Sony bravissimo screen says debug - Televison & Video
Why does debug shown on my screen?
The word "Debug" is not part of Panasonic TVs. We recommend you contact the source provider so they may properly assist you.
May 19, 2014 | Panasonic TC-P55S60
The word "Debug is on my tv screen. How do I remove it?
Unplug the power cord of the receiver box for 10 seconds and then plug it back.in job done..
Mar 23, 2014 | Televison & Video
Word "debug" on my vizio tv screen
Sounds like firmware corrupted. A firmware update might be necessary. Contract the authorized service center for Vizio.
Gopakumar Gopalan Google
Mar 10, 2014 | Televison & Video
Debug message on far side of Screen
Firmware corrupted. Contact the authorized service center.
Mar 04, 2014 | Sony Bravia KDL-40W4100 40 in. LCD HDTV
Word Debug showing on Screen
We regret to inform you Panasonic TV's do not use any errors similar to Debug. We recommend you contact the source provider that the TV is connected to.
Mar 03, 2014 | Panasonic TC-P50S30 VIERA 50 Class 49.9...
The word debug is on the screen. how do i take it off?
Feb 27, 2014 | Sony Bravia 36 40 42 46 50 52 55 LCD...
Were can find usb debugging on sony c902
Go to "Settings"
"About phone"
repeatedly press "build number" (about 10 times) After enough presses you will get a toast notification that says "You are a developer"
Back up to settings and now you will see the developer menu.
USB debugging is located in the developer menu.
Dec 23, 2013 | Sony Ericsson Cell Phones
Mtp drivers for xperia s
Try this:
1. Start off with the device unplugged from the PC.
2. From the home screen, tap Settings, Applications, Developer, and enable Debug Mode.
3. Next, go back one stage so that you are at Settings, Applications, and this time go into Manage Applications.
4. On the top row of tabs, select All.
5. Scroll down the list (alphabetical) until you locate MtpApp. Tap on it, and then tap Clear Data.
6. Plug in the device
7. Drag the notification bar down from the top of the screen.
8. Tap on debugging mode to open the developer screen again, and tab debugging mode to dissable it.
9. PC Companion should now connect. If it still takes a minute, let it do so and don't deem this as a failure until you have received the failure message. Remember, new devices can take a while to connect depending on your envionment.
Oct 20, 2012 | Sony LT26i Xperia S White 32GB Android 2.3...
DeBug appears whenever
what IE are you using?
the debug will appear when you using IE6. the reason is that most of th web site have activex. IE6 can't handle it. you need to install IE7 sp1.
Mar 27, 2009 | Microsoft Windows 2000 for PC
Televison & Video Logo
12 people viewed this question
Top Televison & Video Experts
Electro Med Services...
