Question about Plantronics Discovery 925 Bluetooth Headset
Plantronic voyager pro wont turn on after charge
My voyager is going the same thing. it has the ed indicator light while its charging but nothing as soon as i take it off.. it also wont do anything while its on the charge, and nether way will myphone, a motorola hint, detect it while in paring mode. it has before. ive only had it for 2 days. otherwise its a great prouct, i love it. if nothing here can fix it i think ill just keep on changing it in for a new one. lol
Peter Denton
  • 16 Answers
SOURCE: Plantronics voyager 500a
With these units, if the earpiece battery is allowed to run down, it will switch off. When the earpiece turns off the base station starts to search for it, which is indicated by the flashing red power light. Also the blue light on the top of the base will turn off. The first step, which you have already done, is to charge the earpiece. Next, hold down the little black button that is on top of the earpiece for about 5 seconds. You should get a slow flashing blue light on the mic boom. Wait for about 10-20 seconds and the base should automatically find the earpiece. The red power light on the base will be steady and the blue light on top of the base will come on.
Posted on Oct 03, 2008
cyberguru4u
  • 90 Answers
SOURCE: pair 3xx plantronics with my phone
turn on blue tooth on mobile first..then press and hold the power button on plantronics untill the light flashes red and blue alternatively...then search for bluetooth from mobile and pair and if asking a code enetr 0000..
Posted on Feb 26, 2009
SOURCE: pair plantronics voyager 510 with mac book os x
1. Turn Bluetooth On in Macbook 2. Turn the headset On 3. Press the Up volume and the conversation On/Off key at the same time until the blinking blue lights blinking Blue and Red alternatively 4. In a couple of seconds the Mac will ask for the Authorization Key 5. The Auth key is "0000" (4 zeros) 5. Pairing should now be successful and you should be able to use the PLT510 headset with your Mac. I can
Posted on Oct 02, 2009
HDI Headsets
  • 537 Answers
SOURCE: Plantronics Voyager Pro bluetooth headset
You want to turn off the power to your headset and turn off your phone. Remove for 30 seconds the battery from the phone and reconnect. Then follow the pairing instructions found on pages 4-5 in this link for the Plantronics Voyager Pro+.
Good luck from Headsets Direct!
Posted on Sep 16, 2011
HDI Headsets
  • 537 Answers
SOURCE: My plantronics voyager pro wont turn on, It
Sounds like you have a few things going on here that may be a procedural problem. We recommend reviewing your user guide, paying close attention to the "take a good look" and "tips". The link below for the Plantronics Voyager Pro+ should help.
Posted on Oct 21, 2011
Voyager Pro wont charge??
The batteries may have failed and cannot be recharged
May 11, 2013 | Plantronics Voyager PRO Bluetooth Headset
My plantronics voyager pro wont turn on, It doesn't fill power on-off bottom. I can only charge it correctly with red led. Each time when I press "volume+" bottom for 5 seconds while charging...
Oct 13, 2011 | Plantronics Voyager PRO Bluetooth Headset
Plantronics Voyager Pro bluetooth headset seems to be stuck in pairing mode. The lights flash red and blue, my motorola droid will show paired but not connect ed. If it does connect at all it will drop...
Sep 01, 2011 | Plantronics Voyager PRO Bluetooth Headset
I have charged my pro+ but it wont power on i have no red or blue lights only red when charging
hold the power button down for about 3 seconds- that should either 1. put it into pair mode (red + blue), or 2. Shut it down so you can retry pairing/turning them on.
Jun 22, 2011 | Plantronics Voyager PRO Bluetooth Headset
My plantronics voyager pro will not charge turn on or anything. do you know the peoblem?
I have seen on some Plantronics Bluetooth headsets that you can perform a system reset by doing the following, It might help but not sure.
Instructions:
While plugging in the AC charger, hold the power/pair button. The headphones will show a solid red or blue light when they have been successfully reset.
Jun 18, 2011 | Plantronics Voyager PRO Bluetooth Headset
MY VOYAGER PRO .. LIGHT FLASHES BLUE RED BLUE RED ... CAN'T TURN OFF, CAN'T RESET, CAN'T RE PARE
If you manually turn the headset off, make sure that it is by itself, no other phones in the area, no WiFi hotspots. Once this is done make sure that there is not a bluetooth already installed on the phone itself, if there is, delete it. Make sure that the headset has a full charge. Try the pairing again. If this still won't work, you can try Plantronics Tech service line 800-544-4660.
Here are two links that may be helpful:
Plantronics Voyager Plus User's Guide
Plantronics Voyager Plus Pairing Instructions
Jun 04, 2011 | Plantronics Voyager PRO Bluetooth Headset
THE CHARGING LIGHT DOESN'T COME ON. I CHARGE IT DAILY BUT WENT ON A TRIP FOR 5 DAYS AND WHEN I RETURNED THE LIGHT WON'T COME ON...RED OR BLUE.
Per Plantronics: The Voyager Pro is not a moisture resistant headset. So if you have worn the headset during work outs or outside in excessive heat it could cause it to fail.The only solution is to have the headset replaced if still under Plantronics one year warranty.
May 23, 2011 | Plantronics Voyager PRO Bluetooth Headset
I bought the plantronics voyager pro bluetooth headset two months ago and now it's dead. It's been working great for two months. When it's plugged into the wall for charging the red light is illuminated....
One thing you can try is to power down and then power the headset back up. The instructions are on the link below for the Plantronics Voyager Pro, particularly the page "Listen To The Voice."
Plantronics Voyager Pro User's Guide
If that doesn't help, then you have a bad processor in the headset. It's still under warranty so contact Plantronics at 800-544-4660 x5 x5538 for warranty service.
Apr 28, 2011 | Plantronics Voyager PRO Bluetooth Headset
I have a Plantronics Voyager Pro and it will not take a charge. I plugged the charger into my phone to check it and it does work on my phone except not with my blurtooth. Thanks for your help.
If you have the Plantronics Voyager Pro headset, you should be using the ac adapter that came with the headset ( model 79414-01 ). If the headset will not charge, it could be broken or the internal battery may be worn out. Keep in mind that the Voyager Pro has a one year warranty, and Plantronics will replace it within the warranty period.
Plantronics Voyager Pro Headset
AC Adapter for Voyager Pro Headset
Feb 28, 2011 | Plantronics Voyager PRO Bluetooth Headset
I am having problems getting my Voyager Pro bluetooth to recharge. I am not getting the solid red light to indicate the unit is charging.
So if it won't charge, it may be that the charger is bad, and you may not have a way of charging it to find out if it is the charger or the battery. If it is the charger you can get a new one, there is a link below to the right part. If it is the headset and it is still under warranty return it to the vendor.
Plantronics 79414-01 AC Adapter
Oct 21, 2010 | Plantronics Voyager PRO Bluetooth Headset
Plantronics Discovery 925 Bluetooth Headset Logo
326 people viewed this question
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
shaun taylor
Michael Vincent Cruz
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
