Question about HP CP3525N Color LaserJet Printer
59.0 my printer cannot ready
Printer 5550 laser color cood 59.c0
I am assuming you meant HP Color LaserJet 5550 Error Code 59.c0
Description
A printer motor error has occurred. This message might also appear if the ETB is missing or incorrectly installed. Ensure that the ETB is installed correctly.
Action
  1. Press the green (Select) button to continue.
  2. Turn the printer off, and then turn the printer on.
  3. If the error message returns, turn the printer off.
  4. Perform a cold reset.
    1. Turn the printer on.
    2. Watch the control panel.
    3. When the memory starts counting, press and hold the green (Select) button.
    4. Continue holding the green (Select) button until the Ready, Data, and Attention lights flash once, and then stay on steady.
    5. Release the check button when the Ready, Data, and Attention light are on steady. The control panel will display SELECT LANGUAGE.
    6. Press (Down Arrow) button once. The control panel will display COLD RESET.
    7. Press (Select). The printer will perform a cold reset and then continue its power-on sequence.
  5. If this message persists, contact an HP-authorized service or support provider.
Sep 06, 2016 | Laser Office Equipment & Supplies
Tip
59.co error in hp laserjet 5550 series printers
error because of the sensor located bottom right side of the printer.clean the sensor in an air flow, the printer will be ready
on Sep 16, 2010 | Office Equipment & Supplies
Hp laser jet pro 400 m401 printer 59.A0 error
i have nOt used this site before but i believe they do have a description of the error code you describe. it said problem is defuser or main motor error, heres the link
http://www.printertechs.com/printer-troubleshooting/hp-error-codes/195-numeric-error-codes-50-59-hp-laserjet
HP LaserJet Error Codes 50 59
Apr 20, 2016 | HP Office Equipment & Supplies
How do i fix a 59.C0 error on my printer?
  1. Turn the printer off, and then turn the printer on.
  2. If the error message returns, turn the printer off.
  3. Perform a cold reset.
    7. Press (Select). The printer will perform a cold reset and then continue its power-on sequence. NOTE: If this message persists, you will need to contact an HP-authorized support provider.
Sep 15, 2015 | HP Color LaserJet CM2320nf MFP Refurbished
Hp color laserjet code 59.fo error
All the book says is that one of the motors had a problem.
Power it off for at least 30 seconds. Power back on.
Make sure you are not using a surge protector.
Put the power cord directly into the wall outlet.
I just checked the manual for another printer and the 59.f0
could be the ITB. Make sure that it is seated correctly. If you have
a spare install it and see if problem goes away.
Apr 04, 2011 | HP Laserjet Cp2025n Printer
Code ereur 59
A code error 59:
Description A printer motor error has occurred. This message might also appear if the ETB is missing or incorrectly installed. Ensure that the ETB is installed correctly. Action
  1. Press the green c00099346.jpg (Select) button to continue.
    3. When the memory starts counting, press and hold the green c00099346.jpg (Select) button.
    4. Continue holding the green c00099346.jpg (Select) button until the Ready, Data, and Attention lights flash once, and then stay on steady.
    6. Press c00099347.jpg (Down Arrow) button once. The control panel will display COLD RESET.
    7. Press c00099346.jpg (Select). The printer will perform a cold reset and then continue its power-on sequence.
Mar 02, 2011 | HP LaserJet 5550DN Printer
Printer hp 5500 fault 59.ck meaning
Don't know of a 59.CK error. However a 59.C is a "developing disengaging motor" error.
If you are a tech, replace the developing disengaging drive assembly(RG5-6719-000CN).
If you arn't a tech, get one.
Dec 24, 2010 | HP LaserJet 5500 Printer
HP 5500n 59.ck error code
HP LASER PRINTER 2300 ERROR 59.B, 59.C
1. The Alienation motor error.
2. Replace the alienation motor.
3. Replace the D.C. controller board.
May 15, 2009 | Office Equipment & Supplies
Error 59
Error 59 normally refurrs to the fuser unit replace and test.
Thanks J
Nov 04, 2006 | HP LaserJet 3600dn Printer
HP CP3525N Color LaserJet Printer Logo
19 people viewed this question
Seeker5211
Seeker5211
