Question about Samsung Prostar 816 Phone
Lines are not rolling over - Samsung Prostar 816 Phone
CALLS NOT ROLLING OVER TO ADDITIONAL LINES
The phone company controls the "HUnt".
If line 1 is busy and will not roll over to line 2, then it is the phone company....
Aug 23, 2010 | Avaya Corded Phone avaparp18d
We went to a roll over system on our phone lines and now we cannot receive faxes. We can send them though.
Your roll over system is sending calls to the first line in the sequence and it does not differentiate between voice and fax. You will have to change the roll over so it does not send calls to your fax line. Your internal phone system may still use the fax line for outgoing faxes and voice calls but incoming fax calls have to be sent to the line the fax is on.
~Greg
Jul 13, 2010 | Brother IntelliFax-2820 Laser Fax
GTCO Roll-Up Digitizer... lines appear wavy and jagged
The GTCO ROll-Up is not a high accuracy tablet,it is made for general use by Estimators.
Normal accuracy is somewhere between 15 and 22 mil.
Are there any breaks in the line,this would indicate an open on the grid.
Are you using a Tabletworks driver? Check the options and make sure the correct size tablet is in the driver.
Apr 30, 2010 | GTCO Roll-Up Digitizer, 30/36" (RU3036)
Clear picture, but rolling lines
it might be due to bad signal strength. check for it. good luck!
Oct 14, 2009 | Sony KP-57WS510 57" Rear Projection HDTV
Inter Tel Encore will not roll over
That is not a function of the phone system. You need to call your telephone company and have them configure your lines to hunt
Dec 15, 2008 | Inter-Tel Encore Phone
Sharp Electric Cash Register XE-A203. I just put a new paper roll into the register because it was out of paper. The register screen is showing all numbers and transactions but when the paper comes...
Hi whitwall,
Please make sure that you have the right paper roll.
Your machine takes a thermal paper roll, which means it actually burns the print into the surface of the paper as opposed to printing with a ribbon or ink roller like other makes.
The thermal paper will only show a print on one side of the paper, in other words if you do indeed have the right roll and it is in upside down you will get a blank printout.
An easy way to see if it is the right paper hold the roll in your one hand and scratch a line with the thumb nail of your other hand accross the surface of the roll,if you get a black line on the paper then it is the right one, otherwise you have what we call a "bond" paper roll and it will not work in your machine.
If you got the "black line" with your thumb nail, then lift the printer head arm (green lever) place the roll in position with the paper rolling out from the bottom of the roll towards the front of the machine, pull the paper out past the catch mechanism and close the printer ****.Tear off the excess paper and replace the printer cover.
You should be ready to go ahead with sales.
This should solve the problem .
Regards
Gavin.
Oct 16, 2008 | Sharp Office Equipment & Supplies
Lands Phones Logo
19 people viewed this question
Top Samsung Lands Phones Experts
Jose Ma DM.
Jose Ma DM.
imfedup19
Level 1 Expert
Are you a Samsung Lands Phone Expert? Answer questions, earn points and help others
