Question about Health & Beauty
Require new power cord for syl280b - Health & Beauty
How to hard wire the power supply for a 2.4 ghz wireless camera model 49-2535
Warning: not only would this void the manufacturer's warranty but it could also damage or destroy the product; & you should take or use the necessary precautions to avoid electric shock or any other health risks. Since the AC power cord plugs into the back of the camera, hardwiring a power cord would require unit disassembly & replacing the manufacturer's intended power cord connection with the same power cord or one rated with the same specifications at your own risk to cut off the camera plug-in, to separate the wires, & to anchor these wires to the power jack wires of the same polarity. This could require the use of a multimeter & the use of a plastic plug anchor at the border of the hole leading into the back of the unit. The plastic anchor would serve to further secure the cord to the unit & to reduce unintended entry of moisture, dust, debris, & so forth. Take further precautions if you intend to solder the power cable to the associated wires, & secure the wires at the connections, isolating each new connection with electrical tape, Plasti-Coat, or the equivalent.
Jan 31, 2015 | Home Security
My tv will not come on, checked the power cord and the cord is fine. TV just does not respond whether you use the remote or the button on the side. Please advise.
Did you make sure that the cable cord was also connected to the TV? ....and also did you
check the battery in the remote -you may require a new one.....
Jun 08, 2011 | Philips 32PFL3403D/27 32 in. LCD TV
I lost the manual and need to get a new one for: AT&T 1856 corded speakerphone with digital answering system Thank you
AT&T Corded SpeakerphoneThe AT&T 1856 Corded Speakerphone with Digital Answering System offers the home-user peace of mind thanks to its power failure operation that doesn't require batteries. The Speakerphone features three one-touch memory buttons and a 9-number speed dial. The phone is caller ID and call waiting capable with a 50 name/number caller ID history, and features a visual message waiting and new call indicator. A large, LCD display with adjustable contrast controls allows for easy.
Apr 24, 2011 | AT&T Corded phone
New house has three prong recpticle dryer cord has four prongs. Can I use a three prong cord and strap a wire to the fourth wire on back of dryer? If not got a solution?
If the new house has an existing three-wire outlet, the simplest solution is to install a 3-prong power cord on your dryer. The following link explains the differences between a 3-wire and 4-wire configuraiton:
http://www.fixya.com/support/r3575913-installing_a_220_vac_appliance_cord
So...if you need to install a 3 prong power cord, it should be wired as follows:
RED (HOT) 120VAC to RED
BLACK (HOT) 120VAC to BLACK
WHITE (NEUTRAL) 0 VAC to WHITE - a Ground wire needs to be connected to the Neutral lead at the terminal block and grounded to the dryer cabinet.
The other alternative would require you to install a 4-wire receptacle so you could still use your current power cord. A certified electrician is recommended for this job and may cost you some money. A replacement power cord, on the other hand, usually costs less than $20 and can be found ay any hardware store.
If you have any questions, please post back and let me know. I hope you find this information helpful.
Jun 10, 2010 | Dryers
Need new electric cord for model 7000/a lakewood heater oil filled
Depending on handy you are, the power cords for heaters can be replaced, but may require soldering or other electrical and mechanical skills. You MUST replace the cord with one that has the same amperage and heat ratings.....that goes for the plug too.
Feb 20, 2009 | Lakewood 7101 Oil Filled Radiator Heater
I was blowing snow with my Toro Power Curve 1800. I was distracted for a moment and tangled the cord in the blade. The cord is wraped around tight, how can I remove the cord?
unless you are able to turn the blade backward and pull on the cord at the same time no luck. it may be easier to just cut the cord and install a new one. solution one is best and both require taking the machine apart. start there and hope it works out for you.
Ps. dont forget to rate the solution. Thanks
Dec 28, 2008 | Vacuums
Replacing a fraayed and twisted power cord on a Hoover windtunnel upright
ok so I took this vaccum apart completely except for the electrical and motor systems. It seems to me that without dismantling both of these systems on the vaccum you can't replace the power cord. And I wouldn't recommend taking them apart unless you know what you are doing since replacing the power cord seems to require cutting the old power cord and soldering the new one onto the old terminals. All in all its probably easier to get a new vaccum altogether.
Dec 13, 2007 | Hoover U6616-900 WindTunnel Bagless...
LOST POWER CORD
I need a new ac adapter and I sent an email to evergo@att.net which is the customer service for the company that makes the PDV-709 dvd player. They responded within 1 day and gave me the instructions as to how to order one from them and the price ($20) etc. They require a money order sent to the address below.
Lenoxx Customer Service
Lenoxx Electronics
35 Brunswick Ave
Edison, NJ 08817
Oct 11, 2007 | Durabrand PDV-709
Health & Beauty Logo
27 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
