Question about Onkyo TX-DS474 Receiver
Connect tv How do I connect my onkyo tx-ds474 receiver to my samsung smart-tv type:UE46ES5500W
simplemitch
  • 752 Answers
SOURCE: Onkyo TX-DS474 Receiver shuts down after Standby mode.
It's going into a protect mode. The amp is probably shorted out. Disconnect the spkrs and turn it on. If it still shuts off, it's the amp, if not, it's the spkrs.
Posted on Sep 15, 2007
  • 151 Answers
SOURCE: DVD signal received in wrong aspect
PRESS SETUP GO TO MISCELLANEOUS PRESS ENTER THEN DOWN TO OSD SETUP PRESS ENTER AGAIN AND DOWN TO MONITOR AND CHANGE TO 16.9.
HOPE THIS HELPS.
CABLE GUY.
Posted on Jun 04, 2008
  • 151 Answers
SOURCE: Echo when connecting Samsung Plasma to Onkyo TX-SR602
Make sure you have the tv volume turned right down as this will cause an echo,also set amp to prologic 2, and set up xover to suit your speakers or go for the THX standard of 80 hrtz and as a rule of thumb set front L,C,R speakers to zero rears to about +4or5 and your sub to -5[ dont know which speakers you have but try setting the subs on board volume to the 10,o,cloak position],also make sure the speakers -,+ are wired the same at the amp and speakers.
Hope this helps.
CABLE GUY.
Posted on Jan 06, 2009
pgh_pa_guy
  • 2992 Answers
SOURCE: Connect the receiver to a Samsung LN32A450 TV?
I have a model LN32A330 which is probably has connections similar to yours. I'm not home right now to check whether it has a digital output, but I know for sure it has an analog audio output available. You can run that output to an available auxiliary or a/v source input on the receiver and that will work for you. That's how I have mine connected. If the set has a digital output and the receiver offers digital inputs, that's another connection possibility. The digital output on some brands of TV only works in conjunction with the tuner, and may not always have output. The analog method is guaranteed to work.
If this solution has helped get you on the way, please take a moment to give it a fixya rating. Thanks for asking here!
Posted on Mar 12, 2009
ripleymojica
  • 643 Answers
SOURCE: onkyo tx-sr604
easiest fix is to take all hdmi straight to tv. then come out of tv with optical cable to your receiver. that way what ever your watching will automatically be sent to the receiver thru optical. you even will get dolby dig. also you can have audio from your tv when you dont want to use your surround. keeps receiver on one input also.
Posted on Jul 02, 2009
Onkyo tx sr502vreceiver wont send sound out when trying to play a cd. Hooking up to samsung smart tv that has no s video or optical output connections. HELP ! ! !
Hi Denni, the TV should not be a factor. Is the CD player connected to the receiver. It should be playing out the receiver speakers. Thank you, Onkyo USA
Nov 30, 2016 | Onkyo Audio Players & Recorders
Onkyo tx-ds 474
press and hold the video 1 button and then press the speaker A button - you should see 'clear' on the display. This will reset everything
Jul 14, 2014 | Onkyo TX-DS474 Receiver
I would like to connect onkyo TX-DS474 to my television to play the television sound thru the receiver
you will need a Analog audio cable (RCA) connect one end to Game/TV on the back of the onkyo and the other end to the TV audio out then just press the game button on the front of the onkyo you my have to go into the menu on the av to set the Analog out-put for game/
Oct 16, 2011 | Onkyo TX-DS474 Receiver
I am using an Onkyo TX-8255 receiver with the ION Profile Pro USB Turntable and I'm hearing distortion through my speakers at all volumes. The speakers and the receiver work fine with the radio and the...
The TT should be connected properly for the way it's configured (Line Level Out to any Line Level In OR Phono Out to Phono In) and NOT any other way.
Some background reading:
http://en.wikipedia.org/wiki/RIAA_equalization
Jan 15, 2011 | Onkyo TX-DS474 Receiver
How do I connect my Samsung Model un46b8000xf led to onkyo receiv
Use the TOSLINK - the optical/digital connector on both devices.
Jul 07, 2010 | Onkyo TX-8511 Receiver
Hi all at Onkyo I just have one question about my high definition HD DSP TX-DS474 that I purchased second had from a repairer. It is a fantastic piece of electronics but I don't know how to calibrate the...
Westnet Broadband 1800383368 Support Number Australia For Broadband Support
Alike other Broadband services some kind of errors are very common in Westnet Broadband which occurred occasionally. Amongst all the Broadband Westnet is one of the efficient and most famous Broadband Service Provider. There is Hundred number of Broadband service across the world and a large number of the user using the Broadband service. Users have no issue with this Broadband service. Some kind of basic issue occurred in Westnet which are given below-
    ?•Broadband Service
    •DNS Service
    •Webhosting
    •VPN
    •VPDN
    •IBC and Dial-Up
    •Colocation Service
    If any other account creation related issue occurred in Westnet then just Dial Westnet Broadband Support Number. If the user face any problem Westnet Broadband our expert told you how you can solve your problem.
    For More Details Call on WESTNET Broadband Support Number Australia
    1-800-383-368
    Or Please Visit http://faylyn.forumcity.com/viewtopic.php?p=7496#7496
    https://help-desk-australia.site123.me/
May 27, 2010 | Onkyo TX-DS474 Receiver
Front buttons won't work
The microprocessor may be locked up. While pressing and holding "video 1", press "speaker A". When "clear" appears in the display, the micro has been reset to the factory default condition. To do a full reset without taking it apart, it may have to sit up to 3 weeks for the backup battery to run down.
Dec 21, 2007 | Onkyo TX-DS474 Receiver
Re: ONKYO with New LCD HI Def Television
Hi Lucylu
I don't have a solution to your problem -- but I do have the receiver and want to hook up my Plasma TV through the ONKYO TX-DS474 receiver. Its a great receiver but am not sure it will "do the job" being so old in the tooth.
Hope you found a solution!!
Gary
Nov 18, 2007 | Onkyo TX-DS474 Receiver
Onkyo TX-DS474 Receiver Logo
51 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
