Question about Yard Machines 13AC762F000 38-Inch 344cc 12.5 HP Powerbuilt 7-Speed
Mower deck belt adjustment
Tighten mower deck belt
  • 957 Answers
I am not positive but there may not be any adjustment for the belt. I have had a number of ridding mowers and none of them had a adjustment for the belt. If it is slipping it is most likely worn and needs to be replaced. The ones that I have worked on do have a spring loaded pulley that keeps the belt tight. It is possible that you don't have tension on the belt maybe spring is weak or broken. Hope this helps
Posted on Apr 18, 2014
Is there a way to tighten the belt?
Don, there is usually a spring loaded tensioner to do this, the belt may be stretched and needs replaced, or some pulleys actually are now wear items and may need replaced. Check the video links below, some models are adjustable.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Mower belt tensioner repair question to the Garage Gang
http://support.mtdproducts.com/app/answers/detail/a_id/563/~/deck-drive-belt-tension-adjustment---riding-mower-(step-thru)
Tightening the belt on John Deere L110 Tractor
Mowing Deck Belt Replacement On Husqvarna LR12 Lawn Tractor
Apr 20, 2016 | Garden
How to adjust tighten drive belt on Poulan riding mower with 18 hp b&s motor 42 deck
Probably needs a new belt.You can buy a belt dressing and spray the belt once in a while. Its a special sticky spray for belts that slip.
That will keep you going for a little while.
Apr 11, 2015 | Poulan Garden
I need to replace electric starter with manual starter for ariens 948401-210e series cultivator
you must go to the supplier manufactue to request service manual for this procedure. However you can do this:
Remove the mower deck:
  1. Make sure that the parking brake is locked.
  2. Place scrap lumber under the front and rear of the deck.
  3. Use the deck lever to lower the deck.
  4. Remove attachments from the deck.
  5. Remove the blade drive belt from the front pulley.
  6. Remove the front and rear deck fasteners, following instructions in your owner's manual.
  7. Use the deck lever to raise the deck.
  8. Remove the scrap lumber.
  9. Remove the deck from under the mower.
Adjust the drive belt:
  1. Remove the belt from the large idler pulley.
  2. Remove the belt from the adjustable idler pulley.
  3. Carefully remove the spring-loaded large idler pulley.
  4. Loosen the adjustable idler pulley and move it slightly toward the rear of the mower to tighten it-or move it toward the front to loosen it-and retighten the pulley.
  5. Replace the belt.
  6. Check belt tension and readjust as needed.
Nov 20, 2013 | Garden
I have a 2011 cub cadet ltx1040 with 42 inch mower deck. replaced belt, pto cable and spindle brake pads. Belt is still loose when pto engaged and cannot find any adjustment to tighten belt. All parts...
If all the parts are correct then you need to check the belt routing diagram. Sometimes you can find it on the mower deck and in the owners manual. Look carefully at the spring locations on the deck to be sure there correct. George
Aug 31, 2013 | Garden
CANT KEEP MOWER DECK BELT FROM POPPING OFF
Its to old. Wrong belt. Or needs ajusted. Tighten up.
Jul 14, 2013 | Craftsman 26 Hp 54" Deck Yard Tractor
Replaced deck belt and it keeps coming off,whats wrong?
The belt tensioners on top of the deck need adjusted, or you make have to adjust the pulleys to tighten the belt. Sometimes if you have the deck lowered to low to the ground, uneven terain can cause that. If you have everything adjusted correctly, simply raise the deck another notch and mow.
Aug 09, 2010 | Yard Machines 155 Torque Briggs Stratton...
I need to tighten belt for the mower deck, how is that done? it is a 2004 craftsman 17.5HP 42 " deck. Can you help me
Each of the pulleys on top of the deck should have tensioners. These tensioners are usually the type which have a bolt for you to tighten while attached to the pulley. While you tighten the bolt, the pulley puts tension on the belt.
Aug 05, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Trying to put a new drive train belt on my sit on murray lawn mower
Drive belts can be a pain. You are going to have to drop the deck belt out of the way and sometimes drop the front of the deck to be able to get the belt up around the front pulley. Feed it through the belt guards if possible...if not, you are going to have to loosen or remove the guards to get the belt where it is needed. Then loop around rear pulley, tighten guards, hook up deck and replace deck belt.
www.nnyparts.com
May 29, 2010 | Garden
How to replace deck belt on lt 1000 craftsman riding mower
there are several belt guards that you will need to loosen then the belt will slip right on. having someone hold the clutch will make it easier, and the belt diagram should be on the deck. If not, these are common mowers, so a search for this or a friends/neighbors mower may hold the answer. Be sure to re tighten all guards or your belt will pop off and wear out very fast against these metal parts
Sep 15, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
How do I tighten the mower belt on a lt1000?
It is kept tight by a tensioning pully. If it is loose, replace it.
regards, --W/D--
Jul 20, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Yard Machines 13AC762F000 38-Inch 344cc 12.5 HP Powerbuilt 7-Speed Logo
212 people viewed this question
Top Yard Machines Garden Experts
dannydoesita
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
