Question about Whirlpool WTW4800BQ White 27" Washer Top Loading, 3.6 Cu Ft
Where is serial number on WTW4800BQ?
White 27" top load 3.6CF
I am trying to get the basket out of the washer to check for coins. I am using a 7/16 ratchet to loosen the bolt and it won't move. Does it go clockwise?
The bolt unscrews counter-clockwise. Its possible that it might have rusted in place. Try spraying a little WD-40 down around it and keep trying.
Oct 05, 2016 | Whirlpool WTW4800BQ White-on-White 3.6 cu....
I need to check the drain pump to see if it is clogged as my washer won't spin. It is a whirlpool wtw4800bq top loader. How do I get to the drain pump?
Go to www.repairclinic.com and enter WTW4800BQ. You will be presented with a list of common replacement parts (such as the pump) and may be able to view a generic Whirlpool video showing disassembly and identification of major parts and assembles.
I'm looking for a more do it your self approach. Possibly check for error codes?
Autozone will scan your vehicle and they also sell a basic orange scan tool. Codes can be looked up with solutions on line. Remember the basic things an engine need ; gas, spark, and air.
Apr 15, 2016 | Whirlpool WTW4800BQ White-on-White 3.6 cu....
Lid lock broken. Can it be bypassed?
yes - jump the two wires going to the switch by the lock to bypass.
Mar 14, 2016 | Whirlpool WTW4800BQ White 27" Washer Top...
Washer will not fill spin or rinse, fill light blinking
Make sure the water is on going to the unit.
If that is good check
partselect.com and go thur there questions on what the unit is doing and it will give you a few ideas of what is cause your problems and parts to repair at good prices. I just used them to fix my washer too.
Good Luck
Sep 11, 2015 | Whirlpool WTW4800BQ White 27" Washer Top...
Won't go into final spin and lid lock light flashes
Will try and point you in the right direction you probably have one of the F7 codes which relate to motor speed, since the lid is locked you have to get the entire top up to do this on the back of the machine there is a screw on each side same level remove slide top bout 1/2" forward lift on the front panel infront of basket to the left should be a plastic packet with the service manual it will tell you how to place the machine in diagnostic and explain the error code and possible causes
Sep 05, 2014 | Whirlpool WTW4800BQ White 27" Washer Top...
I can not get the lid locked light yo stop flashing and the lid is closed and has not been in a spin wtw4800bqcycle
Check the lid to see if there is a small metal tab sticking down and at 90 degrees from the lid. If it gets bent that will cause it to do weird things. You can easily straighten it up with a pair of pliars.
Sep 05, 2014 | Whirlpool WTW4800BQ White-on-White 3.6 cu....
My Frigidaire Commercial Series FCCW3000FS 27" Coin Operated Front-Load Washer will not agitate or spin clothes out. Please HELP!
You should check your serial number at this link:http://www.cpsc.gov/cpscpub/prerel/prhtml09/09292.html
There was a voluntary recall issued on your model number. The serial number will confirm if your machine is affected.
As to your problem, i would still suspect drain pump is struggling or inoperable. However if it seems to drain ok and your pump is still relatively quiet except for a nice mellow steady hum (there should be no rattling sound) then i'd take a look at the pressure switch. The pressure switch sends the signal to begin agitation (water level in tub is full) and spin (water in tub is drained.)
Jan 03, 2013 | Frigidaire Commercial Series FCCW3000FS...
Whirlpool WTW4800BQ White 27" Washer Top Loading, 3.6 Cu Ft Logo
Dan Webster
Dan Webster
Sal De
