Question about Saniflo 021 Saniswift Water Pump - Kitchen
Stuck float on saniswift 021 - Saniflo 021 Saniswift Water Pump - Kitchen
My water supply pump to house works but does not pump water from tank to house
What type of pump is it? Is it a shallow well pump or submersible
pump? Is the pump connected to a pressure tank? How have you confirmed that the pump is working properly? Is there a drain valve, and is there water pressure from the drain valve when it is opened? If the pressure tank is of the pre-charged type, is it working properly? Is there water coming out of the air valve? Are there any shut-off valves in the system which may have been turned off, preventing water flow?
Apr 17, 2014 | Saniflo 021 Saniswift Residential Water...
Stuck float
The float is stuck, how? do you mean you cannot pull the little hinge pin out OR the float wont move up or down? If the float wont move up or down then; Your float is stuck because the needle valve is stuck in the Seat area. Spray carburetor cleaner in that area and slowly try to work the needle valve up and down. It should free up very soon and the needle valve and float will come down and out.
Jul 23, 2013 | Garden
My Little Giant APCP 1700 stopped running even when submerged. Now its stuck in a continuous run mode after I played around with the automatic float stick position. Why is it stuck in this run mode?
the floats are mechanical on these pumps, unlike the electronic ones on other models , the floats can get stuck on them most common reason is forign object stuck up inside area of float (leaves, tree droppings etc)
Feb 03, 2013 | Little Giant APCP-1700 Swimming Pool Cover...
Which is more reliable..a stihl 017 or a stihl 021 ? looking to bid both in good runnung shape...thanks
Hi, you cant go wrong their both stihls. The 021 is a more powerful saw and the 017 is lighter, so it all depends on your intended use. Regards Phil.
Jun 26, 2012 | Garden
BIKE WONT START FUEL STUCK IN FUEL INLET OF CARBURETOR
The float is stuck in the closed position. Remove the float bowl on the bottom of the carb and spray carb cleaner at th float needle. Gently lift the float upward then let it drop. Repeat this several times until the fuel flows when the float is dropped and stops when the float us lifted upward. Please rate my answer. Thanks! Below is a generic diagram. tombones49_13.gif
Mar 25, 2011 | Honda CM 125 C Motorcycles
The fuel is leaking from the float bowl when the engine is running. Is the float stuck?
either the float is stuck in the down position or the float needle cannot close properly due to debris in the float valve or a worn float valve assembly.
Feb 26, 2011 | 2004 Yamaha YZ 125
Stil 021 chain saw. It starts easy, but when throttling up, the cain bar will not move. I have disasmbled the covers and am able to move the sprocket with a pair of pliers. How do you remove the...
This sounds like you may have the chain brake stuck on. The hand guard is also a chain brake. release the chain brake by pulling backwards on the handle. If this does not fix the issue remove the clutch by pulling the c-clip and retaining washer. I would look at the bar and chain and make sure they are not bent or damaged. ask a local dealer like www.arcolawn.com for parts or tools you may need. Good luck barterjoe_12.png
Nov 01, 2010 | RTO Spur Sprocket For Stihl 017, 021...
Fuel leaking out of the air box drain tube while engine is running, that would almost have to be a stuck float right?
Yep you got it a stuck float or possibly a plugged main jet, but more likely the float....and probably its not stuck, its probably bad and needs replaced, if there is fuel in the float itself replace it.
Nov 13, 2009 | 1990 Suzuki GSX 600 F (Katana)
Error code 021
Press
Function
7
monitor slowly 4 times
6
scroll down to SHIPMENT SET
set
wait for the fax to initialize and come back to READY
Sep 29, 2009 | Panasonic Panafax UF-585 Plain Paper Laser...
Saniflo 021 Saniswift Water Pump - Kitchen Logo
Top Saniflo Plumbing Experts
jasbo
jasbo
Gil Shultz
Vernon Taylor
Are you a Saniflo Plumbing Expert? Answer questions, earn points and help others
