state of LED at power up.
    Indicates system has power, but the POWER_GOOD signal is not yet active.
    If the hard drive LED is off, it is probable that the power supply needs to be replaced.
    If the hard drive LED is on, it is probable that an onboard regulator or VRM has failed.
Apr 28, 2009 | Dell Dimension 4600 PC Desktop
I have a Dell Dimension 4600 and it won't boot up. When I turn it on the green power light comes on and hard drive activity light flashes however no fans come on, the screen doesn't show the Dell logo or...
i would have to disagree with jerry, while that seems reasonable if the motherboard fan isn't running at all then whether or not the video card is ok is somewhat irrelevant.
I would agree somewhat though, i think the PSU might be a good thing to check to see if it is functional.
when you power it on does the CPU fan start or shudder at least ? that would be my first guess for a problem if you had been having any problems recently
Apr 17, 2009 | Dell Dimension 4600 PC Desktop
My computer goes dead except for a blinking green power light on the front. Looks like it is in stand by, but will not wake up. So far, when I turn it off and back on it will boot up.
Hello todd6476,
Here's a link on Dell's support site that might help explain the blinking light: http://en.community.dell.com/forums/t/18394108.aspx?c=us&l=en&cs=19&s=dhs
If this is a satifactory explanation then please rate it.
Have a great day,
martyshaw152
Mar 22, 2009 | Dell Dimension 4600 PC Desktop
Power Problem
It could be the power supply isn't getting enough current to run things. I'd start there.
Jun 21, 2008 | Dell Dimension 4600 PC Desktop
No power to my dell dimension 4550
It might be a couple of things bad powersupply or power button incorrect ram module or hard drive settings ,if not then lastly have a bad motherboard which we all hate. you said you have a a green light on motherboard? Did you upgrade or install any new ram ,harddrives etc check make sure they are seated properly in their sockets and free from dust check connection on the ram module make sure it shinny brass color if not you can use an eraser to clean them. If you have upgraded check make sure the ram is compatible to your machine sometimes the wrong ram install can cause no power up problem. Do you have four green lights in the back of machine? Dell new desktop has 4 green light in back of the unit . if all four light are green then system is ok but one out of the four light are orange then you have a problem. You can go onto dell web sight for your machine to check out these lights codes. I hope this help you out some.
Feb 12, 2008 | Dell Dimension 4600 PC Desktop
try safe mode f8 and go into msconfig and uncheak startup stuff ok
Jan 21, 2008 | Dell Dimension 4600 PC Desktop
Dell Dimension 4600 PC Desktop Logo
318 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
