Question about Frigidaire FRS3R5EMB Side by Side Refrigerator
Frigidaire Professional PLHS69EESS2 - Frigidaire FRS3R5EMB Side by Side Refrigerator
Frigidaire professional dishwasher buttons don't work
I appreciate your inquiry, friend!
I have identified a few possibilities as to why the buttons are not working on your Frigidaire Professional dishwasher. It could be a stuck button on your keypad and I would recommend pressing every button to see if one is stuck or loose. It could be that the keypad or control panel needs to be replaced. This is not a simple DIY job and I would recommend reaching out to a professional technician for proper diagnosis. I hope this helps. -Matt
Sep 25, 2014 | Frigidaire Professional Series 24 in....
Grinding sound in FGHD2472PF frigidaire professional
Hello friend, thank you for your inquiry!
I understand that your Frigidaire dishwasher is making a grinding noise. Typically that noise could be a faulty motor/pump. I have included a link to your manaul. If that does not help I would recommend having a technician out to your home to properly diagnose and repair your appliance. Best of luck. -Matt
Frigidaire Manual Search Results
Aug 14, 2014 | Frigidaire Professional Series 24 in....
Frigidaire dishwasher error code
Hello Teresa Ann - Typically error code UO indicates that while the dishwasher is in wash cycle, the main control board is not receiving signal from the vent assembly and that the vent plunger is in a closed position. A professional will need to check the wiring between both parts and depending from the results either part may need replacing.
Jan 19, 2013 | Frigidaire Dishwashers
Frigidaire electrolux double oven pro series upper oven not heating properly wont keep temperture
Hello theeggleton6 - Sounds like the mechanical thermostat, oven sensor or EOC needs to be diagnosed for replacement. I would suggest contacting a professional to move forward accurately for proper diagnosing.
Nov 14, 2012 | Electrolux Frigidaire Professional Series...
Oven door locked and fan going frigidaire professional range
Did you solve your problem? I just got stuck in the same situation! How did you stop it?
Jul 09, 2009 | Electrolux Frigidaire Professional Series...
Frigidaire professional series electric oven door won't open
MY OVEN DOOR WONT UNLOCK ON MY FRIGIDAIRE PROFESSIONAL SERIES STOVE 31606390
Jan 22, 2009 | Electrolux Frigidaire Professional Series...
Frigidaire Fridge PLHS69EESS2
Could be a jammed fan or something could have moved inside to block the opening. Some units have deflectors in the openings...did one of those cover the opening on the fridge side? Did you overpack your freezer and block the air flow from there to the fridge?
Dec 29, 2007 | Frigidaire FSC23F7DSB Stainless Steel Side...
Frigidaire FRS3R5EMB Side by Side Refrigerator Logo
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
